Tires size possible deal breaker on 2023 Prius?
Discussion in 'Gen 5 Prius Main Forum' started by Dionysus81, Jan 13, 2023.
  1. Hammersmith
    Hammersmith Senior Member
    2,333
    2,392
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Assuming someone that is buying a Prius is going to want as narrow a tire as possible to minimize resistances, the 205/55R17 might be the better choice for the 17" wheel.
  2. Mendel Leisk
    41,967
    Yeah I hear you. Our stock tires are 215/45R17, and I switch to 195/65R15 snow tires every winter: mpg stays neck-and-neck.
    it’s a combination of width, different tire and different inertial mass with the 15” steel rims I think.
  3. JoeBlack
    JoeBlack Member
    112
    89
    Europe
    2021 Prius PHV
    I was seriously pretending they do not exist :-D that EU sticker looks fairly crappy for something that should roll with a Prius.
    TBH, I haven't found them anywhere available and only a handful of shops even listed them ... yeah, you are right, they exist :)
  4. myktek
    myktek Junior Member
    Houston, TX
    ...looking online for 20's that would fit
    lol
  5. PaulDM
    PaulDM Active Member
    616
    319
    UK
    2022 Prius
    Excel
    Pity the UK isn't getting the car, as we have tyres. Lol.
    195/60/17 Michelin Primacy 4
    bisco and Todd Bonzalez like this.
  6. Trollbait
    12,700
    Are you getting the PHV?
  7. bisco
    52,435
    unless one goes bad
  8. Trollbait
    12,700
    Does it rot, or take up a life of crime?
  9. TGTGUUD
    TGTGUUD Member
    97
    75
    San Francisco
    2024 Prius
    It will be stupid for places like Costco to not provide the new sizes if the new Prius sells well.
    I bet the new Prius won’t be available under MSRP for a long time, which is the real problem here.
  10. bisco
    52,435
    Possibly, but more likely an accident or road hazard
  11. Trollbait
    12,700
    It is a risk, but then many punctures can be repaired.
    Negotiating an extra tire when buying isn't a bad idea for those concerned.
  12. bisco
    52,435
    Dealers probably won’t even have any until long after cars are available, and I doubt they’ll be willing to negotiate anything
    PaulDM likes this.
  13. Rmay635703
    Rmay635703 Senior Member
    2,669
    1,694
    Somewhere in Wisconsin
    2013 Chevy Volt
    215/55 & 215/50 r17 are common as dirt now days.
    That will be the lazy man’s cheap Tire option
    BMW I3 tires will likely work as well even though they are a bit off in size.
    Want a real head scratcher?
    I have 2 cars that can only accept small 13” tires
    155/65r13 and 125/80r13.
    Literally can’t get them on this continent
  14. daisy555
    daisy555 Senior Member
    1,727
    715
    CT
    For someone who isn’t able to wait until the second year of Gen 5s to be released, this tire situation is pretty depressing. I rely on reasonably priced all season tires. I live in CT but most of my driving is in RI which has horrible road conditions. I didn’t realize these 19” low profile tires will add challenges to winter driving. I also don’t have a car I can borrow while waiting a few weeks for an expensive tire to arrive.
    Ok…I’m turning into perpetual waffler #2.
  15. Trollbait
    12,700
    I think whatever was stated in the owner's manual about snow or winter driving with the 19in wheels is there for legal CYA.
    What I'm finding on low-profile tires during the winter seem to be based upon generalities in regards to what tires and wheels are usually equipped. Typically, the larger wheel options a car has also include being wider. With wider tires, they may ride on top of the snow, instead of pushing it aside to stay on the road surface. Riding on the snow could lead to more sliding. After market wheels with low profile tires seem to be even wider than what the factory would put on.
    Low profile wheels are popular as a performance upgrade in cornering. Which leads to performance tires being commonly installed. Which is just another term for summer or three season tire. As the name implies, they aren't meant for winter driving. The rubber is formulated for traction under moderate temperatures. It gets stiff, and starts losing traction ability before the temps hit freezing.
    So low profile tires tended to be wide, summer tires, which aren't good for winter driving and weather. Wide, summer tires that aren't low-profile are equally bad for winter though.
    The Prius doesn't have wide, summer tires on the 19in rim. They are reported to be all seasons, and are the same width as the tire on the 17in wheel. They might be narrower than the tires on the larger wheeled gen4.
    Perpetual Waffle, drash and daisy555 like this.
  16. mikefocke
    4,044
    1,839
    Sanford, NC
    I road to high school across town in the snow in a Model-A Ford with 2 5/8 inch wide tires. Narrow and certainly not studded or have any obvious snow traction tread that I remember. Not pushing much snow aside has its advantages. Ice would be another story.
    GuyLR likes this.
  17. daisy555
    1,727
    715
    CT
    Thank you for taking the time to share this info.
  18. Mendel Leisk
    41,967
    It'd be interesting to see if a 15" rim, say an old Corolla steelie, would clear everything.
  19. Trollbait
    12,700
    I'm finding 11.1 in diameter for the front brake rotor. So the wheel needs to clear 5.55 inches, plus the caliper, with the width of the tire rim. The rotor on the gen4 was 10 inches. I wouldn't bet on a 15in wheel fitting the gen5.
  20. beamsley
    beamsley Member
    66
    100
    2023 Prius Prime
    Premium w/ Solar Cells
    Can confirm. I own a 2020 Miata with similar brake size specs. Best it can swing is a 16" rim.
