Top speed in EV mode
Discussion in 'Prime Technical Discussion' started by mnml, Jan 9, 2017.
  1. mnml
    mnml Ain't nobody got time for that.
    377
    161
    Ladera Ranch, CA
    With a fully chraged battery, what is the top speed while in EV Mode before ICE takes over?
    I've read it's 84 mph but wabted to confirm with actual real-world Prime owners.
    TIA!
  2. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    It has been confirmed on other threads already.
    In fact, we have even found out how long the electricity will last at those high speeds. The answer is not very. Firing up the engine and saving the electricity for later can be the better choice.
  3. mnml
    377
    161
    Ladera Ranch, CA
    Thanks John. Appreciate the confirmation. I'm considering going back to a PHEV once my EV lease is up next month. My commute is 22 miles to work with free charging once I arrive. Of the 23 miles, 18 miles is freeway where the average speed in the HOV lane is 75-80 mph. My hope is I can travel the 18 miles in full EV and only burn a few miles of gas each way.
  4. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    The 22 miles can't be covered fully by EV if you drive that fast. My experience is 17 miles.
    mnml likes this.
  5. mnml
    377
    161
    Ladera Ranch, CA
    Thanks for the feedback. If I can get 17 EV miles in the SoCal "winter" then I'd be okay with it. Just wanted to make sure the ICE doesn't kick on if I'm going faster than 60 mph.
  6. Mister MMT
    Mister MMT Active Member
    285
    142
    Germany
    Would it not be good you making a good test drive?
    Jan
  7. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    I drove 65 in Ev mode on my test drive with no problems and with almost no Ev range left (maybe 2 miles or so).
    mnml likes this.
  8. john1701a
    12,840
    5,312
    58
    Short drive at 70 mph with the electric heater running for me.
    #8 john1701a, Jan 10, 2017
    mnml likes this.
  9. mnml
    377
    161
    Ladera Ranch, CA
    My local dealer is getting a few in next week. I plan on to test drive it now that I have confirmation that ICE won't kick on until I pass 84 mph or EV range is depleted. This was not the case when I had my PIP.
  10. CaliforniaPrius
    313
    201
    Alameda, California
    I am not sure if ICE will engage when you floor the pedal but if you do it gently, I haven't seen ICE kicks in before 81MPH, according to my experience.
    mnml likes this.
  11. mnml
    377
    161
    Ladera Ranch, CA
    Thank you! This is what I wanted to hear. There is less traffic during my early morning commute so ppl are flying in the HOV lane. In my EV, I can easily keep up but not sure if I will be able to do so in a Prime and not piss ppl off. I would likely hop out of the HOV lane if that's the case. My afternoon commute is usually around 70 mph so I should be good.
  12. Darth Vader
    Darth Vader New Member
    17
    16
    New Hampshire
    I hit 86 mph in pure electric. I had one passenger and some luggage in. Battery was completely charged, climate/radio/heated seats turned off.
    I also went 104 mph in it before it governed. I was in power mode while I did this.
    mnml likes this.
  13. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    You mean more than 104 mph is not possible?
    Regular Prius can do 112 mph,in that case the rumours are sadly true .
    They reduced the top speed in HV-Mode !
    That won't go down very well here in Germany...
  14. Lee Jay
    5,850
    4,036
    Anyone driving a Prius at 104MPH has missed the point.
    rajoneshsv, taigebu, ruby and 2 others like this.
  15. civicdriver06
    797
    324
    Germany
    Of course I don't constantly drive 104 mph in my prius,but that's not the point here !
    We are talking of a 4,64 m long mid sized sedan and even a small Toyota Yaris can go faster !
    German Press will make fun of it !
    We go very different speeds on our highways compared to the US and going 100 mph isn't exactly considered fast over here !
    thatoneraccoon likes this.
  16. Lee Jay
    5,850
    4,036
    So what?
    I typically drive 65 in the 75 zones to get better mileage. That's what the Prius is about. If you're sad that you can't go faster than 104, you've entirely missed the point of the vehicle. If the Germans make fun of it for that reason, who cares? I don't need the press to decide what I like and what I don't like and I couldn't care less what anyone else thinks of the things I like (the auto press makes fun of the Prius here because they are dumb motor heads). The only people who do are to insecure in themselves to be considered adults and, yes, that's most people.
    taigebu, kevin54, alpilotx and 2 others like this.
  17. Trollbait
    12,764
    Actual top speed in EV mode does face limits based upon how much charge is in the battery.
    Speed governors are electronic now, and the manufacturer can change it for different markets.
  18. civicdriver06
    797
    324
    Germany
    Yes I know but I doubt they will !
    The US 2017 Prius is rated at 112 mph top speed just as the European version is,so why would they limit the Prime ?
    I guess it' has been done to protect the power train because of the extra weight of the Prime !
    Will be strange going 100 mph and knowing I have almost reached the limit .
    It's allways nice to know that my gen. 3 still has some reserves at that point !
    It's not really the point if you really go as fast as 112 mph,but a car of the size of a Prime should be able to do so !
    Most cars of comparable size in Germany go up to 124 mph and more,so 104 is somewhat limited and is normaly a top speed which is expected to be found with very small,low powered cars !
    #18 civicdriver06, Jan 11, 2017
  19. Wolfie52
    Wolfie52 Senior "Jr" Member
    143
    124
    No. Carolina
  20. Mister MMT
    285
    142
    Germany
    I share your opinion and practice the same with my 2 gen Prius. But I can understand civicdriver06's opinion. It is mainstream.
    What he also is implementing, is that the speed limitation to 100 MPH will affect sales. I'm a Belgian (look at my avatar, a famous professor) living in Germany for more then 10 years now, and people here just want to be able to drive at least 120 MPH, even if they do it rarely.
    There is a > 100 pages thread on Priusfreunde.de about yes or no introducing a 85 MPH limit on the German "Autobahn". Several contributors were absolutely against it. Speed is Germany's holy cow...
    Jan :sneaky:
    mnml and alpilotx like this.
