Towing a Prius Prime behind an RV
Discussion in 'Prime Main Forum (2017-2022)' started by Mooney Driver, Aug 10, 2023.
  1. Mooney Driver
    Mooney Driver Junior Member
    Here is a Toyota instructional video relating to towing a Prius with a tow dolly. It looks to be made around 2016, and it recommends that the ignition be in the "accessories on" position and parking brake off. It does not say if the vehicle needs to be in neutral if it is an automatic transmission. I believe the accessories on is required to unlock the steering while towing. I plan to be towing the vehicle across country sometimes driving 8 hours under tow, Not sure if extended periods with the ignition set for "accessories on" will lead to a dead battery after 8 hours of travel. This is why I would like someone who has towed a Prius to chime in on how they set up the vehicle while towing. Specifically, should it be in neutral with an automatic transmission? Do I have to put ignition into "accessories on" position with a model 2021 Prime or is the steering not locked in that model when turned off?
    Thanks.
  2. Mooney Driver
    Sorry, here is the link to the Toyota instructional video :
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,119
    6,977
    Texas Hill Country
    1. The main confusion I have centers around the parking brake and whether I should turn ignition to accessory position? Some say to release the parking brake where others say to engage the parking brake/? which is it?
    Towing with the front wheels on a dolly is THE way for use behind an rv. Parking brake OFF.
    IF you were a tow truck driver with a flatbed, all four wheels would be off the ground. Then you would engage the brake.
    2. If ignition is on accessory position, will it significantly drain the battery even if you turn off the AC and radio? These are what I am confused about.
    YES it would. Towing behind an RV with front wheels on the dolly would be with ignition OFF.
    3. Realize there are EMERGENCY situations where you might pull the car with a chain or tow rope. With all four wheels on the ground. Not recommended but the manual addresses this case. In this emergency case, with a driver in the disabled vehicle, you turn on the ignition so the driver can steer and brake. The manual says use the ON position so the driver can steer. In Neutral. You disengage the emergency brake. Short distance 18
    mph max. This is not your use case.
    4. The situation is different if your Prius was awd. Then all four wheels have to be off the ground. Most tow truck drivers these days default to this method regardless. This is not your case.
    5. You don't have an "automatic" emergency brake so that variable does not apply. You simply release the emergency brake and tow with the car ignition Off.
    Most of the replies above are correct but first few with questions may not be confidence inspiring. Trollbait's response was wrong but he was probably trying to be funny.
    Yes I have done it. But I would suggest talking to the service manager (not advisor) or their Master Mechanic.
    #23 rjparker, Aug 11, 2023
  4. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    The video shows multiple towing styles, but then shows a graphic checklist that would really only apply to a towbar/flat tow situation. The dolly tow and full transporter tow deserve their own graphic checklists.
    I'll stop short of saying that the video is wrong, but after having watched it I completely understand why you are confused.
    Mooney Driver likes this.
  5. Mooney Driver
    RJParker, thanks so much for your reply and the fact you have towed your Prius. Your response is exactly what I was hoping for. follow-up question...why would the Toyota instructional video advise turning the ignition to "accessories on" and end up draining the battery if that's not necessary? It just doesn't make sense unless the older models had locking steering wheels that would require release to operate with tow dolly. I guess the newer models don't have locking steering and thus don't require the ignition to be set to "accessories on" position?
  6. Mooney Driver
    That is precisely why I am confused by it.
  7. rjparker
    11,119
    6,977
    Texas Hill Country
    Again, the only time the ignition would be on and the wheel would be unlocked is an emergency situation when you're pulling the car with all four wheels on the ground.
    Here is a uhaul instruction and video on the use of a towing dolly:
    Video:
    Pay particular attention at time 1:30 in the video
    #27 rjparker, Aug 11, 2023
  8. bisco
    52,863
    yeah, that key in the ignition right after showing a gen 4 prius on a dolly is really confusing
  9. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    I've rented that trailer before, and I have successfully moved a number of cars by doing exactly what they say in here.
    Your own car dolly shouldn't be any different.
  10. BiomedO1
    BiomedO1 Senior Member
    4,628
    2,426
    Left Coast
    If your using a dolly; similar to the U-haul one above.
    1. Once on the dolly and front tires strapped down. Ignition off
    2. Transmission in Park
    3. Parking brakes OFF
    4. make sure the trailer lights are working. Put your Prime FOB in a Faraday bag. It wouldn't hurt if you brought along a jump pack; Just in case.
    FWD Only!!! AWD require all four wheels off the ground.
    You may want to engage the Prime's parking brakes and drag it for 20 yards. That way you'll know what it feels like, if you forgot to release the parking brakes. You'll find that you will need to get the RV's RPMs up quite a bit to get it going - but at least you'll know something is wrong; before you fry the rear pads on your Prime.
    Have a safe trip....
  11. sylvaing
    sylvaing Senior Member
    1,221
    517
    No need to. Just temporarily deactivate the FOB
    Key Fob deactivating | PriusChat
  12. Mooney Driver
    I have an Acme tow dolley. In their instructional video they do NOT use a seat belt harness to tie down the steering wheel unlike the uhaul video shows. When you use your tow dolley to tow your prius do you tie down the steering wheel or not?
  13. rjparker
    11,119
    6,977
    Texas Hill Country
    No. Just the automatic steering lock like the instructions shown above indicate.
    #33 rjparker, Aug 13, 2023
  14. BiomedO1
    4,628
    2,426
    Left Coast
    No need to, once the front wheels are in the dolly wheel pockets and strapped down. The steering wheel, anti-thief lock will keep the wheels straight. The only way for the car to start crabbing, while being towed - if you angled the car onto the dolly. I believe you'd have a very difficult time strapping down the tires.
  15. hill
    9,039
    You never say what your motorhome is rated to tow? Our turbo diesel motorhome can 'tow' 7,500 lb. The Chevy Volt we tow front wheels up is thousands of lbs less.
    Also, don't forget to account for the vehicle payload. That becomes part of Towing equation as well
    #35 hill, Aug 14, 2023
