Tires/Rims to Raise Ground Clearance
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by 2015 Prius PP, May 15, 2015.
  1. 2015 Prius PP
    2015 Prius PP New Member
    bay area
    Hi everyone. I’m in the market for either the Prius V (5) or Prius Plug-In and I have a question about changing tires/rims to increase ground clearance. My understanding is the 5 comes with 215/45R/17 and the Plug-In comes with 195/65R/15. I have done some searching and was wondering if any of these configurations would work.
    Prius 5 = change the tires to 215/65R/17 from Michelin.
    Prius PP = upgrade the rims to 16” and use tire size 205/65R/16 from Michelin.
    Would any of the two options above works without changing the way the car drives? My goal is to have the car raised at least close to an inch and I don’t mind losing some MPG by doing so. Please let me know.
    Thanks,
  2. Mendel Leisk
    42,323
    Make sure there's tires available in the sizes you're seeking. Taking the 215/65R17 for example, just a quick peruse of Michelin's be offered at TireRack, I don't see any 17" with that high a profile, they're mostly 45 through 55 profile.
    I gather this is to cope with your steep driveway. I'm struggling to avoid comment on your approach, I'll just say, in your shoes, I'd explore all alternatives.
    Tracksyde likes this.
  3. JC91006
    16,936
    8,647
    I believe on the 17" wheel, the largest size you can go on the tire would be to a 50 series tire. 215/50/17. Anything else would rub.
  4. 2015 Prius PP
    bay area
    Thanks for the responses. When I searched, I thought I saw 215/65R/17 from Walmart or maybe I'm mistaken. However I am sure 205/65R/16 is available as it is shown on Tirerack website. Will this work without causing any rubbing? This will cost more since I have to buy the rims, but I don't mind.
    Why does my driveway curb has to be so damn angle and high.
    Thanks.
  5. mikefocke
    4,076
    1,860
    Sanford, NC
    Can you place a 2 by 10 or 12 in the gutter to soften the abruptness of the driveway approach angle?
    Seems to me raising the height of the car means changing the circumference of the tire which means all the electronic calculations that simulate a gearbox would be off.
    rxlawdude, Ken Blake and Mendel Leisk like this.
  6. Mendel Leisk
    42,323
    A picture of the driveway situation would be helpful. Is it a hump or dip you're dealing with?
  7. JC91006
    16,936
    8,647
    The easiest solution is to buy a Rav4
    rxlawdude likes this.
  8. 2015 Prius PP
    bay area
    No offense but the new RAV is not good looking with all those black plastics. My drive way curb has a dip, approximately 6"-8" but it is angled at about 30 degree ,not very smooth transition. I can't put down anything to help me go up or back down as that can block water flow.
    It seems like its not advisable to change the rims or tires. This is too bad since I really want the Plug-In.
    Thank you all for help.
  9. Mendel Leisk
    42,323
    Yeah, it's a little nuts that you need an all-terrain vehicle to negotiate your driveway, but there it is.
    Up the hill from us the builders got away with VERY steep driveways. Most noticeable are ones that climb steeply, then level out. At the crest you'll often see gouges from exhaust pipe flanges and what have you. And when you get a bit of snow or ice (getting rarer) they're near impassable, sans four wheel drive, lol. I think what happens is the builders work right up to the limit of regulations, and the reg's are too slack.
    If you're renting, relatively mobile, and really want a Prius: put it on the back burner for now and start looking for somewhere with a level driveway? Better too for carwashing, etcetera.
    #9 Mendel Leisk, May 15, 2015
  10. Okinawa
    Okinawa Senior Member
    1,333
    320
    I don't know what his driveway looks like. They make blacktop in bags. Maybe he could buy a few bags of that. Spread the blacktop out and tamp it down. Nice and easy permanent repair job. Certainly better than trying to modify his car and causing a lot of problems.
  11. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  12. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
  13. 2015 Prius PP
    bay area
    The image from the website illustrate exactly what my curb is and that would definitely solve mu problem. Do you know if it easyto lift up because I don't want to spend $400 on a product that soneone can easily pick it up and take off with it. This product seems like a cheaper solution than buying new set of rims and tires.
    Thanks!
  14. Mendel Leisk
    42,323
    I started thinking about that too, that someone might walk off with them.
    Wonder: could you convince the city to come by, put in some asphalt?
  15. Okinawa
    1,333
    320
    If they are used where there is snow the snow plow is going to do a number on them the first time around, if the teenagers don't get them first.
  16. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    They will weigh 150 to 250 pounds, so it will be non trivial to walk away with them solo. Screwing them into the asphalt is going to make clean up much more work.
  17. jabbinan
    jabbinan Junior Member
    CA
    I just had an engineer figure out how this would affect your odometer reading, going from 15" to 17" wheels: speedometer will be off 16%, and you gain just 1" not 2" in height or ground clearance. There may be serious ways it will affect computerized trans too. Better way, I think??-is to get height by suspension changes. I want to increase height just to mitigate SUV/truck oncoming headlights, so any cures, I'm interested on a 2012 Prius 4. Joe
    Pluggo likes this.
  18. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
