tonneau cover discoloration (pictures)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Former Member 68813, Nov 21, 2011.
  1. Former Member 68813
    3,524
    983
    US
    I had my Prius for a year with only 11,600 miles. Despite only rare use of tonneau cover, a discoloration developed. I tried to clean, but it looks like grease embedded in the fabric.
    Has anyone had anything like this? Is this a warranty issue or wear and tear?
    Thanks!
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Take it back to the dealer and let them look at it. It looks like warranty replacement to me unless they can clean it for you.
  3. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Mine is the same way in the same place, showed up after about 2 years. I don't know the cause but I haven't been able to wash it off either, if you find a way let me know.
  4. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    mine too...
  5. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Mine has the same mark just not as pronounced, I have not tried to clean it yet though.
  6. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Mine has a very small square mark just as the cover comes out of the retractable frame. This mark is not nearly as long as the one shown in the photo.
    I use mine quite often as I keep my golf clubs in the back most of the time and keep the cover pulled over them. How often do those with the long mark use their covers?
  7. RRxing
    RRxing Senior Member
    2,563
    1,842
    NEPA
    I always keep it extended unless the cargo prevents it. I, too, have the skid mark down the center of the cover.
  8. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    I just checked mine on my 2 year and 4 month old 2010 and no stain mark. I do see a slight glossiness mark about an inch wide up the center that looks like there is a wheel in the roll up mechanism causing the glossy mark that may be staining some of them. I don't use mine much, as in probably less than a dozen times a year.
  9. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Nope, haven't ever seen that before. But I can recommend Woolite "Oxy Deep" spray for cleaning unusual stains.
  10. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    1.) Maybe we can prevent some future discoloration with a vinyl cleaner protection treatment. Something like 303 Aerospace protectant that has Lasting UV-Screening Protection.
    2.) Also that mark from the wheel that might be deteriorating and getting softer/harder or excess grease moving off the wheel onto the material.
    3.) Someone can dye the whole thing a new darker color. (ha)
    my2cents.
  11. tumbleweed
    4,067
    692
    Eastern Oregon
    Yes, the marks will come off. I removed them this afternoon using 409 cleaner and a clean rag. Put one hand under the cover, or better yet remove the cover from the car and put it on a hard surface. Then spray the cleaner on and rub real hard. Looks as good as new.
