Top 20 MPGe
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by markabele, Jul 1, 2013.
  1. fortytwok
    fortytwok Active Member
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    It's not a new entry - last I checked I was 3rd place. And no I didn't hit anything - this is my first tank and the dealer filled up.
    Problem was all their test drives were on gas so car had 20 miles and 1 gallon on the read when I started...
    Must've been a complete fill up though as you can see my read says 10 gallons - I see now my pic didn't show it but I have 2 gas bars left and read says 70 miles to go
    Edit - I may have misunderstood - this is my newest pic : 4010 miles 441 gas 89% EV
  2. markabele
    5,084
    1,782
    Nebraska
    You are at 114.9 MPGe on that pic. Not quite good enough to beat your other personal best.
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    It displays 10 gallons and it may be exactly 10.0 gallons. We are adding 0.5 to it because PiP will still display 10 even if you used 10.9 gallons.
    70 miles to empty also take account of your EV miles. Say, 12 EV miles left and perhaps the car still has a little over a gallon left. I know the official capacity is 10.6 gallons.
  4. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    I get that - and agree on the 70 miles to empty.
    I've got 70 miles to empty in total = 58 gas miles, still greater than one gallon
    2 gas bars should confirm that...
    I also understand my case is different given its my first tank and I was starting "behind" due to the dealer miles included. I'll do better next tank !
    btw has anyone beat 4,000 miles on a tank ? I know another Boston area driver was recently over 3,000
  5. retired4999
    2,652
    627
    Eau Claire, Wi.
    No one I know, and it will not be me. I don't drive alot and I have a road trip at the end of August so that will be the end of my tank. Then fall and winter will be here and we will see shorter EV miles available and heat will be needed, so engine will run more.
  6. retired4999
    2,652
    627
    Eau Claire, Wi.
    Thanks, Just an update just turned 1900 miles today still at 999mpg 95% EV. No trips planned until the end of August so I will keep rolling along till then. At that time I will update.
    markabele likes this.
  7. markabele
    5,084
    1,782
    Nebraska
    Keep an eye on your current numbers. Maybe your current ratio screen might even beat what you already have up there.
    usbseawolf2000 and retired4999 like this.
  8. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    I was going to tell you to suck it up and skip the heat but then I saw you're from Wisconsin.
    Knew a marathoner from GreenBay who did 20 mile runs on her treadmill when it dropped to 10 below
    My tank will be done in no more than 3 weeks because my 5 mo check-up is scheduled - so 4500 max
    retired4999 likes this.
  9. markabele
    5,084
    1,782
    Nebraska
    I assume you run marathons too, hence the name?
  10. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    I've run 20 of them, now I just coach
    good catch on the name - most including running buddies didn't get it
  11. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    I'm a former marathon runner with 10 Marathons and 4 50ks I didn't get it either until this post.
    fortytwok likes this.
  12. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    ok, inspired my Retired4999's crazy numbers I did a reset this week to see how close I could get and the problems with the formula are even better illustrated :
    I'll post a pic if anyone wants to see it but here are the numbers -
    I'm driving along at 100% EV - 61 total miles - 0 gas miles - 11kwk = 158.8 MPGe
    Next mile the dreaded ICE kicks in - when this occurred to me and it stopped I pulled over and took a pic...
    Now I'm at 98% EV - 62 total miles - 1 gas mile - 11kwk and the formula (adding in that 1/2 gallon) now says I've only gotten 70 MPGe !!! Dropped 88 MPGe in a couple miles ? I don't think so
    You could say due to the rules of the formula I should've added the 1/2 gallon at the start - even though 0 gas had been used but that's even more ridiculous.
    the most correct way to do this is to look at gas used - 26 miles used = 1/2 gallon. 1 mile used = 1/52nd
    Otherwise the only time the formula works is when you truly are close to that 1/2 gallon mark
  13. markabele
    5,084
    1,782
    Nebraska
    Yes it's going to throw it way off when you are driving so few of miles in your equation. That is why our minimum is 1000 miles. It throws it off much less.
    While your idea is decent it doesn't take into account that some people may be getting 30 mpg in HV while others may be getting 80 mpg in HV.
  14. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Yup, which is why min of 1,000 miles is needed for the entry. If you can show the actual gallon from refilling the tank at the pump, we should use it. The formula is good enough for general purpose 1,000 mile tank.
    As the competition heats up, we may want to measure our own charging loss and actual gallon.
  15. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    The former makes sense - I just posted this because it was so easy to see the shortcomings.
    I don't really agree with the latter though - unless you're a Consumer Reports driver ;-)
    I'd say a mean of 48 is a really close assumption. I'll bet 90% get 40-60mpg and using such will be a lot more accurate than always assuming .5
    here's that pic if anyone cares :
    http://i1329.photobucket.com/albums/w545/golfx15/photo_zpsb7a122cc.jpg
  16. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    actually had another idea after posting that pic of the reading
    markabele mentioned the variable of 30-80mpg in HV
    but you can get pretty close by looking at the pics - it says "fuel saved by charge" of 9/10 gallon
    So 62 miles - 9/10 gallon... not sure if Toyota is doing what I'm assuming there but it seems pretty close
  17. retired4999
    2,652
    627
    Eau Claire, Wi.
    I know what you mean, notice my HV miles! and only used 1 gal. Yeah right! I am not a math genius, but? I would bet when I hit 100 miles HV it will say 2 gal's used!
  18. markabele
    5,084
    1,782
    Nebraska
    Unfortunately there is no way around this folks. Even requiring a receipt would make it so it has to be all on one tank which might not be practical for some people.
    I realize it's not perfect. But it's the best we can do.
  19. markabele
    5,084
    1,782
    Nebraska
    Also, by posting that...you just inadvertently broke your own record! Congrats!
  20. retired4999
    2,652
    627
    Eau Claire, Wi.
    Cool thanks! for the update.
    I am right at 2000 miles now but no current picture.
