Top 20 MPGe
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by markabele, Jul 1, 2013.
  1. markabele
    5,084
    1,782
    Nebraska
    I unfortunately don't have the time right now to redo all of the top ten numbers. If anyone else is willing I would be grateful.
  2. markabele
    5,084
    1,782
    Nebraska
    Nevermind...working on it right now. :)
  3. markabele
    5,084
    1,782
    Nebraska
  4. retired4999
    2,652
    627
    Eau Claire, Wi.
    Cool, Thanks! :)
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Just need the formula updated.
    markabele likes this.
  6. RBooker
    RBooker Member
    154
    56
    I thought this was interesting.
    Over on the Cmax Energi foroum they estimate the charging efficiency of the Energi is 61%. To calculate MPGe for they Energi they multiple kWh by 1.4.
  7. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    That seems unlikely. Do you have a link? Which forum site (URL)?
  8. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Ah, I now see where the 19% loss estimate came from on the new Volt top 10 MPGe thread. Yes, that's about right for charging at 120v as indicated by the reference to measuring this with a kill-a-watt.
    ChargePoint tells me that a full daytime (70-85F typically) charge if my 2011 Volt at 208-240v is usually 11.5-12.0 kWh (12-15% overhead) with a few 12.28 and 12.78 kWh charges in July last year. I'm guessing the higher numbers were due to especially hot weather causing the TMS system to cool the battery.
    I'll try measuring full charging sessions overnight on OnStar and daytime on OnStar at work this week (yes, we finally have 208v stations now at work!).
    I'll report my results over on the Volt top 10 thread.
  9. 3PriusMike
    3,101
    2,421
    Silicon Valley
    I doubt that you can use the full or usable battery capacity and the Chargepoint or kill-a-watt result to measure charging efficiency.
    I did it by measuring several charges, only driving in EV, and using the car reported kwh used. I got 9-10% losses from L2 on Chargepoint over 140 miles...some uncertainty because the ICE did come on briefly at 124 miles and I did need one L1 charge.
    Mike
  10. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Well, it's a bit of a guess since my 2011 Volt doesn't display the kWh drawn from the battery like the 2012 and later cars do. But, I've got the same battery pack as the 2012 and we know from documentation and experience with the 2012 cars that the typical usable capacity is around 10.3 kWh if the weather is pleasant and you are driving efficiently. The Volt doesn't stays in EV mode until the usable capacity is depleted so there is no need to worry about that.
  11. kurbmaster
    kurbmaster Junior Member
    46
    24
    here is my screen shot
  12. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    81.7 MPGe (137 MPGe / 57 MPG, 51% EV)
    That should put you on the #7 spot.
  13. markabele
    5,084
    1,782
    Nebraska
    Updated!
    Clearly anyone trying to get on the list now will need above a 50% EV ratio.
  14. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    From April 23, 2012 to July 22, 2013 Driving Ratio from April 23, 2012 to July 22, 2013.JPG
  15. fortytwok
    fortytwok Active Member
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    Suggestion - instead of using HV gallons + .5 wouldn't it be much more accurate to use 10.6 (full tank) minus (the remaining tank miles divided by 50) ?
    on an HV read of 9 the formula is assuming 9.5 but it could be 9 or 9.99
    Changes the outcome by quite a bit...
    I understand that assumption of 50mpg could be anything from 45-55 but seems like that's a lot closer to accurate.
    My current (lifetime) read now shows HV = 10. Adding .5 means I'm on empty !
    Yet I have about 1.5 gallons left as evidenced by 2 gas bars and remaining tank miles of 70
    just a thought...
  16. markabele
    5,084
    1,782
    Nebraska
    Update!
    It will now pretty much take 80 MPGe to get in the Top 10.
  17. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)Here's mine as of this evening (072313).
  18. markabele
    5,084
    1,782
    Nebraska
    Updated!
    Nice work!
    As a side note...I think I'm beginning to realize how freakish retired4999 run was. Truly unbelievable.
  19. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    GREAT advertisement for the PiP - thats my goal for tank #2
    Tank #1 just hit 4,000 miles but just 1.5 gallons left so days are numbered ...
    http://i1329.photobucket.com/albums/w545/golfx15/photo_zps18fc9d29.jpg
    still think the calculation we're using is flawed - read says 10gallons used so adding .5 means I'm empty yet I see 70miles left....
  20. markabele
    5,084
    1,782
    Nebraska
    I can't see all the numbers on that pic....and is that a new entry?
    You reset the ratio screen at the same time as you filled up? Did you get a really full fill?
