Today's Adventure
Discussion in 'Newbie Forum' started by Spcalan1, May 24, 2011.
  1. bisco
    52,855
    discharging the 12v is never good, but not necessarily cause for replacement. it's never a bad idea on a 5 year old car. it has nothing to do with your mileage which we don't know yet. ( you can't tell by the pips.) just that it was discharged on the lot. if it goes dead, you can be stranded. and you're going to need one sooner than later. so, for a couple hundred bucks, many here advise replacement now. i think you got a great car at a great price, all the best!
  2. Spcalan1
    Spcalan1 New Member
    104
    Flowery Branch, GA
    Ok. Thanks for the heads up.
    is there a way to 'test' the battery to see if it needs replacing?
  3. Tideland Prius
    16,680
  4. Spcalan1
    Spcalan1 New Member
    104
    Flowery Branch, GA
    hmm, sounds good. I was thinking that maybe the car's display may show the current voltage...
    now, if I can just figure out where the 12v is located ( just kidding )...
  5. Tideland Prius
    16,680
    Yeah but that would mean that the car is on. That wouldn't necessarily give you an idea that the battery needs replacement. I suspected ours needed replacement about 3 years ago (we did kill it twice.. or maybe 3 times) but when I took it to the dealer, they said it was fine and even showed me the printout that said OK on it. The issue wasn't that the battery wasn't charging. It was that it wasn't holding a charge after the car turns off. They were testing it while the car was on so of course the battery was fine (and it was fine if the car is on. The headlights are at full power and the radio works) but turn it off and 2-4 seconds later, you'll see the headlights start to dim and the headlight indicator light on the dash start to fade. Occasionally, I would get a warning message to put the car in Park.
  6. Spcalan1
    Spcalan1 New Member
    104
    Flowery Branch, GA
    Maybe this sat and sun I will use a volt meter to see if it is holding its charge.
    So far so good with the everything in the car.
  7. pfjmarina
    pfjmarina Junior Member
    46
    Marina, CA
    2006 is a Gen II if I'm not mistaken. Check out the Gen II Technical discussion forum. I seem to recall something on there about a method to display battery voltage in some sort of "maintenance mode" that you could get into by pressing various buttons in the correct sequence. Sorry not to be more specific, but the info. didn't apply to Gen III (which is what I have) so I was just skimming. I have a new 2011 which was just purchased a month ago. It's my first Prius so I've been pouring over the forums alot trying to learn about this great new car!
  8. Spcalan1
    Spcalan1 New Member
    104
    Flowery Branch, GA
  9. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Exactly! A 5 year old OEM 12 volt is likely on its last legs. My 12 volt on my 06 bought as new in 1/06 was starting to get marginal around 1/2011 or 2/2011 (reading ~11.8 volts after sitting overnight). I replaced it w/the Optima D51 w/kit from elearnaid.
    I'd never killed my 12 volt even once.
    Check the above again after the car has sat for many hours. Overnight is even better.
  10. Spcalan1
    Spcalan1 New Member
    104
    Flowery Branch, GA
    Will do... I will report back.
