Touch Screen
Discussion in 'Gen 2 Prius Audio and Electronics' started by Aimee Jones, Oct 11, 2023.
  1. Aimee Jones
    Aimee Jones New Member
    New Hampshire
    I have a 2008 Prius. I the only thing that will show up on the touchscreen is the screen that shows the battery charging. I’m not sure what that screen is actually called. No other screens show up, so the radio doesn’t show up the temperature doesn’t show up it’s only that screen. I have googled it, and I have found some videos on YouTube that sound like they will fix with the touchscreen if it is not working, however I think there’s more to it as the only screen that will show up is that one that shows the battery charging. Does anyone have any ideas or suggestions before I look at changing out that screen?
  2. dolj
    dolj Senior Member
    8,631
    4,385
    Wellington, New Zealand
    So, you're saying when you push the buttons around the edge of the screen it does not change to the corresponding screen?
    Does pressing the Consumption button on the screen that shows the battery charging (which is called the Energy Monitor screen) change to show the consumption screen?
