Tonneau Cover for 2016 Prius??
Discussion in 'Gen 4 Prius Accessories and Modifications' started by max2prius, Jul 12, 2016.
  1. Wirt
    Wirt New Member
    I just did this on my 3 Touring this weekend.
    How do you remove the two T-hooks in the back closest to the seats?
  2. Tideland Prius
    16,683
    I’m not sure since I’ve never done it. I thought it might be as simple as inserting a flat blade screwdriver or similar tool and pry it out from behind.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Look closely at the bottom of the T-hook. There is a little opening. Insert something small and pointy and push the tab that's in there toward the center of the T-hook and then pull the hook out by rocking it away from the little opening. Comes right out.
    PS sorry for the blurry picture. Looks like I was a little too close with the phone, but I'm sure you get the idea.
    jwhite518, krmcg and Tideland Prius like this.
  4. Wirt
    Wirt New Member
    Thanks for the quick response, worked perfectly.
    krmcg and jerrymildred like this.
  5. Jontol
    Jontol New Member
    Toledo, Ohio
    I bought used 2016 prius and am looking to buy the rollout tonneau cover if anyone doesn't use theirs.
