Toyota Acknowledges Design Problems In 2010 Prius Brakes, Modified Models Built After January
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by dammitdex, Feb 4, 2010.
  1. web1b
    web1b Active Member
    817
    52
    It isn't a big deal as long unless you are doing an emergency stop and the extra stopping distance makes the difference between having an accident. Even an extra 10 feet could make the difference.
    According to CNN, at highway speeds, it could add 90 feet, so even at much slower city speeds it could be a problem in an emergency stop. The brake delay could either cause an accident or make an accident that was unavoidable even if the brakes worked perfectly worse because the car didn't slow down as much as it should have at the point of impact.
    Just because 99% of the time a few extra feet of stopping distance won't make a difference in your daily commute, doesn't make this problem a non-issue that should be just ignored.
    Toyota: Software to blame for Prius brake problems - CNN.com
  2. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    Re: The Woz Knows What He's Talking About- Toyota Admits Software To Blame For Prius Problems
    Reading comprehension issues here. Wozniak is still a dope because he didn't RTFM. Did many in your clan get past 6th Grade?
  3. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    I think an SSC will be issued for the brake ECU program update.
    Ken@Japan
  4. pjksr02
    pjksr02 Active Member
    532
    227
    Connecticut
    ...did someone just say "Swine Flu"? :flypig:
  5. hitechboy
    hitechboy New Member
    128
    Toronto, Canada
    I see this in a different way:
    After the series of evens happen over the last 2 months:
    1. Fixing the lose carpet problem with zip tie?:confused:
    2. Keep public in the dark of the problem on the gas paddle for a week. (They setup a recall without any fix ready!?:mad:)
    3. Quietly fix the dangerous 6 years old Prius brake problem and try to hide it to avoid costly recall.:mad:
    I totally lost my confidence with Toyota.
  6. DeadPhish
    2,010
    353
    Neither statement you made above is applicable.
    1. It's not an issue at highway speeds, only at low speeds.
    2. In an emergency stop at low speeds it's not an issue either because the Brake Assist and hydraulic brakes bypass the regeneration mode.
    In fact in Toyota's statement today they said that the way to avoid the issue is simply to press harder on the brakes in order to bypass the regen in order to get to the hydraulic / friction braking quicker.
    Read:
    Toyota Says Prius Brakes Had Design Problems - NYTimes.com
  7. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    No, to totally lose confidence with Toyota you need to ring their next to useless UK Recall Helpline which is based in Africa. Losing the will to live doesn't come close!
  8. DeadPhish
    2,010
    353
    Gosh I get so excited by unemotional fact-based boring posts. :D
  9. DeadPhish
    2,010
    353
    Noted. OTOH on my Gen 2 with 142,000 miles I couldn't be happier. We move on.
  10. Jim Clark
    Jim Clark Member
    310
    22
    Northern VA, the 51st state (someday)
    In every car I've ever owned, if you held the accel button until reaching your desired speed and then released it, the acceleration would stop. If, as you say, holding the accel button sends a "series" of requests that do not stop when the button is released, that is a serious safety issue. I haven't tried it in our Prius yet, I rarely drive it and the wife never uses cruise control. But I'll try to make it happen next time I have it on the highway in light traffic.
  11. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Sure pick on the poor FUDster, just because he can't tell stop from go. He is not going to get anywhere in his job to sabotage Toyota if he sticks to facts.
  12. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    It's quite refreshing after all the hysteria and assumptions.
  13. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    This confirms our theories and speculation: the drop-out occurs during the transition from regenerative to friction braking, where friction braking comes in too lightly to fully make up for the loss of regenerative braking. Toyota also confirmed our workaround, which is to press harder when the drop-out occurs.
    It's good that Toyota has formally identified the cause. While not a dangerous problem, it certainly is disconcerting and diminishes the driving experience. Tweaking the control software should improve the response.
    Tom
  14. web1b
    web1b Active Member
    817
    52
    People say the problem with delayed brake response is often caused when braking after hitting a bump such as a pot hole or manhole cover. Does the brake system become confused or knocked out of service for a split second when jarred by bumps in the road?
  15. Danny
    Danny Admin/Founder
    7,093
    2,120
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    I think it's funny how it takes the mainstream media an extra 12-24 hours to pick up on a story. I relayed this information from ken1784 yesterday about the brake ECU update:
    Toyota's Next PR Nightmare: Prius Brakes | PriusChat
    It's simply a software change to address the inconsistent feeling that new owners have between a Prius and a traditional ICE car.
    And CNN is full of crap saying it adds 90 feet of braking, especially since the issue is not at highway speeds.
    5 people like this.
  16. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    That's my guess too. :(
  17. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Since you have managed to figure out the hyperlink feature, perhaps you can move on to the Search function.
    Homework: find the article - either here on Priuschat or via Google - in which Woz describes problems with his brakes.
    Assignment will be due in two days. Keep us posted on your progress.
  18. LulzChicken
    LulzChicken Prius Enthusiast
    791
    135
    Alabama
    Woz admits that it was user failure with the cruise control. I'll post an article once I get home regarding.
  19. DeanFL
    DeanFL 2010 owner - 1st Prius
    1,015
    355
    Leesburg Florida USA
    I've had my 2010 V since June and very happy with the car. I was a PriusChat junkie months before purchase and months after. But over the last few months found the forum to be repetitive and, honestly, boring. But I had reviewed some of the postings over the past weeks and must comment:
    1. Shame on Toyota. It appears the planets aligned on these supposed technical issues and they are paying the price. And it may be dear.
    2. Shame on NHTSA. This government agency was virtually rudderless (no leadership) for well over a year. This, and typical politics, allowed past investigations to be swept under rugs. Now they are IMO over-reacting and CYA-ing. Witness LaHood's stupidity of a public comment yesterday.
    3. Back to Toyota - another shame. Exec management states they would never put growth or revenue above safety and quality. Current events may well disprove this.
    4. Media - especially U.S. media. Sharks in the water with "Foreign blood". And U.S. Feds protectionism. And promotion of Big 3. Of course this is big news, but perhaps quite overblown, irrational, and inaccurate at this point.
    This all said - Toyota BETTER design a program to fix the braking issues with 2010 Prius shipped pre-Jan. I cannot see them stonewalling on this loyal group at this time. I have felt the braking sensation a few times (minor) and very thankful for the Forum to share information and educate me and others.
    But I expect and demand a fix from Toyota for this potentially damaging issue.
    I'm tempted to report the defect to NHTSA - not to pile on, but to substantiate the problem.
    2 people like this.
  20. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    A picture is worth 1000 words....
