To EV or Not to EV. That is the question
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Blue-Adept, Apr 1, 2005.
  1. hschuck
    hschuck Member
    385
    bay city, ca
    Beware of the imperial gallon!
  2. Rowan
    Rowan Junior Member
    34
    Carrollton, TX
    <div class='quotetop'>QUOTE(ScubaX\";p=\"81197)</div>
    I see on the stock EV button but do not see the wire harness were did you find that. Also will we still need the EV part from Coastal or does this do the same thing?
    Rowan
  3. ScubaX
    ScubaX Member
    484
    Redding, CA
    The EV switch and wire harness don't acutally come with wires. They come with the switch and the connector piece that the wires go into at the back of the switch. All wires and clips are provided by your favorite Radio Shack dealer.
    You wont need Coastals switch. The install instructions can be found HERE under the Knowledge Base/Other Articles
    I have not installed mine yet. I am waiting for other items that I will install at one time.
  4. AlphaTeam
    AlphaTeam Member
    643
    Earth
    I see that no one has ever had their warranty voided because of an EV switch, BUT has anyone had a battery/electrical problem that was a warranty issue that also HAD an EV switch installed?
    I mean say you got in for a non battery/electrical issue and maybe the tech saw the mod, but didn't give a crap because it could not be the cause of the issue. And that is why they have been overlooked and/or not implicated.
    Just a thought
  5. Steve Goldenberg
    Steve Goldenberg New Member
    126
    Aspen, CO
    It's just not worth the trouble. I used it 2 or 3 times to demo to friends and not once again in the last 6 months.
  6. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    I have to say it is very much worth the trouble. I use mine alot. Coming into a parking lot where I know I'll be under 20 MPH, I just cruise in EV mode.
    Coming home from work at the end of my commute, I turn on EV mode for my sidestreet that is 20 MPH tops, usually much less.
    And moving the car form here to there (out of garage, to the other side of street, etc.) is very cool to NOT have the gas engine fire up.
    No hassles here, but I also did the headlight flasher cheapo version. I'd kinda like the EV light to illuminate and all but I'm totally happy with this version.
    MPG gain? No, none. Or not enough to make a big difference. But, then again, it isn't ALL about MPG. Sometimes the cool factor, the zen that is Prius driving overrules the pocketbook savings or MPG gains.
    My smiles per hour certainly increases when in EV mode (remember those ads from pre-owned Toyotas!) And that alone has a direct and positive benefit, for both me and the people I interact with, IMHO.
  7. Tideland Prius
    16,681
    Not to mention not emitting any emissions on EV mode.
    I know of several occasions when I could've used the EV mode cause I know I will be parking the car soon and don't need the engine to keep itself warm.
    Also, moving the car out of the garage to wash the car is long enough that the engine will turn on before I position the car and turn it off.
  8. NuShrike
    NuShrike Active Member
    1,378
    Has anybody tried just attaching an EV button next to the SKS enable/disable button? Maybe with even a duplicate original toyota SKS button?
    Of course it's harder to reach, but looks easier to get a thread a wire there and to attach a new switch.
  9. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    I thought of that, but as you said, it's harder to reach so I discounted that.
  10. Dr.Jay
    Dr.Jay New Member
    55
    South Jersey
    I'm really curious why the button is not in the US Prius.
    The programming is there and the unused pin receptable is open.
    Just an invitation to add the EV option.
    It would have been an easy matter to by-pass that area of code, so the button would not work if added or fill the pin receptable with a dummy, un-removable plug.
    Be interesting to hear Toyota's answer on this.
    As far as the warranty, is the battery warranty different where the button is standard?
    I use the EV button whenever I start the car, to prevent the ICE from starting.
    As soon as I'm on a straight road, or the SOC is at 4 bars, I step on the accelerator to let the ICE kick in.
  11. Tideland Prius
    16,681
    I think the warranty's the same elsewhere
