Toyota Aqua navi "nszt-w62g" language change
Discussion in 'Prius c Accessories and Modifications' started by lkman, Oct 3, 2014.
  1. lkman
    lkman New Member
    Sri Lanka
    2013 Aqua
    Hi all,
    I am from Sri Lanka and bought a 2013 Toyota Aqua G. It has a display named "nszt-w62g", which is similar to below images.
    When I click "A V Power" button on the right bottom, it shows a menu with AM & FM, SD, CD/DVD, DS, BT etc.
    Working fine parts:
    1. This display shows the video of backward side if I put vehicle to "Reverse" and it is working fine.
    2. Radio is working fine
    Questions:
    1. I would love to know how to change the language of this to English.
    2. TV has Japanese channels configured, but I am unable to find the way to search TV channels in my country.
    3. When I click BT (bluetooth), it shows a phone. But even though I started bluetooth on my Android phone, I am not sure how to start a scan on this display so that I can pair the phone with car.
    4. When I open the display, it has space to insert a DVD and two move slots to insert "Music" and "Map" as shown below (just below DVD slow). Another closed square named B-CAS. I am not sure what to be inserted into the "Music" and 'Map" slots.
    5. SD menu is disabled, but not sure what is it used for?
    Sorry for raising a number of questions, but I am unable to use most of the features available on this.
    If you could provide me with some information, it will be a great help as I am completely new to this.
    Thanks in advanced.
  2. yushi
    yushi New Member
    Colombo
    2013 Aqua
    i can answer 5th question and 4th question partially.
    4. you can insert a SD card with music files in it (like mp3) also the player identifies the directory hierarchies as well. this is the purpose of "music" slot. "map" slot is used to insert the SD card which contains the MAP.
    5. when you enter the SD card in "music" slot SD menu will be enabled. you can switch between your SD cards using the touch screen. but i do not know the player works without the "map" SD. did not try that
    hope this will help
  3. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    You'll often find that the JDM vehicles don't have the option for multiple languages like international models do.
  4. GregP507
    GregP507 Senior Member
    3,002
    481
    It would be helpful if you could find a model number, and provide more photos.
  5. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    As far as the TV. In Japan, I believe they use a different broadcasting standard than Europe, NTSC instead of PAL. If that is the case, the encoding and possibly frequency settings may make that option useless to you.
  6. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    We haven't had PAL for about 5 years now. I think it's more to do with the FM radio as Japan use a slightly different band to most of the world, but it's mainly that a JDM vehicle will be strictly a Japan only model and rarely has multiple language and character options. Sometimes it's possible to replace the unit with a US or European one, sometimes not.
    FM broadcasting in Japan - Wikipedia, the free encyclopedia
    Eclipse1701d likes this.
  7. Upul De Silva
    Upul De Silva New Member
    Colombo, Sri Lanka
    I have the same set. same problem. Would be glad if any one can help.
  8. DJ Q
    DJ Q Junior Member
    Trinidad & Tobago
    Great news for anyone with this head unit!
    I've managed to get the SD Card with the program needed to unlock most of the deck's features!
    It's an amazing head unit with many, many features. I'm still in the process of figuring things out.
    Will get the card out of the car and upload the files during the day today
    Zakir Ahmed and ariuka like this.
  9. mohsin
    mohsin Member
    91
    61
    Dubai, UAE.
    2014 Aqua
    I have fair knowledge of this set, if you need assistance just ask.
    This set supports;
    Energy Monitor
    Maintanance Record
    Fuel Economy
    Blue tooth streaming
    Zakir Ahmed likes this.
  10. DJ Q
    DJ Q Junior Member
    Trinidad & Tobago
    I'm trying to post the link but I keep getting an unspecified error.
  11. Tideland Prius
    16,643
    You need a minimum of 5 posts before you can post a link. You have 6 now, so the error should go away.
    ztanos likes this.
  12. DJ Q
    DJ Q Junior Member
    Trinidad & Tobago
    Alright so for anyone that has a head unit labelled NSZT-W62G, this link will give you the program you need!
    It's a HUGE file and you will need at least an 8GB SD card formatted to FAT32 to allow this to work.
    https[colon]//mega[dot]nz/#!GIJh0YQZ!Eg0s3nJ5cWaFZexlV5qwqE6MUi97X_b0NPzQ6dW4Z9o
    I'm not sure if this will work for other models, but you can feel free to try this out.
    This does not include maps btw, so you still won't get access to the Navigation menu.
    Also, if your deck is locked, you'll need to get the unlock code before you can access anything.
    Hope this helps!
    AR Ser, Imran82 and ariuka like this.
  13. DJ Q
    DJ Q Junior Member
    Trinidad & Tobago
    Sorry for the messed up link but that's the only way I got it to post^
  14. Darren4210
    Darren4210 New Member
    Trinidad & Tobago
    DJ Q,
    Were you able to have this SD firmware work in your Prius?
    Also is there any way to possibly have the language changed from Japanese to English?
  15. DJ Q
    DJ Q Junior Member
    Trinidad & Tobago
    Darren, I see you're a fellow Trini.
    Yes this works for mine, but you need to check the model of the deck.
    Secondly, no option to change language.
  16. G.Joe
    G.Joe New Member
    Trinidad
    So, Darren and DJ Q, what do we do now about obtaining local maps so these units to be even more useful to us in TT? Any progress with that?
  17. DJ Q
    DJ Q Junior Member
    Trinidad & Tobago
    Haven't even remotely investigated that.
    There's no point in using navigation on a head unit when we have superior constantly updated things like Waze.
    ztanos likes this.
  18. mohsin
    mohsin Member
    91
    61
    Dubai, UAE.
    2014 Aqua
    1- There is no provision to change language.
    2- Map SD, is model specific SD card which contains Maps as well as operating software for this set. Try Toyota Lanka they or some other vendor can supply.
    3- Music SD means a sd card containing MP3 music files.
    4- Use smartphone + Google translate
    Press the menu knob for a second,
    Go to setting menu (last item cogged wheel icon)
    go to BT menu
    go to device registration.
    However, these options will work only after you insert the Map SD card
  19. adityakpatil
    adityakpatil New Member
    Auckland
    2002 Prius
    I downloaded the file, should i unzip it on to the SD card and use the Music or Map slot?
  20. DJ Q
    DJ Q Junior Member
    Trinidad & Tobago
    Unzip to SD card and use in Map Slot.
