Tools for diagnosing Generation 2 ?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by John Casteel, Mar 9, 2017.
  1. John Casteel
    John Casteel Junior Member
    22
    Savannah, ga
    TMR-JWAP do you have a write up on what you did. How you are cycling / monitoring. How do the Gen 3 modules compare in price to Gen 2?
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    John, I have a bench set up just for testing and cycling these modules, I keep the modules compressed in the OEM racks. I have racks for 38 module, 28 module and 20 module setups. I have (3) HiTec X4 AC+ charge/dischargers and a TENMA 300W electronic programmable DC load tester.
    First thing I do is record all the serial numbers and the voltage for each module.
    My methodology:
    1. I orient all the modules so the (+) terminals are on one side and all the (-) terminals are on the other. This helps prevent accidental reverse polarity connections and accidental short circuits between terminals. Safety First.
    2. The rack is placed on spacers (3 sides) to lift it about an inch above the work bench. I have a 120v fan rig that blows air under the rack and the air then flows between each module to prevent any heat issues.
    3. I currently have the HiTecs set up for 5 cycles. This is just personal preference based on experience.
    4. I connect the Hitecs to every other module starting with 1,3,5,7,9,11,13,15,17,19,21,23
    5. After those are complete, all data is recorded and I connect to 6,8,10,12,14,16,18,20,22,24,26,28
    6. After those are complete, all data is recorded and I connect to 2,4,25,27 and any others if I want more info.
    7. After all modules are done, I let it sit for two days to let voltages stabilize. I then disassemble the rack to move any failed/marginal modules to one end of the rack. Then clamp it back together. I install a heavy copper wire across the (+) terminals and another one across the (-) terminals to allow the voltages to equalize for a day. The failed/marginal modules are not connected to the copper wires.
    8. After a day of equalization, the copper wires are removed and the modules are allowed to sit for a week or two. Voltages are checked again to look for any significant change. This is an easy way to check for abnormal self discharge.
    9. Now they can be individually load tested using the TENMA.
    For those of us who have a Gen 2 and need battery repairs, I am a BIG proponent of purchasing a battery from a wrecked GEN 3 and just doing a full swap of the modules. If you happen to get a 2014 or 2015 model, there's no need to even perform any significant testing or balancing. If you do end up just replacing the marginal modules, Gen 2 or 3 will work fine, as long as module quality has been verified.
    A few years ago, I had a 2005 that had a failed battery at 235,000 miles. We swapped one obviously bad module with no further testing and put another 30,000 miles on it with no problems. We decided to let my son have the car, so I purchased (2) 2013 Prius C batteries from a salvage yard. We installed 28 of those modules into his battery and it's been going strong ever since. The old battery sat in the garage for over a year, untouched until I bought another 2005 with 260,000 miles and a failed battery. We took the one out of the garage and put it in with no testing. Fired right up. I bought a 2015 battery with intentions of eventually swapping those modules, but car got wrecked. Very recently bought a 2007 Touring model with a bad battery. Had a set of 2011 modules on the shelf, already cycled and tested, so I installed those and now the 2007 is killing it with a first tank average of 49.3 mpg.
    With what I know now from the testing I've done on hundreds and hundreds of modules, I was extremely lucky with my early module swaps. An example is the 2007 battery I just replaced. The initial discharge values for each module were crazy. There were three modules that were obvious suspects with voltages less than 7.2 Their capacities measured 3, 109 and 300. The remaining 25 modules had voltages from 7.54 to 7.76 Sounds good, right? This is exactly why voltage cannot be used as a sole indicator of good or bad. Initial discharge capacity of those 25 modules ranged from 711 to 4172, with 10 less than 2000mah. The 711mah module measured 7.54 volts. Modules like that are sold every day on ebay. That was the condition of the battery within a week from being removed from the car. Following cycling/testing of the 28 modules, 5 were less than 6200 mah (lowest was 5974 mah) the rest were 6200-6545mah. The obvious bad module maxed at 2013 mah even after 5 cycles. Even the other 2 marginal ones recovered >6000, but probably have internal self discharge problems.
  3. John Casteel
    22
    Savannah, ga
    Thank you TMR-JWAP. I just got off work and I'll have to read through that message 2 or 3 times. I'm currently waiting on mini-vci and I still have to find a computer. I hope to start running diagnostics next week. I'll follow up as I learn what is going wrong.
    So as I quickly read your email it seems best to find a 2014 - 2015 battery and swap modules into my Gen 2 carrier. Does it take only 1 Gen 3 battery and is it simply remove and refit onto older carrier? There are no modification required to the modules?
  4. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    That is correct. The modules are identical except the Gen 3 supposedly has a slightly lower internal resistance which allows it to have a slightly higher max amperage discharge capacity. I'm pretty certain the max discharge is controlled by the CPU, so our Gen 2's wouldn't know the difference between Gen 2 or Gen 3 modules, but a Gen 3 may not like having a Gen 2 module.
    The 28 modules are clamped between two fiberglass/plastic plates. The Gen 2 and Gen 3 use the same style clamps except the Gen 3 has an additional tab on top for holding wires. I removed the Gen 3 modules from the 2011 clamps and installed them into the 2007 clamps just to keep it OEM as much as possible.
    Just take a bunch of photos as you're disassembling so you have something to reference during assembly. Definitely want to have the battery module polarities correct.
    I've had excellent results from most Gen 3 batteries. I actually have (6) 2013 modules (manufactured in July 2013) that I'm cycling right now with some other random leftovers. I caught one of them during it's rest period between cycles and it was showing 6700+ mah from that discharge.
    I'll look around at some of my previous sources and see if I can find something in GA that might interest you..
  5. John Casteel
    22
    Savannah, ga
    I was able to resurrect one of my old laptops so now I'm waiting on mini vci to come in. I doubt I'll have time to mess with anything until after the 22nd of March. Take care. TMR-JWAP there is a gen 3 battery for sale in jacksonville but I'm going to go through the diagnosis process first. The way my luck has been running I might actually get lucky and be able to fix this without the battery.
  6. oil_burner
    oil_burner Active Member
    249
    126
    where do you buy your batteries? Junkyards?
  7. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    I keep my eyes open to all opportunities. Salvage yards, people parting out wrecks, Craigslist, even ebay a few times. Not everybody recognizes a good deal, even when it's staring them in the face.
  8. John Casteel
    22
    Savannah, ga
    There is a battery for sale on the jacksonville, Fl craigslist. I'm assuming that the seller breaks cars apart and sells parts but I really have no idea.
    Is that directed at me :). I should probably consider the battery in Fl but I can't get there until next week and I want to do the diagnosis.
  9. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    No, no, no..I'm referring to deals on ebay and CL that I run across here and there. Most people don't recognize what's for sale or how to look at the serial numbers to tell the manufacturing dates. There could be (2) Gen 1 batteries for sale on ebay, one built in 2002 and one built in 2012 or 2015, but someone always ends up buying the 2002 battery. In all seriousness, my comment had nothing to do with this conversation.
    Jim
  10. John Casteel
    22
    Savannah, ga
    Just kidding around. I am back from NYC but I still don't have my mini-vci. Unless my wife set it aside. I think tomorrow is the first day it was expected to be delivered.
  11. John Casteel
    22
    Savannah, ga
    Back home from a wonderful trip to NYC or what I like to call the land of Prius taxis. Back at work and time to get to work on the Prius.
    Techstream purchased, delivered, and installed on my old HP Mini running Windows 10. This is the first time I've run Techstream so I hope I did everything right.
    Here are the codes:
    In HV Battery.........P0A80..Hybrid battery failure
    ...............................P3022..Battery block 12 becomes weak
    In ABS/VSC/TRC..C1259..HV system regenerative malfunction
    ...............................C1310..HV system malfunction
    ...............................C1378..Capacitor Communication Malfunction
    In Air Conditioner...B1421..Looks like I can forget about this one. Everybody gets it.
    About the car. I am the second owner but I have found all (most) of the records for this car. It has never been in a wreck. It is in very good condition. It was well taken care of before me (all services performed at a Toyota dealer) and I have continued that except that I do all of my own work. Oil changes on time or before. I have had absolutely no trouble with the car during my 2.5 years of ownership. I use fuelly and have averaged 37.3 mpg over the lifetime of my ownership. The best tank I've had has been 49 mpg. Mostly city driving. I've always felt my mpgs are low as I am a fairly conservative driver. Again no problems at all during my ownership until 2 weeks ago when the dash lit up. I replaced the 12v battery as it was a bit old (The age is somewhere in this thread but I'm not going back to look for it. 5 years old?) I have no fear of DIY. Thoughts on what I should consider?
    P0A80 indicates a hybrid battery failure. Do I assume it is dead and start looking for replacement? Either Toyota, possible goodwill. Except age, mileage and I have never had any work done at the Toyota dealer so I don't have a relationship. But it never hurts to ask.
    Or a recent reply to this thread mentioned a Gen3 battery pack which seems a better option to me than a Gen2 replacement depending on cost.
    My gut feeling is to keep the car, replace the battery and try for another 10 years. Mentally amortize the cost of the battery over those expected 10 years. The car is probably worth $3500. I haven't looked at values. I'm guessing and that would be if the dashboard weren't lit up.
    I have a second car so I am not up against a wall to do something immediately but I would like to put this problem behind me since I have lots of other problems coming up.
    What say you oh gurus of the Priuschat?
    #31 John Casteel, Mar 26, 2017
  12. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    If it were me, I'd start looking for the salvaged, low-mileage NiMH Gen 3 pack, maybe around $1000? I'd also start shopping the dealers' parts depts in my area for new battery price. It sounds like some are selling them for around $2100, with a reduced warranty to DIYers. Factor sales tax in your decision.
    I would steer clear of salvaged Gen 2 packs. Even the newest are approaching eight years of age, and in my mind ten years is a good maximum battery life, regardless of mileage.
    Keep in mind, if it helps with the amortization thought process, that a healthy battery pack will be easily transferable, and has some salvage value per se if something happens to the car.
    m.wynn likes this.
  13. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    John, If you're wanting to go the full module replacement direction, I'm going to throw this offer out to you. I have a Gen 3 battery removed from a 2015 wrecked Prius with 14,000 miles. I've already tested all the modules and have them on the shelf. They are all date coded 04XP, which decodes to a manufacture date of November 4th, 2014. The capacity test results were between 6705 and 6942 mah. I can assemble these in a case, along with all the support electronics, install it in my car (also 2007), and drive it to you. I think its probably a 2-2.5 hour drive from Columbia to Savannah. We remove it from my car, install it in yours and make sure everything is good to go. (I'll bring my battery also, of course, so I can put it back in to drive home). $1200 plus your old battery.
  14. John Casteel
    22
    Savannah, ga
    I'm thinking about it. First thoughts are what is your availablity? Not that I doubt you but any proof of the mileage or age of batteries? Photos of serial numbers. Not that I would know what I was looking at if I saw it.
    Another option is that I could come to Columbia with my core and swap with you there. What would be the cost that way?
