Took v on camping trip :-)
Discussion in 'Prius v Main Forum' started by Rh0, May 30, 2012.
  1. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    In ODO mode, the average display includes all time since you last re-set. To re-set, open the info display and navigate to the fuel history screen. There you can reset the current memory, or erase all memory. It holds 6 resets, represented by the vertical bars. I reset this at every fill-up. Of course you also have 2 trip meters which can be used in the same way. The average MPG display relates to the trip meter you have showing.
  2. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    Since I've adopted the habit of pumping gas until it clicks off, the trip computer mileage is extremely close to the manual calcs.
