Torque OBD reader shows HV battery charging at 14kw
Discussion in 'Gen 2 Prius Main Forum' started by BrokenWrench, Oct 23, 2019.
  1. BrokenWrench
    BrokenWrench Junior Member
    56
    Tampa, FL
    I've got the call into Todd at Tampa Hybirds.
  2. BrokenWrench
    56
    Tampa, FL
    I wonder how long a 2nd gen can run with the #5 block causing the Triangle of death code?
    (The battery is 15 years old so it doesn't own the car anything - but I may need to use it a few times before I do the repair)
  3. PriusCamper
    PriusCamper Senior Member
    13,467
    5,435
    Pacific Northwest, USA
    Main thing is to monitor battery temperature with Dr. Prius App or other software so as you drive and clear codes as you go you're able to ensure you don't overheat what's left of your battery pack.
