Total Sound Makeover - Sound Deadening, Speakers, Processor, Amp, and Subwoofer
Discussion in 'Gen 3 Prius Audio and Electronics' started by ultraturtle, Jul 11, 2012.
  1. ultraturtle
    108
    81
    Peachtree City, GA
    I confirmed that is how I originally wired it. The amp is powered only when the car is in "Ready" mode.
    I finally got around to installing a 2 farad capacitor next to the amp. I took some measurements to see if it was worth the time, effort, and money. To minimize risk of damage to the DC system, I turned off all other power draws before setting volumes on the head unit, processor and amps to near maximum. Using track 14 of the XLO/Reference Test & Burn In CD (a Big Band tune that blasts a very wide swath of the audio spectrum), I measured peak amperage and maximum voltage drop on the line feeding the amp. Highest amperage reached was an instantaneous 64.0A, with an accompanying max voltage drop of 0.9V (from 14.4 to 13.5). That's a 6.25% drop using a capacitor double the recommended size for a 900W amp (in this case only pumping out about 690W: 13.5V x 64A x 80% efficiency) . So yes, a capacitor is definitely in order for operating a system like this at a near maximum volume level in order to protect the DC supply system.
    Done. I have a PLX Kiwi ODB2 feeding the Torque application on my Android phone. It is unecessary, though. See last part of the reply below.
    My guess is that your reading mostly took place on DIYMA. Every online community has its own unique culture. Priuschat participants seem to value efficiency. DIYMA folks seem to dislike capacitors. Perhaps it is the nature of the vast majority of batteries used to power thier equipment (large, cranking batteries specifically designed to power large amperage draws for short periods), or that many of them like to listen to their systems for extended periods of time with the gasoline engine off, and want the additional listening time. A Plug-In Prius is a different animal. It does not even have a cranking battery, but does have a massive additional battery already that could provide power (in "Ready" mode) much longer than any single additional battery solution they might come up with. If ever there were a car that would benefit from a capacitor, it is the Plug-In Prius.
    All that said, this capacitor experiment was an academic excercise. I never before, nor ever will again play anything in this car at anything close to this sound level. In order to get near the car while it was playing at this level, I wore foam inner-ear plugs, and mickey-mouse earphones over the top of the ears in order to protect my hearing from damage - and it was still very loud. After attenuating the volume to the loudest I would ever consider listening on the JBL processor master volume (-20dB), I added 5dB for a little leeway, and measured the same sample audio again. The result? 6.0A peak and a max voltage drop of 0.05V, less than 0.4%. At this power draw, I probably do not need a capacitor at all.
    Another lesson learned - 6 amps is less than 70 watts total being fed to all of the speakers, including the subwoofer, so it also tells me a lot about how much power I really need. If I had it all to do over again, I would power the 6 speakers directly from the JBL MS-8 speaker outputs (20W ea), and use a single 100W to 300W amp for the sub.
  2. joedirte
    joedirte Member
    281
    57
    ohio
    2003 Prius
    I
    Thanks for the update. Of course the caps add something. Depending on the Farad rating and the ESR, there will be a an extra "pool" of current available. Sure the amps have their own decoupling caps, and in a normal battery they can handle more instantaneous amps then you would need. But considering in a Prius with the ~30Ah AGM battery, I can see the voltage drop quite a bit with just turning on the headlights, that battery would not sink any high frequency current demands, so then all the current has to come down resistive wires which also have inductance. And it's not clear that the DC-DC on the inverter is designed for current spikes like that.
    Q=C*V so in this case we have 27 coulombs of charge. Which is 0.05Wh...
    Or over 0.25 second that is 100A (except it isn't because you aren't going from 14V to 0V). But yeah, it isn't much compared to a normal lead acid battery, but because of very low resistance, the caps can respond to higher frequencies (ie. very low resistance) and sudden changes in power.
  3. ultraturtle
    108
    81
    Peachtree City, GA
    Thanks. Nice to know that the capacitor upgrade is not only useful for daily listening, but should I ever have a need to use blaring audio as a psychological warfare weapon to compel a Central American dictator to surrender, that I have the proper equipment to do so.
  4. mid jersey
    mid jersey Junior Member
    60
    New Jersey
    Is the Prius battery ~30Wh or ~30Ah? Big difference between the two. I thought it was around the 30Ah range.
  5. ultraturtle
    108
    81
    Peachtree City, GA
    I think it is 36 amp-hours, but would need to pull it to check. It is not listed in the specification section of the owner's manual.
  6. joedirte
    joedirte Member
    281
    57
    ohio
    2003 Prius
    I
  7. Bmr4life
    Bmr4life Member
    131
    56
    Atlanta, GA
    2014 Prius v wagon
    Wish the pictures in this thread still worked. :(
  8. Want A Hybrid
    Want A Hybrid New Member
    WOW!!! Very nice and very inspiring as I'm going through the same questions. Thanks!
  9. WE0H
    WE0H Senior Member
    3,247
    527
    The original poster could edit this thread to fix the links to the pictures.
    Mike
  10. Want A Hybrid
    Hmmm.... all pictures show up ok for me...?
    Bmr4life likes this.
  11. Bmr4life
    Bmr4life Member
    131
    56
    Atlanta, GA
    2014 Prius v wagon
    Ha, tried another browser and they show up. Not sure why I don't see them with Chrome, but thanks for replying.
  12. Andrax
    Andrax Junior Member
    Wow, just saw this. Would love to tackle a sound deadening project, but realistically it would be easier and faster to pay someone to do it as I don't have the time or tools...
    Great work!
  13. dan_rc3
    dan_rc3 Junior Member
    this thread is incredible. Thanks for all the info.
  14. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    I'm confused why someone would go through all this trouble to listen to 'CD quality' sound.
    Just kidding! Lovely thread, and kudos to OP.
    sarals likes this.
  15. sarals
    sarals New Member
    Absolutely stellar work! I'd love to hear that system.
  16. janice45
    janice45 Dudley Girl
    82
    maine
    With all this work can I ask how's the bluetooth sound to people now
    I know its not a radio or music question but it somewhat a noise one.
    Thanks
  17. ultraturtle
    108
    81
    Peachtree City, GA
    I frequently stream lossless AAC from my Android phone via Bluetooth, and the sound is about as good as it gets. My unsophisticated ear cannot tell the difference between it and the same files via USB.
  18. Ed Law
    Ed Law New Member
    Australia
    Mate, this is seriously the best sound deadening job ever done to a prius.
    Personally, i thought i had done a pretty good job on my doors, but this has inspired me to go even further and at do the boot and then redo the door trims.
    I just wish i could get some sound deadening Mass loaded vinyl here in Adelaide, Australia. So I am stuck with Dynamat and Jaycar Sound deadener.
    Great work mate.
    Ed
  19. Ed Law
    Ed Law New Member
    Australia
    And also, are you still using the standard head unit?
  20. afpri
    afpri Hemi-Hybrid
    27
    Maryland
    This.... THIS WORK RIGHT HERE. This is Prius porn. very impressive work. You, Sir, are the Chuck Norris of Prius installs.Thank you for a great post.
    girluvr likes this.
