To Charge or not to charge- that is my question
Discussion in 'Prime Fuel Economy & EV Range' started by Mark Schneider, Apr 15, 2019.
  1. fuzzy1
    10,444
    None of that is known to apply to the OP in New Jersey. NJ appears to have a very consumer-friendly net metering system, with production back into the grid credited at full retail price.
  2. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    My information may be specific to Austin, and is second-hand. However, it’s probably fair to say that net-metering, and grid-tying, a system are not synonymous.
    Grid-tying just means that you use power from the utility when you system isn’t producing power, and sell power to the utility when you have surplus.
    Net metering, as far as I know at least, means that the utility tallies up your total usage and charges you, or pays you, for the entire sum usage, positive or negative.
    As I understand it, at least here in Austin, all systems that they subsidize the purchase of (and possibly all systems they allow to be grid-tied; not sure) are grid-tied but not net metered. In return for subsidizing the cost of your system, they pay you less than they charge you. They then offer all in most of their service area a “Green Choice” energy option, which is partly powered from nearby solar.
    Anyway, if the OP’s system is not only grid-tied, but also net-metered as I understand it, then, true, it wouldn’t matter.
    #42 mr88cet, Apr 20, 2019
  3. fuzzy1
    10,444
    OK, this is where the difference lies. Austin doesn't use a standard simple net metering system, but instead created something called VOST, which I haven't adequately digested yet:
    How Does Austin Energy Net Metering Work in 2019? | EnergySage
    In fact, they aren't even the same topic. One refers to the electrical and physical architecture, while the other refers to the financial aspect of energy exchange.
    Grid-tie is simply the opposite of off-grid. The former is electrically connected to the local utility grid, the other is disconnected and isolated. The term says nothing about how energy is bought or sold.
    Net metering is just one of several methods of buying and selling energy between the utility and the grid-tied customer/home-energy-producer. It is generally used in the most PV-friendly areas, while hostile areas generally have other systems. While Austin's system is derived from net metering, apparently the VOST variation makes it different than the common basic net metering systems used in many other places.
    #43 fuzzy1, Apr 20, 2019
  4. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    I know, my point was only that one can't generalize with regard to net metering, there are many different systems.
  5. fuzzy1
    10,444
    The other systems are not simple or basic net metering.
  6. mr88cet
    2,313
    1,335
    Austin, TX
    In short, grid-tying a system doesn’t necessarily imply that it uses net-metering, nor any other particular billing system.
    fuzzy1 likes this.
  7. Mark Schneider
    Mark Schneider Junior Member
    28
    New Jersey
    Enjoyed reading all the replies I wish I had better answers to some of the questions but I believe Net metering is our setup - but on next months bill I’ll find out for sure.
    But to be honest since starting this post I think I will continue to charge daily unless it gets to a point where we aren’t producing enough solar to keep the house 100% green and have to start pulling from the grid.
    But it’s still an interesting thought experiment
    mr88cet likes this.
  8. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    But even if your solar can't keep up with the demand including charging the car, wouldn't you still want to pull from the grid to charge the car and not run the car on gas?
    mr88cet likes this.
  9. mr88cet
    2,313
    1,335
    Austin, TX
    I personally agree that there are other, equally-good reasons, not related to finances, to drive on electric, such as reduced pollution and noise, both for you and the people and other creatures around you. Better responsiveness too.
    However, just for the record, I gather the OP’s concern is not with the capacity of their home-solar, but with the economics of using that power directly vs. selling to the utility.
    jb in NE likes this.
  10. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    I was looking at the 100% green line. But, if the cost to run the car on electric exceeds the cost to run on gas, it's a more complicated decision.
    mr88cet likes this.
  11. bruceha_2000
    3,054
    302
    Northwest VT
    2018 Prius Prime
    I think the OP will find that his wife is incorrect about how much the electric company is paying for their electricity.
  12. Peng Xiao
    Peng Xiao Junior Member
    84
    New Jersey
    2018 Prius Prime
    Base on today's price,
    EV 25 miles need, 6.5 kWh x $0.18/kWh = $1.17
    HV 25 miles need, 25 / (59 mpg) x $2.74/g = $1.16
    JC91006 likes this.
  13. Roy2001
    Roy2001 Active Member
    371
    158
    Sacramento, CA
    For me right now, EV 25 miles need 6.3 kWh x $0.28/kWh = $1.76
    HV 25 miles need, 25 / (55 mpg) x $3.74/g = $1.70
    My electricity price is 22c for tier 1, and 28c for charging vehicle since I used all tier 1 quota. Fortunately I have solar installed.
  14. bruceha_2000
    3,054
    302
    Northwest VT
    2018 Prius Prime
    EV 25 miles need, 6.5 kWh x $0.17/kWh = $1.105
    HV 25 miles need, 25 / (59 mpg) x $2.89/g = $1.225
    But like Roy, my actual electric cost is $0.0 since my solar array produces more than the house uses.
    Prius from Dad likes this.
  15. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Are there no costs of the solar arrays that are being recaptured?
  16. fuzzy1
    10,444
    He is probably counting that as a sunk cost.
  17. bruceha_2000
    3,054
    302
    Northwest VT
    2018 Prius Prime
    Yep. I've paid for them and they are generating more than the house uses. Our net meter credits expire a year from the month they are accrued. The capital cost per kWh generated/used is the same whether I put some in my car or give the utility free electricity. Some places will pay real cash money for excess net metering credits. In that case there would be an opportunity cost to using the extra in the car.
    fuzzy1 and jb in NE like this.
