Total Loss of Power!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by rogerthat, Oct 2, 2015.
  1. rogerthat
    rogerthat Active Member
    411
    128
    Georgia
    I had just pulled into a parking lot and was coasting to a stop at very low speed and my 2009 Prius (only 50k on the ODO) lost total power - engine off and all lights on the dash also off. I did not notice any warning lights.
    As I pulled into the parking lot and I thought I heard a strange hissing noise. Although at the time I thought this noise was coming from outside and did not consider it to be from my car (my radio was on at the time so that didn't help). However within 10 seconds of noticing this noise the car powered off.
    After a few more seconds, I hit the power button and the car started up as if nothing had happened. The noise was no longer apparent. Ironically, I was visiting Harbor Freight to purchase a hollow hole punch for the smelly vent tube fix. Anyway, I parked and checked under the hood for any obvious issues. First checked the drive belt which was still on, then checked the oil which was all good, then checked for any obvious coolant leaks which I could not see.
    After running into Harbor Freight for 5 minutes, I drove home (approx 6 miles) and experienced no issues with the car. At home, I plugged in my bluetooth OBD2 and the Torque lite app showed zero logged or pending fault codes in the ECU. In addition, I checked the 12V battery via the vehicle display. The battery appeared to be good - 13.9V when the car was fully powered on.
    The one weird thing i have noticed about the car is that there is a buzzing noise (different from the brake vac pump noise) after I power off the vehicle after driving. The noise originates from the drivers side under the hood and last about 10 seconds - although sometimes it seems to last much longer. It was my understanding that this noise is normal for a Prius?
    Between the funky smell and this new issue, I'm starting to regret my purchase....I've only had the car for a few weeks! Any help is greatly appreciated.
  2. JC91006
    16,931
    8,640
    1. Have you done all the recalls on your car?
    2. There is an issue with an intermittent combination meter problem. Your dash lights will all go out and it'll seem like you car actually powered off, but it's actually not off. This has a 9 year extended warranty from Toyota.
  3. rogerthat
    411
    128
    Georgia
    Yeah, as far as I know all recalls have been performed. After I purchased the vehicle, I had it serviced at the dealership - they changed the oil, transmission fluid, and performed two recalls - the Steering intermediate extension shaft and the electric water pump. I'll definitely check if they skipped any recalls.
  4. JC91006
    16,931
    8,640
    the combination meter is not a recall, there's a TSB (technical service bulletin) on it. If the problem occurs, they'll fix it for free, within the 9 years extended warranty
  5. rogerthat
    411
    128
    Georgia
    Could failure of the combination meter be accompanied by a hissing type noise? After the power loss, I recall hitting the power button and the vehicle powered back on. Your description of the combo meter problem seems to imply that this would not be possible as the vehicle would not have actually powered off - so hitting the power should have powered it off if it was actually still on?
  6. JC91006
    16,931
    8,640
    If the combination meter failed, the car does not power down. You would need to press the start button for a few seconds for it to power down. When the combination decides to work again, everything goes back to normal. it's intermittent.
    The hissing sound is normal, it's a pump that pumps warm coolant into the thermos tank when you shut down. This usually lasts 10 seconds or so. The purpose of this silly thing is so the car will warm up quicker when you start up again (with warm coolant from the thermos).
    the combination meter is a guess....as you don't show any codes when you read it.
  7. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Your major hybrid items are covered for 8 years. As per JC sounds like the combo meter failure is a good guess and Toyota would replace it free of charge in your case. You may want to check to see if your VIN is in group with faulty combo meter. My case I am over 9 years so it'll be out of my pocket. So you are in decent shape with a younger low miles vehicle.
  8. rogerthat
    411
    128
    Georgia
    Just to clarify, the hissing noise I heard as I pulled into the parking lot was not the same as the buzzing noise I always hear after powering off the car. This sound was more of a high pitched whirring sound - although since I initially thought the noise was not from my car, I wasn't paying too much attention to it.
  9. JC91006
    16,931
    8,640
    This car is accident free and not a salvaged titled car right?
  10. rogerthat
    411
    128
    Georgia
    Yeah, car has a clean title and clean carfax - it was purchased privately from the original owner. I did not get the sense that he was hiding anything.
  11. rogerthat
    411
    128
    Georgia
    Could this issue be related to the replaced coolant pump? What about some type of smartkey failure?
