Touchscreen less responsive
Discussion in 'Gen 3 Prius Main Forum' started by nudriver, Sep 1, 2025.
  1. nudriver
    nudriver Member
    283
    32
    los angeles
    Anyone know why an audio touchscreen is rarely responsive? You push it over and over and it often doesn't respond. I have the same problem turning it on and off sometimes, or switching from stereo to phone mode. If it's just busted, is that normal, and how much to fix?
  2. PriusCamper
    PriusCamper Senior Member
    13,451
    5,430
    Pacific Northwest, USA
    Well your car is getting close to 14 years old and so is the sound system... And because a used replacement is going to cost the same or more as a 2025 touchscreen car stereo it's an opportunity to upgrade with way more features and better integration and performance!
  3. nudriver
    nudriver Member
    283
    32
    los angeles
    But what's the cause and what's the cost?
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Age and $454.79.
  5. nudriver
    nudriver Member
    283
    32
    los angeles
    Ouch! Can't be fixed?
  6. PriusCamper
    13,451
    5,430
    Pull it and clean it with compressed air / all the usual other cleaning tricks and try again. Most of the time these problems are just basic end of lifespan problems of a device that had some type of additional wear and tear or manufacturing defect compared to others...
  7. nudriver
    nudriver Member
    283
    32
    los angeles
    It can be taken out? Why would it break prematurely? No wear and tear just usual use. How long do these things last?
  8. PriusCamper
    13,451
    5,430
    Maybe @ChapmanF can elaborate on an explanation better than those of us whp have already tried?
  9. ChapmanF
    19,009
    Has anybody tried unplugging the touchscreen ribbon cable, swabbing the end with contact cleaner, and plugging it back in?
    Could require a visit to the calibrate-touchscreen screen afterward.
    PriusCamper likes this.
  10. Mendel Leisk
    42,330
    I despise touch screens, about as much as I hate teflon.
  11. PriusCamper
    13,451
    5,430
    Yes... Cleaning and inspecting always needs to be the first step!
  12. PriusCamper
    13,451
    5,430
    They probably don't like being touched by you either!
    Mendel Leisk and nudriver like this.
  13. ChapmanF
    19,009
    Teflon has never liked me.
  14. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Quotes archive gold!!!
