Total Mileage Between Fill-Ups
Discussion in 'Gen 2 Prius Fuel Economy' started by rochesteruser, Mar 8, 2008.
  1. Prius 07
    Prius 07 Member
    715
    Toronto, Canada
    Re: < 500 km
    Eug, those Toronto (GTA drivers) that you referred to as "annoyed" are annoyed already. Drive the best way you think you can and maximize the benefit of your Prius. I've found that route selection is the most important factor and this will enable to implement the beneficial driving techniques.
    Gabe
  2. MPGsnob
    MPGsnob New Member
    16
    Arthur, IL
    Hey Brad,
    I bought my Pri @ Dan Hecht- an 05 package 4. Did you trade in your 05 there?
    Steven
  3. pashadc
    pashadc Pasha DC
    Washington, DC
    I got 501 miles on my last tank. I love my Prius!
  4. brad_rules_man
    brad_rules_man Hybrid electric revolutionizer
    716
    76
    Effingham
    Actually I had two other cars in between. I however came back to the Prius in the end, which really says something about the car. I did have a 2003 first generation Prius and I traded that one to get the '05 model. :) I dealt with the salesman by the name of Doug. It is a pretty good dealership as far as dealers go.
  5. way0utwest
    way0utwest New Member
    Denver
    Summer - 410-440
    Winter - 350-380
    We have had our Prius for one year today and we have had a few 500mile tanks, but mostly I think we're in the low 400s per tank in the Denver area.
  6. rochesteruser
    rochesteruser Cruzin' in Rochester MN
    153
    Rochester
    I hope I can learn to drive like that. I don't drive that far anywhere I go. Rochester is such a small city that I can get from end to end in 10 minutes. My trips all consist of 15 minutes or less mostly highway. Still incredible mileage on your part.
  7. KandyRedCoi
    KandyRedCoi S is for Super!
    860
    SoCal/AZ/NV
    i have about 850miles so far
    last time i filled up i waited til only 1 bar on the gauge
    i got about 350+mpg in between
  8. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    I have an early 04 with the 'gas tank issue' so I'm very limited. It's my most frustrating issue with the Prius.
    Before I got the TSB done, when the last pip was flashing I could get in about 6.5 gallons. Now I can get in 8 with the pip flashing and 7.5 at one pip.
    As a rule, I never let it run down below two pips so may average tank is 300-400 miles. I've never been able to go 500 miles on a tank even though my lifetime average at 65K miles is 55 mpg.
    If I could beat Toyota over the head to fix one thing, that would be it.
  9. HighBreed
    HighBreed Member
    113
    Los Angeles/Orange Counties
    I always fill up after the fuel warning beep has sounded and 1 pip begins flashing. I get anywhere between 450 - 485 miles, and pump in between 8.4 - 9.4 gallons.
  10. rochesteruser
    153
    Rochester
    That is about what I am getting now that my car has over 3000 miles. :)
  11. Rakimb17
    Rakimb17 Junior Member
    48
    Palmdale CA
    I get about 500 miles every tank. But I don't refill until 10- 15 miles after it starts beeping.
  12. HighBreed
    HighBreed Member
    113
    What's the highest number of gallons you have put in the tank when you fill up?
  13. KandyRedCoi
    860
    SoCal/AZ/NV
    i have about 2K miles now, and last i checked i did about 405 to a tank, with 1bar still showing but NOT yet blinking
  14. Reallyhatespam
    Reallyhatespam Junior Member
    Miami, FL
    We go about 500 miles, usually with a 45 mpg and down to 1 gallon... never put in more than 11 gallons.
    Steve
  15. hill
    8,989
  16. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    Every tank in 72000 miles has been noted and tracked in GreenHybrid database. I fill up when the empty light blinds which is usually at about 9.5 gal but rarely over 11.0 gal. I'd say the typical 10 gal tank is about 420-520 gal depending on the weather.
  17. rochesteruser
    153
    Rochester
  18. brad_rules_man
    716
    76
    Effingham
    I am about to fill up. I haven't got many miles on this tank, however the temperature did drop as low as 35 degrees out, so the mileage is bad. I will take stats, and post my gallons, my tank miles, and my economy.
    -Brad
  19. jacu23
    jacu23 New Member
    Austin area Texas
    I have only had my 2008 Prius for a couple of weeks. On the first tank I got 390 miles and put in 8.5 gallons of gas, mpg on read out said 49.1. On the second fill up I got 420 miles and put in 9 gallons, read out said 50.1. Both times I filled up with one pip left. I live in central Texas and the weather has been in the 70 -90's. This is mixed hilly highway and flat city driving on my daily commute.
    Thanks for everyones input.
  20. STLPriusOwner
    STLPriusOwner New Member
    St. Charles, MO
    Hello all...I am a bit concerened. I've had my Prius since last Wednesday, it came with a full tank of gas, which I am still on. However, I am down to 3 PIPS and I've only gone about ~230 miles. I'm averaging 44.5mpg (want to work on improving this). I don't think i'm going to get the ~440 miles I was thinking. Did the dealer just not fill it all the way? Is it an anomaly with the first tank?
    Any advice?
