To plug-in or not to plug-in...
Discussion in 'Prime Technical Discussion' started by SweetPriusBro, Jan 7, 2018.
  1. SweetPriusBro
    SweetPriusBro Junior Member
    Vacaville, California
    that is my stupid question. I purchased my Prime yesterday so please forgive me for such a seemingly ignorant question. My rate per kWh is $0.26 so I will be paying $2.28 to go 25 Miles. Gas in California is $3.30. I went on a 350 mile road trip today and averaged 64mpg. So 64 Miles for $3.30 or $2.38 for 25 Miles? Why would I ever plug in at home?
    Stupid question part II: does it really take 8.8 kWh to charge a 8.8kWh battery? There has to be some % lost as heat with that brick converter.
  2. Ferrarilover
    Ferrarilover Active Member
    185
    168
    Manchester, UK
    I think it’s 6.6kw that will take you 25 miles. The 8.8 is never filled or depleted.
    iPhone ?
  3. Tideland Prius
    16,681
    It's about 6.1-6.3kWh on the electricity meter (5.7-5.9kWh true)
    52,863
    welcome!
    there's a 10-15% loss in the charging process.
    i pay 24 cents/kwh, and only charge for funsies. gas is much cheaper. sometimes, i wonder why i bought a plug in, it cost me a fortune.
  5. CharlesH
    2,798
    1,166
    Roseville, CA
    What does "true" mean in this context? Is there an issue of power factor here (so Volts times Amps does not equal Watts)?
  6. padroo
    padroo Senior Member
    2,763
    2,253
    Look at the bright side of it, you are saving the planet by not polluting when in electric. Just kidding but I have wondered how may people have bought their Prime strictly to save money or are there really any tree huggers out there.
    I grew up in a polluted area outside of Pittsburgh, Pa. My dad was a steelworker so what do I do, move to Indiana and work in another dirty steel mill. I was lucky to get out of the mill with my health. I really do like the idea of cleaning up the air but I do not consider myself a tree hugger.
  7. bisco
    52,863
    i like trees. and my chainsaw.:sneaky:
  8. SweetPriusBro
    Thanks for the great info guys. I still get to charge at work for free. There are also about a dozen free charging spots within a couple miles of my house. Therefore I’m still hoping to mostly use EV mode. On my first day I got 27 Miles in pure EV mode!
    jerrymildred likes this.
  9. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    that IS the question:confused:
  10. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    Is your chainsaw gas or electric? Or is it a cordless plug-in?
    bisco and priuscatprimeguy like this.
  11. fuzzy1
    10,713
    Is this your only choice, or does your utility have other rate plan choices available for EV charging?
    Figured how?
  12. Tideland Prius
    16,681
    Oops, my true kWh might be a bit high (probably closer to the low 5s).
    I mean that the actual battery range is worth about 5kWh (even though your power meter will show 6.1-6.3kWh because of the losses as electricity flows through the charging cable and converted from AC to DC)
    priuscatprimeguy and CharlesH like this.
  13. bisco
    52,863
    that's mine! except i have the old blue one. you wouldn't believe the trees i'e cut down with that little thing. and the chain only turns about 7 rpm.:p
  14. priuscatprimeguy
    2,730
    2,640
    wait'll the tree huggers get wind of what you're doing:mad::p
  15. bisco
    52,863
    they can hug them horizontally, before they go into the fire.:cool:
    #15 bisco, Jan 8, 2018
    priuscatprimeguy likes this.
  16. priuscatprimeguy
    2,730
    2,640
    :eek::eek::eek::eek::eek::eek:
  17. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Putting 6.3kWh in from the wall results in about 5.7kWh of battery energy returned.
    Tideland Prius likes this.
  18. Tideland Prius
    16,681
    Thanks!
  19. pyramidbuilder
    pyramidbuilder New Member
    Novato, CA
    After reading your post, I did my own calculations for my own energy costs. Gas powered, I pay $.05 per mile. On EV, it's $.07 per mile. So, plug in is more expensive. The only advantage for me now is it's free for me to charge at work.
  20. ct89
    ct89 Active Member
    323
    266
    New England
    HV - $0.05 per mile is about $3.00 per gallon if you get 60 miles per gallon....Yup, that sounds about right
    EV - $0.07 per mile would translate to $0.33/KWh if you get 30 miles on a 6.3KWh charge...That's a pretty expensive electric rate
    pyramidbuilder likes this.
