TOD...Triangle of death...(sigh)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bshef, Nov 4, 2016.
  1. bshef
    bshef Active Member
    510
    76
    OC So. Calif.
    oh crap.....Here we go.
    All warning lights appeared yesterday.
    I added oil (it was low..I have 155k miles on car). however, this did not clear the warning lights.
    Drove her into work this morning (40 miles). SOC worked well without incident. Car appeared to operate fine.
    I do not have a reader and have no established relationship with any dealers.
    Anyone suggest somewhere I can take my vehicle to get it checked out?
    I'm in Pomona for work today.....than travel back home to OC (HB specifically) for weekend.
    Thank you!
  2. JC91006
    16,936
    8,647
    How much oil did you have to add?
    You would need to get the codes read, it could be something fairly minor like a failed inverter pump to something major like a failed hybrid battery
    bshef likes this.
  3. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    You can try for assist from Toyota USA on cost reduction for new batt, if it comes down to that. But you'd have to get the codes read by Toyota, and negotiate a little ...takes a little while for them to respond. You're over 10-yr warranty but you're in CA so that's a plus possibly worth a try.
    bshef likes this.
  4. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    If you're a DIYer, you could stop in a local auto shop parts store and have your OBD codes read. Most places will read the codes for free and then you can google to see what needs to be fixed.
    If I was on the road with the same problems I'd take the car either to 1 - A hybrid specialty repair shop (google hybrid repairs in google maps, etc.) or 2 - A Toyota dealership. Most local auto shops aren't specialized in Prii, and therefore are more likely to make mistakes when repairing and leave you stranded longer.
    bshef likes this.
  5. bshef
    bshef Active Member
    510
    76
    OC So. Calif.
    Thanks Fella's.....
    JC....added just over 1 quart. All freeway driving. I did the inverter coolant change @ 100k. Also had performed cleaning of the cooling fan around the same period.
    WJTracy....thanks.....yes....I read the post that mentioned Toy USA helped our one member with his battery replacement at $200 so that's definitely on my radar.
    Kevin....Yeah, have read mixed reviews about local parts shops ability to read codes. I'll try and get out at lunch time here near my work and see what's available.
    Robert Holt likes this.
  6. b100
    b100 Member
    145
    75
    Netherlands
    First thing to do, get the codes read.
    bshef likes this.
  7. Mendel Leisk
    42,358
    Dealership would read the codes for maybe $50~75. Likely they're the only ones that would get everything; other places with generic readers are not as successful? And best informed to propose a course of action.
    bshef likes this.
  8. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    Your oil was low enough that it might have been the cause of your warning lights.
    bshef likes this.
  9. Mendel Leisk
    42,358
    From what I've heard here, by the time you get a low oil pressure warning light you're crazy low, virtually no oil. The distance between the two marks on the dipstick is something like 1.5 quarts, and I believe Toyota says anywhere in that zone is within spec.
  10. bshef
    bshef Active Member
    510
    76
    OC So. Calif.
    Thanks Don....Yes, that was my hope...however, having now added oil....would that automatically clear the codes?
    Low oil indicator - I never got any low oil indicator.....straight to red triangle
  11. DonDNH
    1,711
    655
    Nashua, NH
    Four Touring
    I don't know if the warning lights will clear themselves with time. You could clear them by disconnecting the 12V battery for a minute which will clear nearly all codes. If there are serious other problems, the lights will return.
    bshef likes this.
  12. bshef
    bshef Active Member
    510
    76
    OC So. Calif.
    ........P0A80.......
    amazing...i'm at 156k and just over 10 years......(sigh)
  13. Tideland Prius
    16,683
    Sorry to hear that.
    That's about the same as our 2005 Prius (245,000km and 11.5 years). It spit out that code back in February.
    bshef likes this.
  14. bshef
    bshef Active Member
    510
    76
    OC So. Calif.
    So.....did you abandon the 05 and purchase the 2010 at that point?
  15. Tideland Prius
    16,683
    We put the cost of the battery replacement (CAD$3,000 incl. taxes and labour) towards the purchase of a 2016. We had to wait a month since the Canadian launch was in March.
    The 2010 was bought in 2009. It currently has 125,000km on it.
  16. bshef
    bshef Active Member
    510
    76
    OC So. Calif.
    So.....how do we figure the value of a 2005 Prius with a dead hybrid battery?
    It may be time to trade up!
    #16 bshef, Nov 4, 2016
  17. JC91006
    16,936
    8,647
    If you have the time, I can check the car for you. I'm 20 minutes west of Pomona.
    Send me a pm if you want
    bshef likes this.
  18. bshef
    bshef Active Member
    510
    76
    OC So. Calif.
    I'm heading back to hb now.....I have some decisions to make
    SM-N910V ?
  19. Tideland Prius
    16,683
    Best guess would be to determine what your 2005 would've sold for with that mileage in your area and then subtract the estimated cost to replace the battery.
    bshef likes this.
  20. bshef
    bshef Active Member
    510
    76
    OC So. Calif.
    Thanks Tideland....
    I'm going to get there battery replaced. Just need to figure new from dealer or refurbished.
    Thanked
    SM-N910V ?
