"Touring Package"
Discussion in 'Gen 2 Prius Main Forum' started by mosesk, Feb 23, 2013.
  1. mosesk
    mosesk Member
    124
    17
    Ventura County, California
    First post so I hope it's in the right place.
    What specifically does "Touring Package" mean?
    How does it differ from "Package 6" in the Gen 2 Prius?
    Does it add or subtract any features that Gen 2 have?
    Thanks
  2. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    AS I am in the UK I cannot report on the different package levels in the US, but I know the touring version has the firmer suspension and 16 inch wheels as used in the UK and Europe as against the 15 inch wheels on other gen2 models in the US.
    John (Britprius)
  3. Britprius
    5,194
    1,922
    Forgetting my manners, welcome to PC, lots of information and helpful people here so any questions just ask.
    It can be very helpful if you put your location in your avatar as PC is world wide and different countries and regions have different variations and systems on the Prius so making diagnosis and advice more accurate if at leased the country of origin is known.
    John (Britprius)
  4. Tideland Prius
    16,665
    It adds:
    • 16" Alloys with P195/55R16 rubber
    • Longer rear spoiler (Type B)
    • High Intensity Discharge (HID) headlamps
    • Foglamps
    Here's the list of the packages
    2G Prius (2004-2009) Standard and Optional Equipment (Some Countries) | PriusChat
  5. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    The HID headlights have had problems since they burn out and cost big bucks to fix.
  6. fuzzy1
    10,687
    Before buying, personally verify the features that Tideland lists above. In the used car market, the fraction of Prii labeled as Touring is far larger than the fraction Toyota actually built.
    I believe the Touring wheels also have 7 spokes, compared to 6 spokes on the regular Gen2 wheels. 5 spokes indicates Gen3 wheels.
  7. Tideland Prius
    16,665
  8. TampaPrius.com
    TampaPrius.com Active Member
    461
    300
    Tampa, Florida
    Sometimes dealers will swap the wheels but if you look in the driver door jam there is a sticker that has the original tire size. If it shows 185/65R15, it is not a touring model. If it shows 195/55R16, it is. Also if you crawl under the rear of the car and look at the rear shocks they will have red and pink stripes and blue paint on the springs. I have attached a picture of mine. My car is a 2007 with 127k miles so the stripes are a little faded. Also the touring model wasn't available until 2007. I have seen many 2004-2006 cars advertised as touring models.
  9. mosesk
    mosesk Member
    124
    17
    Thank you all for the great answers...
    I have found a new "home"...
  10. Bob Hahn
    Bob Hahn Wingman08
    386
    118
    Jacksonville, Fl
    Love those wheels..... Tell me about those rims, please.
  11. Britprius
    5,194
    1,922
    They are the OEM alloy rims with the OEM plastic wheel trims on top.
    John (Britprius)
  12. Bob Hahn
    Bob Hahn Wingman08
    386
    118
    Jacksonville, Fl
    Sorry, I'm not clear on that..... Are they 16, 17 or 18" wheels. And when you say plastic wheel trim do you mean plastic hub caps?
  13. Britprius
    5,194
    1,922
    Yes 16 inch wheels with plastic hub caps (wheel trims in the UK). Standard fitting for all gen2 Prius in the UK.
    John (Britprius)
  14. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
  15. xpcman
    1,302
    295
  16. xpcman
    1,302
    295
    the Touring wheels are 16 inches and they will bolt on the Gen III also. But, the standard tires ( I think 195x55) can be hard to find in a LRR size.
  17. Britprius
    5,194
    1,922
    That's why many of us that hve 16 inch wheels use 205/55/16 tyres. Much greater choice of tyres, cheaper price, and much lower RR. Also gives the advantage of greatly improved handling of the Prius.
    John (Britprius)
  18. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    It is pretty easy. Everyone should at least try.
  19. Britprius
    5,194
    1,922
    Agreed.
    John (Britprius)
  20. Tideland Prius
    16,665
    They're 195/55R16 specification. The alloy wheels are finished in gunmetal grey with the silver-painted plastic wheel cover that gives it the final look you see above.
    Here's how they look like without the plastic cover. From another PC member...
