Top 20 MPGe
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by markabele, Jul 1, 2013.
  1. markabele
    5,084
    1,782
    Nebraska
    Hmm, that is a good question. I'm torn. But I would be happy to hear thoughts and go with the consensus.
  2. RBooker
    RBooker Member
    154
    56
    I am in favor of adding other plugins. After all the goal is to help educate ourselves and others to the real world capabilities of the technology.
    We need to think about a better format for presented the data. It should include both PIP only rankings and a second that includes all plugins. The biggest challenge will be recruiting drivers of the other plugins to submit their data.
  3. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    Agreed you want a PiP only table..
    I think you should keep this thread for PiP.. and if others want to have a top X they can do it in their subforum. Note that the sampling of PiP users here may be good, but for other vehicles its likely a poor sampling so top 10 here might be meaningless. E.g. I'm at 84% EV lifetime but there are 715 people with higher EV percentages at voltstats.net, so likely better overall MPGe.
    A different problem for other vehicles is how they verify data. The 2011 Volts did not display kWh used in the car in any way.. so I have to track it externally.. For many months volt owners do get emails from onstar with monthly usage that shows kWh/100miles and gas miles but it truncates overall MPG at 250 and does not report gallons. So one cannot see data for computing MPGe other than the "last 30 days" tab which may not equal 1000miles. Volt owners have voltstats.net for tracking but because the car does not report kWh the MPGe there is a weak estimate (presuming 95Mpge on EV, but last month including 100 ICE mles I was at 105MPGe overall; I have many months where my EV is 135MPGe or better..
    I have no ideas what one would do to verify a Energi's usage.
  4. markabele
    5,084
    1,782
    Nebraska
    I'm bumping this thread because I'm certain there are more PiP drivers out there who just don't know about it. Just post a ratio screen of over 1k miles and you are in the top 10...easy. :)
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    This is from my 4th of July four days trip to Canada.
  6. markabele
    5,084
    1,782
    Nebraska
    Pretty good, about 59. Doesn't beat your other entry though.
  7. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Yea, that's probably the worse it can get for me. Time to work on the next 1,000 miles run.
    Edit: Volt owners need to average 65% EV ratio to hit 59 MPGe. My PiP did it with 6% EV ratio, wow!
  8. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Per Voltstats.net, Volt owners with 85% EV ratio averaged 73.5 MPGe. My PiP with 50% EV ratio returned 75.3 MPGe. Volt owners with 50% EV averaged 51.6 MPGe.
    Isn't it interesting? Using more electricity does not result in higher efficiency.
  9. drinnovation
    2,027
    586
    65
    CO
    Actually voltstats does NOT track MPGe as OnStar won't provide through its interface to voltstats (we tried).
    Voltstats presumes 93MPGe when on battery which is a lower bound from the 2011 model year.
    For example, on voltstats my last month shows as 79.2 MPGe (and july which is 100% EV is 93MPGe).
    But here is the actual data (Note this had some highway trips at higher speeds, used gas and AC).
    Energy Consumption
    Select Time Frame
    Last 30 Days
    543
    100
    643
    315 MPG
    101 MPGe
    2 gal
    149 kW-hr
    Which is over 129MPGe. MPGe for EV miles over the past 12 months is 115MPGe (winters lower, summers higher and trips with guests and highway higher). My best months have MPGe of 130 and I've never had a month lower than 98. So using a flat 93 is really more of a lower bound. I'm at about 85% EV.. and since Oct 2011 my MPGe including gas and electricity, is at 95.78
    Isn't interesting how EV drivers can so significantly exceed EPA?
  10. 3PriusMike
    3,101
    2,421
    Silicon Valley
    Yes I measured about 9-10% from an L2 ChargePoint. Of course it is only measuring the watts when you are using it and it takes some watts to have it just sitting there. At home with L1 charging it is only a little bit worse...11 or 12% and this was measured each time and unplugging.
    If I was wiring a garage today, I'd put in a dedicated on/off wall switch. Even better would be a push button mechanical timer...one push gives you 1 hour, two pushes 2 hours, 3 pushes 3 hours...or slide a switch for always on.
    Mike
  11. 3PriusMike
    3,101
    2,421
    Silicon Valley
    My best stats that I have a pict of (from low mpg winter months):
    usbseawolf2000 likes this.
  12. retired4999
    2,652
    627
    Eau Claire, Wi.
    Nice Job! Can't wait to see your summer numbers! (y)
  13. markabele
    5,084
    1,782
    Nebraska
    Updated!
    Congrats, Mike, second place. Still 3 more spots to fill until the competition really heats up.
  14. plugable
    plugable Junior Member
    59
    Rancho Cordova, CA
  15. markabele
    5,084
    1,782
    Nebraska
    Nice work! Updated!
    Need only 3 more posts/entries to boot me off the list!
    retired4999 likes this.
  16. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    I don't think I'll last very long on the list, but great EV ratios so far! 95%+ 0f my rides are 100% electric in town/commute. Almost 100% of the HV miles are 200-800 mile round trips with little or no chance to plug-in.
  17. markabele
    5,084
    1,782
    Nebraska
    Updated.
    I'm sure you guys know this, but just a reminder that this can be any 1k miles segment. I imagine once the competition heats up some more we will see people going for really good 1k mile segments.
  18. Clearwater Blue PIP
    Clearwater Blue PIP Junior Member
    36
    Arizona
  19. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Does it include charging loss? If not, what is a typical loss for Volt?
  20. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    I may need to add more air into the tires and drive more carefully for the next 1,000 miles LOL.
    markabele likes this.
