Tony's EBH Thread
Discussion in 'Gen 2 Prius Accessories & Modifications' started by TonyPSchaefer, Jul 27, 2009.
  1. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    I get to S4 almost immediately compared to before. Like I said, there's a stoplight about 0.2 miles from my house. It's magnetically triggered and biased to cross-traffic. Previously, I would sit there and idle or shut down. Now I go into S4 when I come to a stop.
    From that point (for the rest of the initial 5 minutes), it's 40-45 mph speed limits. I can stealth and glide easier than I previously could but still can't account for the consistent 25mpg first segment.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Can you keep your speed under 40mph in that 40-45mph zone? If you're getting to S4 that quickly and can keep your speed a tad lower you should be able to get better MPG. With a similar route I often see 50-75mpg in the first 5 min on roads that are certainly a lot steeper.
  3. TonyPSchaefer
    14,816
    2,501
    66
    I try to keep it under 40 but I'm very aware of surrounding traffic. Even though there are two lanes traveling in both directions, I try to not be an obstruction.
    Here's one that's bugged me for a while.
    Often, after ascending a hill, I can not stealth at speeds less than 40 mph. I glide down the hill, sometimes accelerating >40 mph then use the gas to maintain speed up the other side. Once I crest the hill, Priapus will not stealth. Too fast for the EV button (I always average 35 - 40 mph at that spot). This will last for the entire plateau until I go downhill again.
  4. TheForce
    3,461
    537
    Wheelersburg, Ohio
    This is where a scangauge comes in handy. If your coolant temp reaches 176F I think the engine stays on to get the coolant flowing through the system or something like that. It takes about a minute to get through that.
  5. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    An alternative explanation is that the battery SOC is too low. I think that is what happens to me sometimes, even though the MFD display doesn't show it (immediately).
    Try going up the hill with a bit more pedal next time.
