Tow Truck Driver Reverse Polarity Jumpstart
Discussion in 'Generation 1 Prius Discussion' started by Cleoprius, Dec 27, 2021.
  1. ammdb
    ammdb Active Member
    288
    119
    Indianapolis
  2. ammdb
    ammdb Active Member
    288
    119
    Indianapolis
    For those interested, this video shows the DC to DC converter in the Gen1. Removing it doesn't provide access for disassembly of a relay block.
    If the converter is bad, this would be one reason for not getting the 14V DC from the engine to charge the 12V battery, but we already know the reason the battery isn't getting charged is the blown 100A fuse.
  3. Q*bertZ
    Q*bertZ Member
    167
    greenville south Carolina
    2002 Prius
    All Gen 1s look the same. I have 3 2001s, 5 2002s, and 2 2003s. They all look the same.
    ammdb and Cleoprius like this.
  4. Cleoprius
    Cleoprius New Member
    26
    2002 Prius
    If the converter is bad, this would be one reason for not getting the 14V DC from the engine to charge the 12V battery, but we already know the reason the battery isn't getting charged is the blown 100A fuse.[/QUOTE]
    That was a really informative video showing the differences between the generations of inverters/converters. The professor also emphasizes how difficult it is to get the inverter out, so if its removal is not even needed, all that labor would take a lot of time and effort.
    I was impressed by the comparisons and how sophisticated this technology is.
    I’m also very impressed by how helpful you and so many other people here have been! Thank you!
    ammdb likes this.
  5. ChapmanF
    19,027
    Well, there's a big difference between (1) undoing all of its electrical connections and coolant hoses and fully removing it from the car, and (2) undoing the four or so mounting bolts and shoving it aside for more room to work. People sometimes do (2) in order to work more easily on things in that area under the hood.
  6. Cleoprius
    26
    2002 Prius
    Exactly! I refused to pay so much for replacing the 100 amp fuse.
    The upshot was:
    I texted the service department manager last Friday:
    “I've learned the 100 amp fuse can be replaced without moving the inverter so I cannot agree to your estimate for replacing it. I had specified the electrical diagnosis needed to be comprehensive. It hasn’t been. I will need a courtesy ride to come up tomorrow.”
    Response: “It is not drivable.will need to be towed out.”
    I wrote: “I understand.”
    Response: “We will stick with the original $225 diagnosis.”
    I thanked him, and asked whether the car had been made to run with the original battery. He wrote: “it had a jumper on it and a jump wire from the 100amp fuse.”
    He didn’t answer my question about whether trouble codes had been generated. However, from what’s been said here earlier, the weak battery would not have been reliable for generating trouble codes.
    I took a bus to get there very early on Monday morning, paid the $225 plus tax, and called AAA to tow the Prius. Interestingly, the tow truck driver *was* able to jumpstart the Prius and get it started, so it *was* drivable after all, which helped it get on the flatbed. (He had first checked the 100 amp fuse, so he appeared knowledgeable about this Prius generation.)
    The Prius was towed to an auto repair place that I had worked with before which happened to be near by. The owner/mechanic replaced the 12v battery and the 100 amp fuse and charged me for less than 1.5 hours of labor. Total cost was less than $500.
    When I drove the Prius away, after about five to ten minutes, trouble codes came on (the triangle and check engine light), so I drove back right away. He checked the codes from the OBD, which were about the hybrid batteries being unbalanced, told me he’d seen these before when the hybrid car had been sitting for too long while the driver was away on vacation, and added that sometimes they will come back with additional driving. He suggested I keep driving the car and come back to get the codes cleared if they came back on again.
    I did so and the codes came back on pretty quickly. I started paying more attention to that information screen that shows whether energy is getting into the battery.
    After I drove back again the next day to get the codes cleared, I learned from him that the Prius can still keep functioning with its gasoline engine even if the hybrid battery quits, giving me time to get the hybrid battery replaced. He thought the car was in pretty good shape otherwise and could easily keep going another five to ten years (if the hybrid battery is okay or replaced). I asked about testing the cells of the hybrid batteries, and he clarified that this hybrid battery doesn’t have individual cells, so if it fails, the entire battery would have to be replaced, unlike the 2004 and later batteries.
    He thought someone did a reverse polarity jump that blew out the 100 amp fuse. I don’t know which individual would have done that. I’m very relieved to have a working car again.
    It’s really interesting to see what kind of driving charges the hybrid battery. Going downhill, for example, seems to charge it longer. I was able to drive it home without the codes showing up again but plan to drive it today to charge it up.
    So:
    The initial $225 diagnosis from the service department had *not* determined that the 100 amp fuse had been blown.
    It had estimated a charge of $1548 to replace the 100 amp fuse, $675 to do a complete electrical diagnosis, over $400 to replace the 12v battery, and over $3100 to replace the hybrid battery. There was a text saying it might not be worthwhile to fix up the car.
    It had told me the hybrid batteries had failed but this interpretation may have been due to using the weak 12v battery to start the car. It didn’t provide the trouble codes.
    The service department was wrong about the car not being drivable, although it looked like a portable battery would have been needed to keep it going.
    My guess is that no one who looked at my Prius there was a certified Prius technician or much actual knowledge of Priuses. If I ever have to use a Toyota service department again (because I’m too far away from the good mechanic here), I’ve got to remember to ask whether they have a certified Prius technician there, and ask for only that person to work with the car.
    The input I got here on PriusChat was invaluable! Truly made a huge difference for me in figuring out what to do. I really appreciate other people’s willingness to help me here.
    I’d welcome other tips on what kind of driving techniques to use for charging the hybrid battery up more quickly and reliably. I realize it may need to be replaced, but it turns out that it has fewer than 140,000 miles on it, so there’s still a chance it could come back.
    I might bring it to another place that specialized in Priuses. The fuel economy had dropped quite a lot over time, and I’d like to know what can improve it. Or could that be a sign of the hybrid battery getting less effective?
  7. rjparker
    rjparker Tu Humilde Sirviente
    11,116
    6,974
    Texas Hill Country
    Reduced mpg is a clear sign of a bad hybrid battery. Mpg is the primary reason the hv battery is there. It is designed to capture otherwise wasted energy when braking and going downhill. The hv battery allows a reduced power engine design to be supplemented with "regen" battery power. If you want to keep the car, change the hv battery. You will get more power and mpg.
    Sounds like the dealers left the 100 amp bypass jumper in which allowed your tow truck driver to start the car. As I said before, the dealer mechanics know how to bypass a blown 100 amp fuse in a matter of minutes. That bypass would have allowed them to run the car for 30 minutes hoping to recharge both batteries. At that point the hybrid battery was good enough to start the engine and may still be barely adequate. Given its age the hybrid battery is testing bad and throwing codes. Dealers don't like to leave that scenario as it points a finger at them if it strands you in the next few weeks or months. So they recommended a new hv battery. There are lower cost options. The one I like is all new cells installed for less labor by an independent.
    #67 rjparker, Jan 12, 2022
  8. Cleoprius
    26
    2002 Prius
    The non-Toyota mechanic had told me that the 2002 hybrid battery cannot have its cells replaced; it’s one complete unit. (I don’t know if that’s the case or not.)
    Previously, the Toyota service advisor had written: “according to the health check scan, the hybrid battery show healthy.”
    If I recall correctly, someone had written here that using a depleted 12v battery to run the engine could have led to the hybrid battery getting depleted and appearing to fail. Since the hybrid battery had just checked as healthy, that had seemed to account for the contradictory information.
    Probably my best bet is to get the Prius checked at a shop that has an excellent reputation, like Luscious Garage in San Francisco.
  9. rjparker
    11,116
    6,974
    Texas Hill Country
    [ QUOTE ]
    Not true. You can buy the cells on Amazon, you can use gen2 cells in a gen1, the options are many.
    Obviously a mistake as well. Particularly after they tried to charge it and failed. At that point they recommended a new hybrid battery.
    There is a situation where a depleted 12v battery will force the high voltage system to excessively charge the 12v battery costing you mpg. This can be solved with a new 12v battery but is not an indicator of the hv battery health. It is important to note that a 12v battery by itself can not run the hybrid system without a barely adequate hv battery. A hv battery that is totally depleted won't start your car, stranding you
    I agree with that idea. You will get confirmation of what the car needs. Maybe not the lowest cost option but likely more cost effective than a Bay Area dealer
    [/QUOTE]
    Discussion:
    Toyota did not make many 2001-2003 Prii. That generation was twenty years ago. Many of today's dealer mechanics were in grade school at the time and virtually all of them rarely see Gen1 cars needing repair. Primarily because few Gen1s still exist and secondarily because second and third used car owners rarely take their cars to a dealer for repairs.
    Clearly your dealer was quoting "by the book" which means a longer, safer procedure where the mechanic removes more parts and replaces more things, by the book. Obviously, over a period of time, people find shortcuts and the owner who uses an independent shop benefits. At the dealer, the informed mechanic might take shortcuts but he is paid fixed "book hours" of labor. Dealer labor hours by the "book" are longer and the service advisor is usually on commission. A dealer is great when your car is under warranty, maybe not so great when the customer is paying the freight.
    Guest Editorial:
    Finally, there are a few of us on Priuschat who have owned and maintained these cars for 15-20 years. Some are well educated, decent researchers, lifetime learners and have the ability to see patterns while negating noise. Many Priuschat pundits possess a few of those attributes, some believe things that are not proven or worse yet, some offer answers that are not true at all.
    Priuschat, as a forum, is not strongly moderated to clean up some of this problem. This forum does not allow a member to correct misleading information after a few hours, further complicating the integrity of the information. Other forums do better in their areas, but there is not a bigger Prius forum than this one. So conflicting and just plain wrong information is common here and is allowed to propagate.
    #69 rjparker, Jan 12, 2022
  10. ChapmanF
    19,027
    I think that boils down to the way the 'edit' button locks itself out after so many hours. It's still possible to add a followup post to a thread with the corrected information ...
    ... which is why, any time you pick up some claim from a post in the middle of a thread ... it is a good idea to keep reading the thread, to see if the information ever got corrected later.
    The "can't edit" doesn't seem to be an inescapable rule either; there have been times where I noticed that I posted something especially dangerous, like a part number with digits swapped, and I've made a report to the mods saying "please change the part number in this post to -xxxxy", and it happens. Naturally, I try not to bother the mods for every sort of edit I might otherwise make, like if I just thought of a better way to word something.
    There wasn't always that edit lockout. If I remember the history right, there was once a member who had made lots of posts with very useful information, then got peeved with the forum and left, but not before editing and erasing every post they had ever made. So now it seems like we have this kind of inconvenient rule, meant to protect against something that only one person ever did and probably only one kind of person ever would do. But it was high impact....
  11. Mendel Leisk
    42,352
    And you can quote your erroneous posting, and note the post number, helps clarify.
  12. Cleoprius
    26
    2002 Prius
    Sadly, the codes for the Prius down to me by the independent mechanic were P3000 and P3006. I found the following gloomy write-up:
    https://lusciousgarage.com/blog/gen_1_prius_battery_failure/
    I had gone to the Toyota department in the first place because I had suspected I might need to replace the hybrid batteries, and if I did, I had thought it would make sense in my case to buy some that had a national warranty, which only Toyota seems likely to be able to provide.
    Still thinking about what to do. The estimate from the Toyota service department for replacing the batteries had been under $3200.
  13. ammdb
    ammdb Active Member
    288
    119
    Indianapolis
    If it's the original pack, replacing cells isn't an option. Gen1 cells aren't as good as newer generations, and even back in the day the advice was probably not worth replacing them. Now any you may find on-line are most likely pushing 20 years old. Gen2 cells are better, but all 38 will need to be replaced and they're still used.
    Your old pack is worth around $1300 as a core when purchasing a new Toyota pack. which can be picked up from the parts department and installed by anyone that knows what they're doing. The $3200 quote doesn't sound like a terrible price, but you might find a better deal at an independent hybrid shop. I've read one advantage of having Toyota install the pack is it will have a longer warranty.
    My experience is the cost savings from buying a remanufactured after market pack doesn't always add up, because they're only as good as their warranty, where as a new Toyota pack will last another 10 or more years.
    #73 ammdb, Jan 12, 2022
  14. AlexY
    AlexY Member
    163
    45
    UK
    Happy to read it is at least again on the road. You should get some cheap OBD bluetooth adapter and dr prius app for phone or tablet to keep an eye on your battery. Get your car running for few hours, it will try to rebalance cells but I have no idea what is condition required to do that, I noticed in my gen1 this is done at least 20 minutes after car is started. Most likely it will not fix the battery anyway.
    Yes it can but car is very weak and struggle with little uphill. Very unpleasant.
    It does have individual cells, in case single cell replacement, gen2 cell have to be used and it have to be slightly modified, also bus bar need to be made out of piece of copper because gen1 module is a bit shorter, I did it 3 times in my 2001.
    If it was official Toyota garage they followed manufacturer's repair manual, they have to, that's why 100A fuse replacement cost is so high.
  15. rjparker
    11,116
    6,974
    Texas Hill Country
    I would still call Luscious and get their price or referral on a new hv battery. You have several Bay Area options including the shop that installed your 100 amp fuse. If they can do that they can change a hv battery.
    You might call Gasketmasters in the Bay Area and ask for a battery referral as well.
    Some Toyota dealers around the country list a new Gen1 battery for around $1800 if you have an independent installer. I would try to negotiate with your dealer based on those prices.
    Greentec in Hayward offers new batteries for a 2001. They also sell used replacements marketed as reconditioned or remanufactured. If you want to drive the car longer than a year or you value reliability, go with a new battery. Toyota Prius 2001-2003 Hybrid Battery with NEW Cells | Greentec Auto
    #75 rjparker, Jan 12, 2022
