touch control buttons on steering wheel
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by 9G-man, Sep 29, 2011.
  1. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    Anyone notice that for 2012 the touch control steering wheel buttons
    will now orient the increase/decrease of volume, temp, scan, etc. vertically ( as it should be) instead of horizontally as in the 2010/11 models? This is a Prius V pic but the Plug-in is the same.
  2. Gurple42
    Gurple42 New Member
    354
    Santa Monica, Ca.
    I shoudda waited:p
  3. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Is there no "B" mode?
  4. Feri
    Feri Active Member
    761
    144
    Sorry! used to the right hand drive version and RND were on the "wrong " side.:redface:
  5. Mendel Leisk
    38,659
    That is an improvement, more intuitive.
    I wish the radio button that jumps to the next preset station would just scan to the next available station. Especially in Satellite radio.
    Others probably like it the way it is I suppose, hard to please everyone.
  6. lensovet
    2,614
    496
    Burlington, NJ
    Yep, that's correct, and also is the orientation the regular 2012 Prius will have
  7. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Exactly. I don't care about the up/down, I'd just rather have non-menopausal controls. I don't adjust the temperature while I'm driving but I do adjust the fan.
  8. Feri
    Feri Active Member
    761
    144
    Wonder, if the Prius V rubber inset is available, whether the actual switch positions could be changed around on the 2010?
  9. 9G-man
    1,273
    194
    Atlanta, GA
    When left in AUTO mode, the climate control system will vary fan speed with changes in temperature control. Very effective and appropriate fan speed changes, I use the temp control to vary the fan speed regularly.
    With a really hot interior I run the temp down on the steering wheel control and the fan blows hard to cool the interior, and when it's comfortable I run the temp back up to a normal comfort level and the fan slows down. Perfect. Some people misunderstand AUTO mode. It's about combining fan speed with temp differential and system demand. Factors like sun-load and humidity are factored in too. Quite a neat system.
  10. Tideland Prius
    16,128
    Yep and doesn't bother me.. left/right or up/down. The Gen 2 Prius had a mixed layout. Vol was up/down, temp was up/down and track up/down was left/right (which also changed CDs). I miss having most of the automatic climate control buttons on the wheel. The ones I use the most are the recirc, the front defroster and the AUTO on/off.
  11. lensovet
    2,614
    496
    Burlington, NJ
    Yeah lack of climate on the wheel was a real downgrade in usability and even safety imho.
  12. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,996
    Fort Lee, NJ
    This is a great change. I like how they keep improving every little details.
