Toyota Approves Use of 0W-20 and 5W-20 GF-4 Oils
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by etyler88, Oct 17, 2007.
  1. etyler88
    etyler88 etyler88
    450
    Dover, DE
  2. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    So what is being referred to with the
    NOTE:
    For Prius vehicles, refer to TSB No. EG050-04, "Engine Oil Specifications."
    Inquiring minds want to know. :)
  3. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Yeah I'd like to see that TSB too. In what's posted above it says all Toyota and Scion vehicles then in another place the same document says except Prius??? Looks like it was written by the government LOL.
  4. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    My FJ Cruiser falls under the tsb to allow an xW-20 oil. Considering how badly it shears an xW-30, I'm leery to try that science experiment
    The Prius is not covered by this tsb, we're still supposed to use an xW-30.
    However, I have been using Mobil 1 0W-20 in my Prius with very good used oil analysis results. In very cold weather, say -30 C and colder, it does seem to gain around 2 MPG. No difference in fuel economy in mild weather
  5. dogfriend
    7,512
    1,185
    Carmichael, CA
    <div class='quotetop'>QUOTE(Sufferin' Prius Envy @ Oct 17 2007, 02:28 PM) [snapback]527086[/snapback]</div>
    [attachmentid=12100]
    Note that the Prius engine designation is 1NZ-FXE . Is it considered to be part of the NZ series?
  6. Sufferin' Prius Envy
    3,998
    <div class='quotetop'>QUOTE(dogfriend @ Oct 17 2007, 10:55 PM) [snapback]527224[/snapback]</div>
    Thanks!
    So, if I am reading things correctly, it looks like they recommend the ILSAC GF-4 for the Prius, but still only in 5W-30 viscosity.
  7. etyler88
    etyler88 etyler88
    450
    Dover, DE
    Thanks for getting the TSBs in there. I did not see the note on the first TSB with note for Prius. OK continue with 5w30 .
  8. dogfriend
    7,512
    1,185
    Carmichael, CA
    <div class='quotetop'>QUOTE(Sufferin' Prius Envy @ Oct 18 2007, 12:44 AM) [snapback]527239[/snapback]</div>
    That's how I interpret it. Certainly, in Sacramento, with our hot weather in the summer I think that it is best to stay with 5W-30.
