Tires question
Discussion in 'Gen 4 Prius Technical Discussion' started by Oh4Corolla, Dec 11, 2020.
  1. Oh4Corolla
    Oh4Corolla Junior Member
    Mass
    2017 Prius ll here with 40k miles. With all the construction around here, I've several flats from debris/nails and I'm at the point now where I have 2 patches on the same tire. And 1 patch on another tire. Local mechanic told me next step is to buy a new tire if that tire gets another puncture. I can't, however, find the same tire that I have on there now. It's a Toyo Nanotechnology tire which "boasts a rolling resistance performance rating of AAA and wet grip performance rating of b under the Guideline for Tyre Labeling to Promote the Use of Fuel Efficient Tyres".
    All the tires look like they have a good amount of tread left.
    So with that said my questions are:
    What would you do? Replace the tire now just in case? Wait until it gets another puncture?
    Is it fine to replace with a random brand?
    Where would you go to replace the tire or tires?
    Are there high mileage tires or high MPG tires that are worth the extra cost?
    I heard Costco is great for tire replacement/warranty so I just signed up for a membership and was quoted around $115 for 1 tire or ~ $355 for all 4, for BFGoodrich Advantage T/A Sport.
    .We also have a BJs membership.
    Thanks!
    #1 Oh4Corolla, Dec 11, 2020
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I don't understand why he/she's saying that you need to replace it just because it's had a puncture? That's a new one to me - back in the old days, we'd get lots of punctures, get them fixed and keep collecting patches.
    Unless of course it was damaged by having been driven on while flat?
    Oh4Corolla and Salamander_King like this.
  3. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    I am with @alanclarkeau. Unless your next puncture is the "unrepairable" type, I would just keep driving and repairing until you have to change all 4 tires. If the "patch" was done correctly, it is a permanent fix good for the life of the tire. If you have one of that unrepairable puncture, such as on the sidewall or too large a hole to patch, then you have some choice. If other tires still have plenty of treads, you could just change one tire of the same brand and model if you can find one, but a tire of similar characteristics will be OK. You will be able to find a make and model of tire you need from an online shop if you can't find it in a local shop, but most tire shops can special order any tire you want. But most tire shops recommend at least a pair of the same type of tires with similar tread on an axile. But if you do this then your tire rotation may become off, for a new set of tires will be on the rear, and your old tires will stay in front. You always have less treads on the front by changing only two tires at a time. Since most tire place gives you a better price when you buy a set of four tires, at some point, you will probably better off changing all four.
    Edit: One additional point, if you are experiencing so many punctures, it may be worth buying road hazards insurance on the tire purchase, it usually costs ~$15/tire, but it will cover free repair and if it is not repairable, then they will give you prorated discount on new tire purchase. Maybe worth looking into if you have a good tire shop nearby.
    #3 Salamander_King, Dec 11, 2020
    Oh4Corolla and alanclarkeau like this.
  4. Merkey
    Merkey Active Member
    327
    298
    Birmingham, Michigan
    I'm pleased with the Michelin Defenders from Costco. Good wear and mpg. They have approx. 45,000 miles now
    with probably 20,000 left.
    Oh4Corolla and Mendel Leisk like this.
  5. sclevine
    sclevine Active Member
    170
    160
    Northeast Florida
    2024 Prius
    Agree on not to change the tires just for punctures. I replaced my tires at 70k, about 2 years ago, and that winter in the first 3-4 months on the new tires, I had 4 punctures in 3 tires (bad luck I guess). I had a 2nd unrepairable one in one tire, but BJ's replaced it free under warranty. In the 20 months since, never had any more punctures, never even had to add air to the tires outside of normal maintenance, and finally just replaced them again after 70k more miles - probably 50k miles with no additional punctures.
    Oh4Corolla and Merkey like this.
  6. bluespruce
    bluespruce Member
    79
    72
    New England
    2020 Prius Prime
    You probably don't need to change them but you may want to. Personally I love the feel of fresh tires. The last 1/4 life of tires they are noisy, prone to flats and do not instill confidence. Prius tires are not expensive so it may be not be necessary but its still a low cost purchase. Being able to buy cheap tires is one of the great things about these cars.
  7. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    If you do decide to buy new tires, don't you want to put exact match tires on the same axle? In other words, change two tires minimum. Not so much a problem between axles on 2WD (FWD or RWD), but I would want to match tires at least on the front (driving) axle. Even on AWD vehicles, I believe the wisdom is exact match tires on all 4. You've got speed sensors on all four wheels that feed into Anti-Lock Braking, Traction Control and Stability Control that expect similar tire properties for the algorithms to work.
    bluespruce and Oh4Corolla like this.
  8. alanclarkeau
    7,045
    7,593
    Yes, I generally do them in pairs too - per axle. But - depends on the situation.
    Oh4Corolla likes this.
  9. Oh4Corolla
    Mass
    Thanks to you an Alan. It sounds like the mechanic gave me bad advice? So what you're saying is that there is no limit to the amount of patches one wheel can have? He's not my usual mechanic, just the closest shop that could fit me in for an immediate patch. It's more of a gas station anyways so I don't put a lot of trust in what he says.
    Also - I'm leaning towards Costco because they offer 5 year road hazard on all tires for free. Thanks again
    Salamander_King likes this.
  10. Salamander_King
    11,024
    8,977
    New England
    A cursory search seems to point to the recommendation that you can have multiple patches as long as they are at least 16 inches apart. And there seems to be a rule of thumb that you don't want to have more than 3 patches per tire. I can see that's because if you have more than 4 patches, chances are they are within 16 inches. So, your mechanic may not be giving you totally off-the-wall advice. It seems it is unsafe to be trying to patch holes that are too close to the previous patch.
    How many times can a car tire be patched? - motorbeast.org
    Most dealers’ advice is that tires shall not be patched more than three times, having one patch per one-third of the tire. There is, however, no officially set limit as to how many times you may patch up your tire as long as a few industry rules are observed;
    • Patches shall not overlap.
    It is not safe to patch over a previously repaired area. If damage occurs in the same place, you may consider replacing the tire altogether for your safety on the road. While not overlapping, patches should not be done too close and if there are too many leaks close together, it may be time to replace the tire.
    Other sources with similar recommendations.
    How many times can you patch a car tire? - Quora
    How Long Can You Drive on a Plugged or Patched Tire? | YourMechanic Advice
    #10 Salamander_King, Dec 12, 2020
    alanclarkeau and Mendel Leisk like this.
  11. RRxing
    RRxing Senior Member
    2,560
    1,836
    NEPA
    Different locales may have different requirements that limit the number of times a tire may be patched. No shop is going to want the liability if they made the last (fourth? ninth?) patch and it goes flat, causing you to careen off of the road into a canal (example only).
    FuelMiser likes this.
  12. Oh4Corolla
    Mass
    Thanks all for the input. You helped me make a good decision here... For safety and peace of mind, I'm going to order 4 new Bridgestone Turanza QUIETTRACK tires from Costco, which are the highest rated from the available options. $490 OTD. Thanks!
    krmcg, Merkey and Salamander_King like this.
  13. bluespruce
    bluespruce Member
    79
    72
    New England
    2020 Prius Prime
    Oh4Corolla......Those are suppose to be the best tires per Tireracks website. I would be interested on what you think of them in the future. $490 out the door is a great deal too.
  14. jdenenberg
    jdenenberg EE Professor
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Tirerack only rates tire models/brands that they sell. Some very good tires are not on their lists including one of the best choices for a Prius - Nokian WRg4 "All Weather" tires.
    JeffD
  15. jdenenberg
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The reason for the rule to replace all 4 tires on an AWD car is that a difference in rotations per mile will cause excessive wear on the transfer case clutches. This rule does not apply to a Toyota AWD-e vehicle as there is no mechanical drive-line connection between the front and rear axles.
    JeffD
    FuelMiser and Merkey like this.
  16. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,011
    NJ-USA
    It sounds as if the shop has a conservative tire repair guideline probably due to liability. They don't want to be responsible if a tire fails after they repair it.
    krmcg likes this.
  17. Recian
    Recian Junior Member
    62
    22
    New Bern, NC
    I've got a 18 thatll need some tires soon. How do you like those? A friend put those nokians on his gen 2 when his toyos were spent because they were cheap and the sidewall laimed they were LRR but he said he didn't notice any mpg changes. The toyos weren't specifically LRR and he noted 41-42mpg before and after
  18. jdenenberg
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The Toyos on a GEN2 were good for MPG in warm weather, but rolling resistance went up in the winter. I went from the Toyos to Michelin MXV4+ and saw some MPG improvement in the winter. When I switched to Nokian WRs (then WRg2, then WRg3) tires there was a further improvement (I averaged 46 MPG over the 12 year-188k miles life of my 2004 Prius). I have continued to use Nokians for my Gen4 (now WRg4). They last a bit over 50k miles, have good bad weather traction, are strong tires (the "H" rated version, max cold PSI is 51) and are LRR (not the Run Flat models!).
    JeffD
  19. Recian
    62
    22
    New Bern, NC
    So should I be looking for a LRR with the max 51psi? A harder tire that'll hold up better, can run higher psi and being harder it'll be less sticky. I know ecopia has alot of options. My last store we sold a few Nokians but you can't find them much anymore. Besides the ecopia continental makes a good looking (by specs) tire. It's eco+, 800 tread wear, 51psi max and a H rated tire and $11 cheaper along with 1 lb lighter than Dunlop and ecopia
  20. alanclarkeau
    7,045
    7,593
    You WON'T use 51 on a PRIUS!!!
    The figure on the sidewall is what the tyre is rated at for MAX - definitely not what you drive with. That figure is what it's designed not to blow-out at - but using that pressure on a PRIUS would be unsafe. Just ignore that figure - it's always much higher than what you'd drive at.
    Look up the CAR Manufacturer's recommended Tyre Pressure Placard - it's on the door opening on most cars (glovebox lid on one I had). It's also in your HANDBOOK.
    Some cars have different front/rear pressures - if you're going to over-inflate by 2 or 3 PSI like some people might suggest - maintain any F/R differential. Pressure differential can affect handling (more FRONT can cause it to oversteer, maybe dangerously; and vice-versa).
    bluespruce likes this.
