Took v over scale.
Discussion in 'Prius v Main Forum' started by schmuly, Jun 3, 2013.
  1. schmuly
    schmuly Member
    209
    51
    BC
    I drove our v over the Gov scale to see the weight here is what I found.
    Front axle... 950 kg.........2090 lbs
    rear axle......660 kg..........1452 lbs
    That was with 3/4 tank of gas and only me in drivers seat and seat slid back.
    That shows the v is front heavy by axle, I did not check each tire weight side to side. Next time I will get each individual tire to see how the car is balanced (or unbalanced)
    I am thinking if weight is off side to side the tire pressure could be adjusted for each tire for best handleing and gas milage.
    woppa likes this.
  2. CLUBGUY
    CLUBGUY Member
    293
    49
    Cincinnati
    Interesting...thanks for sharing..
  3. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    Is the total weight of the car the combo of the two weights? 3542 lbs?
  4. Tideland Prius
    16,073
    Makes sense. Weight is approximately 60/40% front/rear.
  5. Tideland Prius
    16,073
    Well the v is rated at 3273lbs so it's a difference of 269lbs. I don't think the OP weighs that much so I'm guessing there's a bit of overlap where the weighting is involved.
  6. Lee Bridges
    Lee Bridges Junior Member
    44
    Indialantic, FL
    2013 Prius v wagon
    Yes. I assume the weight difference from spec is due to the OP's weight, vehicle fluids, misc stuff like carpet mats, etc.
  7. skwcrj
    skwcrj Member
    278
    68
    Gig Harbor, WA
    Q: Does the vehicle weight listed on the official specs include fuel? I can see oil, coolant, and other fluids that don't change as you drive.
  8. Lee Bridges
    44
    Indialantic, FL
    2013 Prius v wagon
    The curb weight is the amount it weighs when it is parked and empty. Passengers, cargo, fluids, and other items are not included in this weight.
  9. schmuly
    schmuly Member
    209
    51
    BC
    Aaaah you caught me, I am over weight
  10. schmuly
    schmuly Member
    209
    51
    BC
    Had a chance to go over the scale again,
    With my wife and two golden retrievers in the back...no the wife was in the pass seat.
    Front total 2156lbs lf 1076lbs rf 1080lbs.
    Total rear 1650lbs lr924lbs rr726lbs
    So the front is almost equal side to side, but the drivers left rear is a little heavier compaired to the right
    I am not sure where my two dogs were laying in relationship the weight.
    Oh yea I also had a full tank of gas this time.
  11. Tideland Prius
    16,073
    I believe the curb weight does include fluids and a full tank of fuel.
  12. sURFNmADNESS
    sURFNmADNESS Prii Family
    199
    48
    Omaha, NE
  13. skwcrj
    skwcrj Member
    278
    68
    Gig Harbor, WA
    Thanks guys.
