Total Loss of 12V in 2010 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Peter P, Aug 11, 2019.
  1. bisco
    51,952
    does anyone make a load tester, battery charger/maintainer, jump pack?
  2. ASRDogman
    ASRDogman Senior Member
    7,598
    3,916
    I have once of those types of pack. Mine has a usb to charge a phone/iPad etc. Also a light.
    I've used it on my van a few times. And helped other people. And it's small enough to be out of the way.
    I've used it to jump vehicles 5 or 6 times and it still didn't need to be charged.
    But I keep it charged up anyway.
    It is well worth it!
    dig4dirt likes this.
  3. ASRDogman
    7,598
    3,916
    Yes, I know SnapOn has one. A LOT OF MONEY! :)
  4. Mendel Leisk
    41,467
    Just get all three. For me, that's a Solar BA5 (tester), CTEK 4.3 (charger) and Jump-N-Carry 660.
  5. Peter P
    Peter P Junior Member
    Nova Scotia
    2020 Prius Prime
    Technology
    Did your batteries gradually die, or abruptly fail and then self-resurect?
    Thanks for the suggestion! I try to avoid buying from Amazon, but I expect I could find something similar at one of the local businesses. My real hope is to get the problem definitely identified and fixed.
  6. Mendel Leisk
    41,467
    Last JNC I bought was through Napa Auto Parts, they were on sale for $199. Yeah I know.
  7. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Does your go green light by itself? Mine doesn’t anymore, stays red even over 14v (n)
  8. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    A few years ago give/take battery was dead. Cant remember if any dash lights were on or not, but I dont think so.
    Just jumped it from my other prius and all good. It happened a second time and same just a jump, then all good.
    I am still using same batt, as I never replaced it. and hasnt happened since.
    I really think the one time an interior light was left on (I think) and second time,
    I think a door was ajar overnight (again, just thinking) however those were just my assumptions.
    I never gave it too much thought after those incidents.
    But 5 years now, same batt and now im just starting to get nervous on it being original and
    near end of life, although I think I will take it until it is actually dead, maybe. I just
    have been multimetering when I think to do it, once a month or few. and im low 12.3-12.5
    for both my prius.
    I even jumped quite a couple non-hybrids a few times with the same batts lol.
    that was before I knew about the prius inside and out....now I just use the excuse of
    having a prius to get out of jumping cars hahaha....but with good intentions.
  9. Mendel Leisk
    41,467
    How old is it?
    Guessing either the battery is going, or the charger is defective. The charger is a rudimentary "smart" charger, but not sure of the quality. I've opened mine up: it's just a little brick.
    You could try connecting an external smart charger to the clamps, or open up the back and clamp directly to the battery posts. Try 1 amp max?
    Up here Canadian Tire has a replacement battery, likely more available in States. Still, I'd troubleshoot the internal charger first. And maybe something like Solar BA5 could test battery. You need to connect directly to posts for that.
    Maybe contact Clore first, hopefully they say something other than "mail it in". Did you get the repair coupon? Not that's much of a deal, especially with shipping.
  10. Robert Holt
    Robert Holt Senior Member
    1,313
    889
    I would add one other long-shot possibility: when tightening the connections to the 12-volt + and - terminals, if you put a bit too much torque on the nut, you can put enough sideways force in the battery post to break its INTERNAL connection to the lead plates underneath the surface cap. That is impossible to see and deucedly difficult to diagnose as the battery works fine when the post is in contact with the underlying plates, but fails completely if the post is jostled out of contact with the plates by, for example, running over a bump in the road. Don’t ask how I know this.
  11. Peter P
    Nova Scotia
    2020 Prius Prime
    Technology
    I do suspect some internal damage in the battery leading to the occasional open circuit. Just now I had a careful look at the plastic around the terminals (looked fine, no cracking indicative of big forces on the terminals) and I gently rocked the terminals just a little - no loss of 12V.
    As you alliteratively say, deucedly difficult to diagnose - thanks for the idea, though!
    Robert Holt likes this.
