Toyota 0W-20 Motor Oil Not Available
Discussion in 'Gen 3 Prius Main Forum' started by Rickinohio, Feb 1, 2023.
  1. qdllc
    qdllc Senior Member
    1,377
    400
    The only Toyota brand stuff I buy is the coolant and transmission fluid. Just because it’s changed rarely and no chance of the formulation not being OEM. I use Amsoil on the Prius.
  2. Matth Torrijos
    Matth Torrijos Active Member
    119
    212
    Poway
    I use Motul Hybrid Oil. Gets better MPG on my prius
    Tbkilb01 likes this.
  3. Tbkilb01
    Tbkilb01 Active Member
    218
    187
    Louisiana
    Goes for 10K+ miles
  4. douglasjre
    douglasjre Senior Member
    2,219
    742
    Null, NL
    You'll only get 190,000 mi out of your third gen and it has less to do with your choice of oil then more to do with the head gasket popping and the need for a hybrid battery shortly thereafter as well as a radio and an unfortunate accident that none of us ever see coming and lots of other life factors. Mobil one Pennzoil Platinum Castrol synthetic, they're all great. Kirkland and Walmart oil are probably okay too
  5. Matth Torrijos
    119
    212
    Poway
    I think so. I change my oil every 5k
  6. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Don’t let asrdogman See this reply!!!
  7. Tbkilb01
    218
    187
    Louisiana
    I had my 2010 fully serviced, head gasket, tune
    Up, battery rebuild...ready for another 200K .... let daughter use it... bamm.. front end got smashed... now
    It’s
    A parts Car
    ... so yea, treat em special while you can ...especially 3rdGen ..they are special! Change that oil regularly with quality oil...plus plan maintenance projects... don’t wait for repairs!
    Get to know your vehicle...
    I had been purchasing them used, with a budget allowed for 6K... before pandemic fib...service them and then drive em daily... had 3 running...down To 2.. all vehicles need repair soon or later... Recently raided the egr, intake, accumulator, brake cylinder and a wheel off The 2010 forMy other maintenance needs on 2011’s so yea it’s still giving... plan to disassemble engine bay and electrical parts, Sensors, etc and then log em and shelve Em ... parts for later use or
    Sale to other needy 3rd geners...
    #27 Tbkilb01, Apr 1, 2023
    ColoradoBoo and Mendel Leisk like this.
  8. Tombukt2
    Tombukt2 Senior Member
    13,647
    2,473
    Durham NC
    Toyota oil comes in bulk oil drums from a local supplier in their town I'm pretty sure it will not come from Toyota itself I don't think they're really in the oil business like that they purchase oil and bulk from their approved sources in whatever given countries at least that's how it's been every dealer I've worked at maybe that's changed in the last few years but I kind of doubt it because when you go to the dealer you see 55 gallon drums of oil You also see some quarts in the parts department.
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,836
    Clearwater, Florida
    The racket these little solid lifter engines make running a 20m weight oil was always disturbing to me. Sounded like a sewing machine on steroids. I am cursed with very good hearing as I lost an eye from trauma when i was a child and it seems my hearing has compensated for it. I hear things no one else hears and sometimes that's horrible lol...
    I ran a 20 weight oil once in my car and never again in my bought new 07. Ran a 30 weight oil for almost 15 years with that car no issues. With Toyota low tension rings Your way better off running a 30 weight oil. You can buy a 5 quart jug of Mobil 1 5-30 at Walmart for $25. last I looked. That's a pretty good oil and your car takes 5 quarts. With a $5 OEM filter and $25 for the oil your at $30 for an oil change + labor.
    That's pretty good.
    ColoradoBoo and Tbkilb01 like this.
  10. Mendel Leisk
    42,058
    Sifting through your voice-dictated rambling, I think you're saying Toyota bulk oil is "any oil"? I don't think that's true. Not that I know much more, but my take is it is a specific oil, manufactured and quality controlled. It's all I used up till about 2 years back, when the price went through the roof and they (local dealership) finally refused to sell it to me in bulk.
    Tombukt2 and Tbkilb01 like this.
  11. Tombukt2
    13,647
    2,473
    Durham NC
    In the US you go over to the Toyota dealer and just look at the drums sitting over there in the designated area You can walk over there and look at them and read the labeling on the tops of the drum I'll go take some pictures next time I'm over there It comes from the local oil distributor I do believe they have 020 030 straight 30 weight a few others here and there I'm not saying it doesn't come from Toyota but it looks to me like it comes from a place like MM Fowler oil company which is the local BP Sunoco and whatever is under that umbrella dealer they selling 55 gallon drums down to quarts stock local convenience stores and all of that matter of fact this company owns convenience stores since it got out of gas stations. But anyway it's all good that's in the States now in Canada things may be different at least in appearance they may not let you near the oil drums in Canada I have no idea
  12. Mendel Leisk
    42,058
    Maybe that's your local (more unscrupulous than usual) Toyota dealership.
    Here the price did go through the roof though, making it more expensive for me to bring-my-own-bottle, get their bulk oil. Which is nuts.
  13. ASRDogman
    ASRDogman Senior Member
    7,909
    4,020
    What ARE you talking about??? :whistle:
    Original: head gasket, hybrid battery, master cylinder-booster-accumlator.....
    Grit likes this.
  14. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    (y)(y)(y)(y)(y)(y)(y)(y)(y)(y)(y)(y)(y)
  15. ColoradoBoo
    ColoradoBoo Senior Member
    1,307
    922
    Monument, Colorado USA
    Yep, the oil at the Toyota Dealer is, more than likely, the same el-cheapo crap quick-lube and Walmart auto centers use. It's sad...you spend PREMO dollars for an oil change at a dealer and get the same oil you could get spending half as much money at a Jiffy Lube!
    One of the many reason I learned to changed my own oil (and now all maintenance) starting in the 80's.
    edthefox5 and Tbkilb01 like this.
  16. Tbkilb01
    218
    187
    Louisiana
    Noice
  17. Jim Caldwell
    Jim Caldwell Member
    145
    26
    Mathis
    This is commonly available at any wal mart, o reilly auto parts, and autozone stores.
  18. Jim Caldwell
    Jim Caldwell Member
    145
    26
    Mathis
    That is Mobil 1 brand. No reason to stick with oem oil! Not when M1 oil is great for a Prius....its probably better than owm Toyota.
  19. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Same here I am about to shift over to DIY on our 2020 RAV4 probably go with Mobil-1
    Tbkilb01 and ColoradoBoo like this.
  20. ColoradoBoo
    1,307
    922
    Me, too, and I've noticed the 0W-16 from Mobile isn't as clear as it used to be so they must've added a darkening agent. I like that, the clear stuff made reading the dipstick very difficult unless you're in a bright light.
