To P or not to P
Discussion in 'Gen 4 Prius Main Forum' started by StarmanUK, Dec 19, 2017.
  1. Prodigyplace
    12,720
    11,852
    Central Virginia
    You put your foot back on the brake before shifting out of Park.
    In addition, hill start assist on the Prius keeps the brake on for 2 seconds or until you have pressed the accelerator sufficiently so the car does not roll backward.
    #41 Prodigyplace, Dec 22, 2017
    KV55 and RCO like this.
  2. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    But that would only happen if there is no one stopped behind you, which certainly is a time when you should never put it in park. In fact the UK vehicle code quoted earlier by Colin Jones alludes to this:
    "once the following traffic has stopped, take their foot off the footbrake to deactivate the vehicle brake lights. This will minimise glare to road users behind until the traffic moves again."
    Although I assume that the glare problem that they are trying to solve only occurs at night?
    Well I guess I could be flabbergasted that you are flabbergasted! :) Or I suppose I could be flabbergasted that people prefer to keep their foot pressing firmly on the brake pedal for three minutes when they know they won't be going anywhere, especially in a Prius when it's so easy to put it in Park with a single button push, then back into gear with a flick of the knob, with plenty of time to do so. But I'm not because I understand, most people do what they are used to and/or were taught. Also I suppose for some people that there is more of a feeling of control when holding the vehicle yourself instead of trusting the car to do so.
    It seems that semantics is used as an argument by many, that you should only put it in park when you are parking, as if the name "Park" settles the question indisputably. The same argument was made in another thread by those who felt that you should always engage the parking brake anytime you park, even in your flat enclosed garage, because after all it's called the parking brake so you should use it anytime you park, no matter the circumstances. Well if we get into semantics, to "brake" by definition means to slow a vehicle, or bring it to a stop. Once you are stopped you are no longer braking. So from a semantics argument we should stop using the brake pedal once we are done braking, to do otherwise is to use it for a purpose that it wasn't intended, at least judging by the name. Even though being stopped at a light is not the normal definition of being "parked", you are certainly closer to being parked than braking when you are stopped at a light.
    All in jest of course, to each his own, as long as done safely.
    RCO likes this.
  3. sclevine
    sclevine Active Member
    170
    160
    Northeast Florida
    2024 Prius
    There is one particular case where I actually choose sometimes to put the car in park when stopped at a red light. It is when traffic is very heavily congested and I end up too close to the car in front of me, or too close to a crosswalk with lots of people are crossing just in front of the car, to stop that infernal loud beeping that won't stop until car in front moves or people stop crossing. Granted, that might not be a condition many of you face, but I live in New York City, so heavy and sometimes gridlock traffic conditions is part of the experience, and getting too close to your neighbors happens quite a bit.
    As an aside, regarding that safety beeping feature, it is important and should be there and therefore I leave the feature on, but I wish it would not beep if car is not moving and foot is on the brake.
    RCO likes this.
  4. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    My Prius does not have park distance control (PDC), but my other car with it has a button to disable it when necessary. Maybe Prius does not have a disable switch?
    RCO likes this.
  5. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I think mine does too. I'll check..
  6. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Can be disabled through the menus IIRC.
    RCO likes this.
