touch screen 47220 interchange?
Discussion in 'Gen 2 Prius Main Forum' started by Paul Soldridge, Mar 29, 2019.
  1. Paul Soldridge
    Paul Soldridge Junior Member
    27
    coplay pa
    got an 08 prius nav with a dead touch screen - does anyone know if you can interchange any others - dont care about the Nav function and am wondering if any other part numbers will have all the functionality except the nav? current part number is 47220. and I traded out the screen with my other 08 prius with nav, so I know that it is the head unit that is bad.
    Thanks
    Paul
  2. 09Prius2
    09Prius2 Member
    201
    88
    FL
    Yes if the harness connectors match. Theres a bunch of different models but as long as it plugs in it can still work.
    I just swapped a nav unit for a non nav, only difference was the data feed connector. So it had an error message that went away after a few minutes.
  3. Paul Soldridge
    27
    coplay pa
    yea, that is what I am looking for. Just have to try and figure out the part number that will work
  4. Bunya
    Bunya New Member
    Australia
    i-Tech
    There's a Youtube video with a guy that changes a 47220 with a 47260 from an 09 model.
    The title is - Toyota Prius MFD Fix Replace 47220 With 09 Updated 47260 Will It Work?
