Top Speed of Gen 4
Discussion in 'Gen 4 Prius Main Forum' started by Gen 2 Tom, Dec 2, 2016.
  1. raspy
    raspy Senior Member
    438
    699
    London, UK
    I have yet to max out but has anyone else observed that the car accelerates stronger between 80-90mph compared to 70-80mph?
    douglasjre likes this.
  2. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Sorry, not been aware of my speed when above 80mph. What more were you in?
  3. William Redoubt
    William Redoubt Senior Member
    1,228
    1,174
    Coronado Island, California
    Virginia? 20 over gets the death penalty in Virginia, plus they kill your cat to show they are serious.
    Montana, though is the place to speed. At 117 mph you'll get passed by a red 1984 top down caddy convertible with steer horns on the front and pair of fake testicles on the rear. And the cigar smoking driver will be laughing.
  4. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    I'm afraid to go too fast... I might blow out one of my cheap Toyo tires. :LOL: I stay down on the 30 mph range, like bisco.
  5. Prodigyplace
    12,717
    11,849
    Central Virginia
    He said West Virginia. That is a different state.
  6. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    My Gen 2's Michelin Energy Saver Tyres have an 87H rating - that means they're rated to handle speeds of up to 130mph. I once got my Prius 2 up to 100mph - I found it surprisingly well balanced at that speed, albeit a tad noisy.
    iPhone ?
    RCO likes this.
  7. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Max speed on the gen3 is 116mph
    iPhone ?
  8. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    Can we flash the ECU to undo the speed governor
  9. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    It is an RPM governor. You can put on larger diameter tires to go faster. That is what the Gen 2 land speed Prius did.
    Notice that to go faster this way, you accelerate slower. Bonneville allows push trucks.
    telmo744 and krmcg like this.
  10. Chris Wolfgram
    Chris Wolfgram Active Member
    425
    169
    Sacramento CA
    2019 Prius
    Oh geez ! Now you guys tell me !
    I was going to get a Ferrari, but figured I could get close to 200 mph in my Prius Gen 4.... Now I'm bummed :(
  11. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    You can accelerate your Prius to 200 MPH, but you will need a cliff 1400 feet tall to push it off. El Capitan is 3000 feet tall and nearby, so it is possible.
    alanclarkeau likes this.
  12. BlackT0P
    BlackT0P New Member
    North California
    Four Touring
    We have done 117 on a downhill while cross country traveling. But yes the “set” limit is 115 on flat roads.
    Gen4
  13. douglasjre
    2,250
    751
    Null, NL
    How do I unset the governor to get a higher speed
  14. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    You can use larger tires to get higher speeds, expect slower acceleration.
    Even the land speed record guys could not alter the rev limits.
    (in theory, you could hand craft a new final drive gear to do the same thing. tires are cheaper and require less skill. The Prius v uses a different final drive than the Prius liftback to get lower top speed and quicker acceleration.)
  15. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Yes, and the computer controlling MG2 and MG1 (and the HSD) would need re-programming somehow.
  16. Mambo Dave
    Mambo Dave Active Member
    641
    307
    2019 Prius
    L Eco
    I can confirm I was limited to 112.
  17. Razvan76
    Razvan76 Junior Member
    London United Kingdom
    124 mph in Germany! Speed is limited because of the CVT transmission , Toyota limited all to 200 kmh ! I am thinking to remove from computer the limit ! Driving perfectly on high speed ! The car feel perfectly at 125-140 km/h and consumption is around 5,3 l /100 km
    douglasjre, krmcg and Mambo Dave like this.
  18. fuzzy1
    10,713
    Is that:
    (1) displayed on the speedometer; or
    (2) read from ECU internals via the OBDII port; or
    (3) measured with a different device, such as a GPS?
    We know that #1 intentionally reads higher than true speed, and have had numerous indications that European market speedometers are biased higher than North American speedometers. That is why readings by #3 (best) or #2 (better than #1) are useful.
