To Wheel Cover, or Not to Wheel Cover...
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Chachabah16, Aug 13, 2011.
  1. J5A
    J5A Active Member
    592
    83
    Severna Park, MD
    PM sent :)
    BTW, Congrats on your new 2011.
    For the Gen III, I prefer the look of the thicker spokes on the plastic cover as opposed to the smaller looking alloy. I hate that they're plastic, but they remain.
  2. macmaster05
    macmaster05 Senor Member
    4,050
    730
    I'm with 32k and J5A. The alloys under the covers on the Gen III just don't look right.
    The 16" Touring rims from Gen II are in a class of their own. Possibly the best move Toyota last made in the wheels category. 7 spoke gunmetal rims at 15.2 lbs each. They don't compare to anything that isn't aftermarket.
    You can keep debating which way the 15" wheel looks better - covers on or off. Quite frankly I feel sorry for all of you w/o these 16" rims, that even includes you guys with the 17" V wheels, which I think weighs in at 22 lbs.
  3. Insight-I Owner
    Insight-I Owner 2006 Insight-I MT + 2011 Prius
    505
    100
    Essex, CT
    No worries, save your pity. I'll take better mpg and so-so wheels any day!!
  4. macmaster05
    4,050
    730
    Lol bro, you're not even right.
    Gen II
    15": 14.3 lbs
    16": 15.2 lbs
    Gen III
    15": 16.3 lbs
    17": 24.2 lbs
    So I'm getting better mpg (in theory) and better looks. If the hypermilers here had brains (and money to waste haha) they'd be snapping up Gen II wheels, realizing they are actually more of an engineering feat.
  5. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    That's not correct either. Weight is not a big factor in fuel efficiency. Rather, it affects acceleration/deceleration to a much larger degree. Increased rolling resistance (caused by larger wheels especially with wider tires) plays a much bigger role than unsprung weight in mpg hit.
  6. macmaster05
    4,050
    730
    I thought I covered my nice person with the "(in theory)" bit. :rolleyes:
  7. Insight-I Owner
    505
    100
    Essex, CT
    Sorry, I was unclear. I've never driven Gen II, but from what I read here and from the EPA ratings I gather the Gen III's are good for a few more mpg than the Gen II's.
    So to restate, I'll happily accept the Gen III with its so-so, slightly heavier wheels to get more mpg than I could get in a Gen II. I bought the car for fuel economy, definitely not for aesthetics. But yes the Gen II 15" wheels would be even better if they would fit?
    (FWIW, The Insight-I OEM tires weigh 11 lbs and the wheels weigh an additional 11lbs)
  8. macmaster05
    4,050
    730
    Gotcha. Yeah the Gen III is a newer, better car than Gen II, so better overall mileage for sure. I don't know how it works, I'm not a tech guy, but something about Hybrid Synergy Drive is improved.
    (Yes Gen II wheels fit Gen III.)
  9. Tideland Prius
    16,539
    Yeah but the Gen 2's 16" alloys have the same width as our Gen 3's 15" so it's more of the larger tyre than the increased width.
  10. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    True, so the larger tire might cancel out the lighter weight of the Gen II's 16" alloys compared to Gen III's 15". Weight isn't everything.
  11. Insight-I Owner
    505
    100
    Essex, CT
    Exactly. In terms of rotational inertia, mass further from the axis of rotation (the axle) has a bigger effect because the mass is multiplied by its distance from the axis. So a lighter tire has more effect than a lighter wheel (of course it's best to have both as light as possible).
    Given that the overall diameter of the wheel/tire assembly is the same, what we are doing is changing the mass distribution between the wheel and the tire, and maybe changing total mass as well.
    If you do a lot of accelerating and decelerating, changes in rotational inertia will have an effect. One of the goals of hypermiling is to minimize unnecessary/random speed changes.
    Wider tires may have increased rolling resistance, depending on which tires are being compared. Unfortunately the current "LRR" designation has about as much meaning as "free range chicken" as far as I can see.
    A wider tire will also increase wind drag of the tires. Probably a small effect but maybe detectable.
  12. mmcdonal
    mmcdonal Active Member
    666
    98
    16
    Columbia MD
    Another affect of greater wheel weight is the force needed to turn the wheel at speed. I think lighter wheels are an issue for road racers, mostly.
    That being said, I have mine off since the plastic ones chip and fray around the edges if you just look at them funny. Without hitting any curbs (so they might have been delivered that way) mine were all breaking around the edges, so I took them off.
    I think any mileage savings from the plastic uglifiers is in the nature of a hillbilly "go-faster" as we used to say in the trade, when people put all sorts of uglifiers on their cars to make them look faster. Just a placebo.
  13. Tideland Prius
    16,539
    Hmm.. more importantly.. how did the Gen 3's alloy gain 2 lbs?? You'd think by going with twin spoke instead of a large spoke (as it was on the Gen 2), they'd save some weight.
  14. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Maybe they've determined that the wide spokes provide less side aero drag in wind tunnel testing and decided to go with that, thereby canceling out the slight weight gain in terms of mpg hit.
  15. Tideland Prius
    16,539
    The wide 5-spoke was on the Gen 2. Ours is a twin-spoke design (still 5 spokes). Maybe it's a bit wider?
  16. xamnosidda
    xamnosidda Junior Member
    61
    Celebration, FL
    But is it the weight of the wheel or the width of the tire that effects MPG? I hate the 15" OEMs on my 2010 II. If upgrading to 17" yields a 0-5 mpg hit, I don't mind. I was getting 20 mpg on the highway with my Xterra. Anything above 30 mpg and I am in heaven.
  17. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    It is primarily the rolling resistance of the tire. The weight doesn't amount too much. Worst case it's the equivalent of adding twice that weight to the inside of your car.
  18. Chachabah16
    Chachabah16 Junior Member
    35
    Island Park, NY
    I don't know a whole lot about this tech stuff, but, the 15" wheels do look smaller with the uglifiers off. Too much so. No choice is ideal. The lesser of two evils for me, at the moment, is with the caps off. I reserve the right to change my mind!
    v ~
  19. green4u
    green4u New Member
    115
    CA
    What I've noticed is that the 15" wheels look better with covers off when rolling, but better with wheel covers standing still.
  20. Chachabah16
    35
    Island Park, NY
    That is a good observation!
