Tow truck coming in the morning
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 16 yrs & counting, Apr 13, 2024.
  1. 16 yrs & counting
    16 yrs & counting Junior Member
    77
    24
    Oakton, VA
    Ugh. Thanks for the heads up. Will investigate.
  2. Carall
    Carall Active Member
    308
    104
    Harrisonburg, VA
    A stretched chain makes a rattle noise. I uploaded a video of what a Prius engine sounds like with a chain stretched.
    I had this problem on a Prius a few years ago, but I don’t remember what the codes were.
    I can't say for sure what the engine sounded like in the Prius I replaced the battery in because I was focused on the engine misfire and replacing the hybrid battery. I started it 2 or 3 times with the hood closed while sitting in the car as far as I remember.
    The owner can tell how the engine sounds in her Prius.
  3. 16 yrs & counting
    77
    24
    Oakton, VA
    Thankfully my Prius doesn't sound like that, and there is no check engine light. Car is running well with better acceleration since Carall replaced the battery. I replaced the cabin air filter and dumped a bottle of Chevron Techron Fuel System Cleaner in the gas tank this morning, so hopefully we're good for a while.
  4. Carall
    308
    104
    Harrisonburg, VA
    I cycled the battery once and this is the capacity of four modules.
    I wanted to check the capacity with the 4-channel charger again, but when I was trying to connect the 3rd channel, the battery shorted through the charger and now it is dead. Next time I will remove the bus bars from at least one side.
    I'll test the battery with a Dr. Prius app when I get a chance.
    Module voltages before discharge-charge cycle:
    Module 2: 8:40 (1st test 8.42v)
    Module 3: 8:32 (1st test 8.39v)
    Module 15: 8:41 (1st test 8.39v)
    Module 22: 8: 40 (1st test 8.35v)
    The capacity of these 4 modules
    Module 2: 7100mAh (prior 637 mAh)
    Module 3: 7116mAh (prior 490 mAh)
    Module 15: 7370mAh (prior 508 mAh)
    Module 22: 6837mAh (prior 527 mAh)
