Tires, Tires, Tires
Discussion in 'Prime Fuel Economy & EV Range' started by maprice, Sep 1, 2023.
  1. BiomedO1
    BiomedO1 Senior Member
    4,596
    2,410
    Left Coast
    If the inside edge of your current tires are going bald - you've got uneven wear and definitely need an alignment. If you don't do an alignment; you'll place that same uneven wear pattern on the new set of tires and pretty much VOID the mileage warranty. They will blame mechanical misalignment and/or suspension issues - not manufacturer's defect. This could also void your road hazard warranty.
    dicknose likes this.
  2. Mendel Leisk
    42,345
    To verify: your wheels are 15" diameter?
    Was the head gasket replaced then? I'd recommend you clean the full EGR system as well, if it wasn't done. More info in my signature. (on a phone turn it landscape to see signatures)
    douglasjre likes this.
  3. PHEVisthefuture
    PHEVisthefuture Junior Member
    83
    25
    Illinois
    My experience has been - tires make a HUGE difference on an EV/HEV/PHEV car, not so much on a gas or diesel car. On my 2012 Volt, I gained around 5-7MPG compared to regular all-seasons, when using Bridgestone Ecopia EP422+ tires (or 4-5MPG gain with Goodyear Assurance Fuel Max tires).
    On everything else, tires don't seem to do much for MPG, unless you get into dedicated snow or off-road tires. YMMV, you should also get an alignment too like Biomed01 said to increase the life of your new tires.
  4. Gerald10
    Gerald10 Junior Member
    38
    what about continental tires?
  5. PHEVisthefuture
    83
    25
    Illinois
    They are said to be good, I only have limited experience with them (gasoline car & not one that was known for MPG). It had a 5-speed manual, the aerodynamics of a brick, and did 3,000rpm going down the highway. So nothing I did could improve MPG, that's like saying "I put a spoiler on my Nissan Pathfinder, why doesn't the handling improve"
    I'm sure they are fine, just not sure how they rank compared to the aforementioned Bridgestone Ecopia EP422+ and Goodyear Assurance Fuel Max tires that were winners in MPG on my previous PHEV cars.
  6. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    Have u done the math on brand X vs the cheapest tires sold at Walmart?
  7. PHEVisthefuture
    83
    25
    Illinois
    I have not. I'm just going by personal experience when swapping between Goodyear Assurance Fuel Max and Bridgestone Ecopia EP422+ tires on a previous hybrid. The cheapest tires at Walmart may offer a lower cost per mile, but have higher fuel usage and emissions. All engineering is a trade-off...
  8. douglasjre
    2,250
    751
    Null, NL
    Like I said. I encourage you to do the math and see how much fuel savings is required to make up for the higher price of the tires you are choosing. Please do this math, as I have and report back
