Toyota Aqua navi "nszt-w62g" language change
Discussion in 'Prius c Accessories and Modifications' started by lkman, Oct 3, 2014.
  1. SERGEJ GONCARENKO
    SERGEJ GONCARENKO Junior Member
    IRL
    Hi DJ Q
    can you describe please what this file helps with?
    I have this unit, and after long research was able to customise some features of the unit, like changing default start up image, switching off default view of navi screen at the start and having radio for instance.
    next step is to purchase fm band convertor so I can use fm up to 108.
    also disabled japaneese reminders.
    But still looking for more features.
    That why I wonder what that software does.
    Tank you
  2. DJ Q
    DJ Q Junior Member
    35
    Trinidad & Tobago
    That's the software that allows the head unit to load if you disconnect the 12v battery.
    If you're already able to access the settings menu (including bluetooth) you won't need this.
  3. ariuka
    ariuka New Member
    mongolia
    2011 Prius+ MPV
    new link plzz this link is not working i really need this file plzz
    Arslan Ahmad and Imran82 like this.
  4. DJ Q
    DJ Q Junior Member
    35
    Trinidad & Tobago
    You need to copy and paste the link, replace [colon] with : and [dot] with .
  5. Chipstar
    Chipstar New Member
    Princes TOWN
    Luxury
    Hi am a new member what does this file do? And can u use a normal as card into the deck ?
  6. DJ Q
    DJ Q Junior Member
    35
    Trinidad & Tobago
  7. Adityakpatil88
    Adityakpatil88 New Member
    Auckland
    2013 Aqua
    Did exactly as you said, but the screen just says "Map data can not be read Please check map " - According to Google Translate
  8. DJ Q
    DJ Q Junior Member
    35
    Trinidad & Tobago
    What size SD card did you use?
    Same model head unit?
    Did you put it in the correct slot?
  9. Mike1987
    Mike1987 New Member
    Cyprus
    I have the same problem. I had to wait 30 sec for the sd to load and then nothing... radio and camera was working just like before. BT doesn’t work. Any help?
  10. DJ Q
    DJ Q Junior Member
    35
    Trinidad & Tobago
    There's a message that comes up but I've never translated to see what it says.
    My map doesn't work either so I'm assuming it's the same message you see. You can press AV to skip past it.
    Bluetooth settings: when you press the knob, there's a settings icon at the bottom right hand corner of the screen.
    In there, I believe the bluetooth menu is on the second screen.
  11. pdforever
    pdforever Junior Member
    30
    50
    Pakistan
    2015 Aqua
    Huh. Mine just worked when I got the car. When I turn it on, it gives me a message which sounds suspiciously like "Good morning and welcome" (which I'm basing on what I've heard in animes). The radio doesn't work beyond 95MHz or something (which is fine because my wife just listens to FM 89.0). Bluetooth works. Pairing was a huge pain until I used Google Translate to figure out which was the "Pair new device" and which was the "Remove paired devices" buttons. There are screens where you can input information about maintenance about the car, but I can't be bothered because I note that stuff on my smartphone.
    There are energy readouts (mileage and things, I guess?), but honestly, I just stick to the audio screen because that's all I really need. Or the phone screen, so that I can make and receive calls while driving.
  12. Toyo7
    Toyo7 New Member
    Trinidad and Tobago
    2015 Prius c
    Can anyone tell me how to get the Quick Setup menu for this unit to appear?
    Even after disconnecting my 12v battery it won't appear for me to setup the unit.
    Is there a 'hard' option like a sequence to follow to get the Quick Setup menu to show up, like that of the Service Menu?
    Any help much appreciated. Thanks!
    Imran82 likes this.
  13. Szyahya
    Szyahya New Member
    Karachi
    2012 Aqua
    Dear DJ Q
    This link does not works now, as I have replace colon and dot.
    Imran82 likes this.
  14. Imran82
    Imran82 New Member
    Malaysia
    2014 Prius+ MPV
    Upgrade
    Hi... I also need that file too. The link can't open anymore.
  15. DJ Q
    DJ Q Junior Member
    35
    Trinidad & Tobago
    Unfortunately, I've had to delete the file online as I needed the space.
    I'll try to have it back online soon.
  16. Arslan Ahmad
    Arslan Ahmad New Member
    Pakistan
    Please update the link
    javair jarrett likes this.
  17. javair jarrett
    javair jarrett New Member
    Jamaica
    Technology
    HEY can you upload the file again. i need it desperately for my car
    can i get a copy of the file
    #37 javair jarrett, Aug 19, 2019
Loading...
