Towing zero turn mower with Prius??
Discussion in 'Gen 3 Prius Main Forum' started by eddiehaskell, Aug 26, 2017.
  1. eddiehaskell
    eddiehaskell Member
    233
    51
    Charlotte NC
    I have one of the foldable harbor freight 4x8 trailers which is maybe 375lbs. I've pulled some small loads with it, but now I need a new mower for my own yard and my parents yard. Looking online, the 42" zero turn mowers are 480-500lbs. Add in fuel, trimmer, blower and that's about 550lbs of cargo. 550+375 = 925lbs. Would you feel comfy towing 925 lbs with the Prius. I'm 150lbs + 75lbs for the hitch so a grand total of 1150lbs.
  2. CNYhybrid
    CNYhybrid Member
    158
    83
    Liverpool, New York
    GrGramps likes this.
  3. CNYhybrid
    CNYhybrid Member
    158
    83
    Liverpool, New York
    It would also help if you could calculate the tongue weight.
  4. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Agree, if it's flat and at night, like 3am, stopping going fast downhill would be problematic, why possibly get hit from behind, rent a truck at Home Depot, get them to deliver,
  5. bisco
    52,782
    flat, slow, short, no problem. slow acceleration and braking.(y)
  6. William Redoubt
    William Redoubt Senior Member
    1,228
    1,174
    Coronado Island, California
    This would be no issue with the trailer or the car, however if it has small tires and wheels you will want to keep your speed down. I assume the trailer is rated at 1000 pounds for the load.
  7. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Of course, we do not recommend doing this while mowing the lawn ;)
  8. eddiehaskell
    eddiehaskell Member
    233
    51
    Charlotte NC
    Pretty flat land. Live near Charlotte. Maximum distance traveled would be about 10 miles at below 50 mph. No highway driving.
    The trailer I have is rated for 1,195 lb.
  9. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Right from the start, "towing is not recommended for the Prius" from Toyota.
    -However-, such a light load and such a short distance should be no problem.
    m.wynn likes this.
  10. William Redoubt
    1,228
    1,174
    Any car that is capable of hauling fat chicks and/or guys that could be stars on a pawnshop or tow truck reality show can pull a small trailer without an issue if it is properly loaded. And the Prius IS rated for the fatty's.
    herqulees likes this.
  11. William Redoubt
    1,228
    1,174
    You won't even notice it. :) And neither will the car.
    garglo likes this.
  12. ILuvMyPriusToo
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Sometimes towing a mower is better than trying to load it in the hatch!
  13. William Redoubt
    1,228
    1,174
    That mower would fit right in the back of the Prius! Probably close the hatch, too.
  14. garglo
    garglo Member
    99
    45
    Port St Lucie, FL
    2020 Prius Prime
    I've used the same trailer to tow from NY to FL with a gen2. Loaded at least 1000 in it, 100-120 on the tongue, had to look see if it was still there. Needed a 5in rise to get the level correct.
    William Redoubt likes this.
  15. frodoz737
    frodoz737 Top Wrench
    4,791
    2,559
    33
    I pulled "a lot" more than that for +12 hours straight. Don't know about your trailer, but the car can take that load.
