Top 20 MPGe
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by markabele, Jul 1, 2013.
  1. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    Sorry, I should've said "12V battery didnt die".. but if you want to hear the story of my 12V battery death..
    basically, the little cover on the vanity mirror was open.. when its open and the sun visor is down, the vanity mirror light stays on even if the car is off (I assume its the same on any Prius or Toyota).. when I had my car parked for 4 days, I put up a sunshade using the sunvisor to hold it in place.. I didnt notice the light was on.. so it drained the 12V battery completely
    I bought an Optima 12V but havent put it in yet because the stock one is still working after charging it up
    But my big battery is still working fine.. no noticeable degradation (although my driving technique has definitely improved since I bought the car)
    usbseawolf2000 and SageBrush like this.
  2. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    Thanks, mark
  3. vvillovv
    vvillovv Senior Member
    4,332
    1,516
    NY
    The only reason I believe some of these numbers is that I can see how to get at least some of them. for myself.
    So I also have an idea about what my numbers would be if I were just a regular joe type driver, names witheld except joes.
  4. vvillovv
    4,332
    1,516
    NY
    I'm no expert on lead acid, but it's hard to believe the battery was completely drained. I'd expect to see a couple of V let in it and depending on it's previous condition, sometimes if you get a trickle charge on it right after it gets taken down real low, one can cycle it back to fairly decent health.
    as always YMMV
    and buying new is so much easier, granted.
  5. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    Well, when I say completely drained, I mean nothing worked.. no lights, nothing lit up when pushing the start button, remotes didnt work, even the little LED above the charging port didnt light up
    I put a charger on it and it started up. I let it sit for a bit and drove it for a few minutes and parked it. The next day, it was dead again. So that evening, I put it on a charger for about 3-4 hours and its been fine since (that includes a 3-day period of sitting around). Its going to be sitting again for 5 days real soon.. so we'll see if it still survives.. but so far, it seems to be more resilient than some would portray it be.. but I'm still going to replace it :)
  6. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Battery minder ? (trickle charger)
  7. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    I have one.. but nah, I kind of want to see if it will be alive after 5 days. I have an Optima sitting in the box so if I come back from vacation and its dead, it'll be motivation to swap out the old battery with the Optima.
  8. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)My current fill up (March 29, 2014 - 3 bars left) - Thanks Markabele!
    My daily driver since Nov 2013
    usbseawolf2000 likes this.
  9. retired4999
    2,652
    627
    Eau Claire, Wi.
    Very nice!! Excellent!!(y)(y):whistle::D
    -1- likes this.
  10. markabele
    5,084
    1,782
    Nebraska
    Updated!
    Nice work!
    vvillovv likes this.
  11. JBumps
    JBumps Member
    167
    57
    Morgantown, WV
    2013 Prius Plug-in
    I know I'm only half way there this month, but have to share what the changes to commute/charging habbits/patience have done. This even includes a trip to Lowe's with trailer in tow, thus the crappy HV mileage :) There are even 14 more all EV miles this month that occurred before I reset the trip!
    #631 JBumps, Aug 8, 2014
  12. markabele
    5,084
    1,782
    Nebraska
    Nice, keep it up! Looks like you should have no trouble claiming at least fifth place.
  13. kriggleman
    kriggleman Junior Member
    Indianapolis, IN
    Except that fifth place can be a moving target as I had my sights on reclaiming it as well. I held 5th for quite a while until markabele and Tracksyde did even better in the category below "pure" EV. Then I unexpectedly ended up with a summer of almost pure commute driving with just a small number of weekend trips outside of EV range. Mostly because longer trips were in our 2010 std Prius whose ICE needed some longer trips to balance out all the short ones my wife takes. Doubt I will ever see 90% EV again over 1000 miles so I doubt I'll ever do much better. These numbers essentially reflect efficiency of my daily commute of 9 miles each way, while my previous entry included far more weekend HV miles.
    usbseawolf2000 and retired4999 like this.
  14. markabele
    5,084
    1,782
    Nebraska
    Updated!
    Even though you bumped me down a spot...congrats! Haha! :)
  15. kriggleman
    Indianapolis, IN
    Yes, but your EV efficiency is still much better than mine. What's the secret? I imagine the 11 traffic lights that are part of my daily commute are part of what's holding me back, but I already do my best to time them as much as possible. The speed limit on my commute is 45 MPH tops so that along with nearly flat terrain did help with the efficiency I reached.
    retired4999 likes this.
  16. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I was doing 68% EV ratio and then the Labor day weekend screwed it up. :) Now it is 55%.
  17. markabele
    5,084
    1,782
    Nebraska
    No real secret. I try to drive without brakes as much as possible (and even drive without regen). Also, I rarely go over 45 unless I absolutely have to.
  18. vvillovv
    4,332
    1,516
    NY
    my 1k ev trip was reset at 950 miles last month, so I just waited for the other trip to get to 2k.
    #638 vvillovv, Sep 9, 2014
  19. markabele
    5,084
    1,782
    Nebraska
    Updated!
    Nice jump!
  20. Anthony Lucero
    Anthony Lucero New Member
    Upland, Ca
