Tools for 3rg gen Prius.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by saltdiscus, Dec 22, 2016.
  1. saltdiscus
    saltdiscus Member
    198
    89
    US
    Hi
    Thinking of doing my own oil change.what do u need ?I have 1/2 inch torque and impact driver 18volt.So is jack stand or car ramp good option? I won't be doing any tire work so leaning towards car ramp for easy installation. Do I need anything else beside oil and filter.
  2. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    Pan plug is 14mm
    Keep the car level....especially when filling.
    You will need oil, filter, filter O-ring,filter removal tool,and plug gasket.
    Strong hand tighten everything.
  3. saltdiscus
    saltdiscus Member
    198
    89
    US
  4. Jimi1976
    242
    124
    Denver, CO
    Keep it level.
  5. Mendel Leisk
    42,208
    The oil filter socket requires a 14-face socket with 64 mm inside face-to-face dimension.
    Torque specs:
    Oil pan drain bolt: 27 (ft/lb)
    Filter: 18
    (the Toyota filter comes comeplete with replacement O-Ring)
    There's no need to keep the car level during the drain. I would just button up, lower the car, and put in the spec'd quantity of oil.
    When checking oil level, then obviously it's best if the car's level. it's best to remove the dipstick, wipe it, and wait a few minutes before reinserting for the check. Oil tends to hang in the dipstick tube, the wait gives it time to drain down.
  6. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
  7. saltdiscus
    saltdiscus Member
    198
    89
    US
  8. Rebound
    3,996
    2,645
    Portland, OR
    It's my mission in life to talk you into changing your transmission fluid, your air filter, and lubricating your brake caliper pins. Come on, join the club!
    With that said:
    If you have a decent cement garage or flat driveway area, I think jack + jack stands are better than ramps for several reasons:
    1) More versatile; more types of repairs can be made (like fix a flat tire).
    2) Driving up ramps takes a second person
    3) Prius bumper scrapes ramp as you ascend
    4) Take up a ton of garage space
    I've had cheap floor jack, then ramps, and now pro floor jack. The ramps are pretty "meh," but some prefer them and that's cool.
    For tools, you can see the minimum but I recommend a Sears Craftsman set priced on sale at about $100. Get one that comes in a fitted case, so when you're done, you can quickly tell if you've got all your sockets. I'd be happy to help you pick out a set that's on sale and appropriate. There are other miscellaneous tools you'll need, namely the oil filter wrench, big funnel, nitrile gloves and drain pan.
    #8 Rebound, Dec 27, 2016
    Apl420 likes this.
