Touchscreen Calibration Issues
Discussion in 'Gen 2 Prius Audio and Electronics' started by Bgustafson, Aug 10, 2017.
  1. Bgustafson
    Bgustafson Active Member
    259
    222
    Chicago
    Hi - all of the sudden, the top half of my touchscreen calibration is very off. I can't calibrate it in diagnoses mode because I have to tap about an inch above the button I want to press, so I can't press the "MENU" button on the screen.
    Thoughts?
  2. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    There is a calibration process posted elsewhere. But I had ours calibrated and then it went bad again, I get the bottom buttons at the top of the screen, and only after many tries. Basically need a new MFD screen or someone suggested maybe the electrical connections are dirty and maybe try to disconnect/reconnect the wiring sockets. With the buttons on the Steering wheel, there is not much we actually need the display for, it turns out.
  3. Bgustafson
    259
    222
    Chicago
    So did you replace MFD? I'm going to look into replacing it myself with a unit from a trusted reseller.
