Toll transponder placement - 2023 Prius
Discussion in 'Gen 5 Prius Main Forum' started by PriusPrimetime, Jul 24, 2023.
  1. PriusPrimetime
    71
    59
    FL
    2023 Prius Prime
    XSE
    Has anyone run into any issues placing a toll transponder (EZpass, SunPass, etc) behind the black dots that surround the rearview mirror? I have placed mine on those dots, to the right of the mirror (out of view of the driver) vertically and not horizontally.
    52,819
    Mine is there and works fine
    PriusPrimetime likes this.
  3. flarecde
    flarecde Member
    59
    68
    NY
    2023 Prius
    Limited AWD-e
    Mine is also there and does not have an issue.
  4. GeoJ
    GeoJ Active Member
    225
    203
    United States
    I did not realize the transponder could be placed on those dots. I had planned to put the transponder on the dash, behind the entertainment screen where it doesn't block any of the view and can't be seen by driver or passenger. Still testing whether it works there, but I can't see why it would not. I guess if you can place on the black dots surrounding the mirror that may be as good, or better.
  5. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    I used to put it on the front window. But as it turned out, it works fine just keeping it in the glove box in front of the passenger seat. No messing with adhesives.
  6. RRxing
    RRxing Senior Member
    2,563
    1,842
    NEPA
    Pennsylvania EZ-Pass transponders use suction cups instead of adhesives. I placed mine just below the frit behind the rear view mirror.
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Those black dots are just "paint". They do not block RF.
  8. GeoJ
    GeoJ Active Member
    225
    203
    United States
    I like that the best, if it works. Going to try it.
  9. GeoJ
    GeoJ Active Member
    225
    203
    United States
    So if they are "paint" do they serve any functional purpose?
  10. sam spade 2
    7,035
    2,804
    2017 Prius c
    A slight sun screen. Mostly useless.
  11. RRxing
    2,563
    1,842
    NEPA
  12. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
  13. tovli
    tovli 2023 Prius Prime replaced 09 Prius
    354
    277
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    I couldn't get it to stick there so put it here:
