Toyota Aqua navi "nszt-w62g" language change
Discussion in 'Prius c Accessories and Modifications' started by lkman, Oct 3, 2014.
  1. MangroveD
    MangroveD New Member
    Trinidad and Tobago
    2015 Aqua
    Can I have this file, it isnt available anymore.
  2. MSF1344
    MSF1344 Junior Member
    61
    UK
    Active
    Hi , I just bought my toyota prius with this unit installed and there is a japanese words on screen and I dont know how to open the lcd and accsess to sd or cd player . can anybody help me ? Thanks
  3. AR Ser
    AR Ser New Member
    Malaysia
    Hi DJ Q
    Could you re-upload the link for this map data.
    Or could be anyone can upload. I think my SD card was corrupt. Need to counter check
  4. DJ Q
    DJ Q Junior Member
    52
    24
    Trinidad & Tobago
    Hey yes I had this same problem once. You have to go into the system to fix this.
    I honestly don't recall the sequence and I've since changed my unit.
    When I have some time, I'll power it up and see if I can navigate to that menu.
    I'm not sure if I can get to the menu without the camera hooked up though but we'll see.
    Also, I still don't have anywhere to host the file.
    I know you guys need it, but I honestly just don't have anywhere to host it.
  5. abel jhonatan
    abel jhonatan New Member
    bolivia
    2012 Nissan LEAF
    I am from Bolivia I had a toyota radio which was stolen from me now I bought the same model NSZT-W62G I beg you help DJ Q and you can upload the files, because now it only appears to me as locked and asks me for an SD card please brother
  6. abel jhonatan
    bolivia
    2012 Nissan LEAF
    upload it to google drive if you don't have space Bro! I beg you!
  7. Larry Ramdial
    Larry Ramdial New Member
    trinidad
    2016 Aqua
    Technology
    hey good day. can you repost the link please? i want to try the software
  8. Ravisha
    Ravisha New Member
    Sri Lanka
    Three Touring
    I don't know if you were able fix this or not, there's a video
    Unfortunately that doesn't have audio instructions
    So first you have turn you vehicles headlight switch to off position, then press and hold map button while switching headlight switch to parking light position 3 times. This is the hidden configuration menu of this unit
    Follow the steps in the video
    In last couple of minutes in the video you can see that he's doing something while holding two buttons on the screen. You have to turn your steering wheel to fully counter clockwise while holding the left button and clockwise while holding the right button. That way you'll be able to setup full camera guidelines
  9. CrzDoc
    CrzDoc New Member
    auckland
    the link no longer avialable can you upload again ?
  10. Mwaura
    Mwaura New Member
    Nairobi ,Kenya
    2013 Aqua
    Dear all ,I bought a Sienta with NSZT-W62G deck unit ,I found the manual for this unit is in Japanese,After alot of struggle i managed to translate it to English that can be read.My problem is how can i write music to the head unit memory
  11. MSF1344
    61
    UK
    Active
    There is no need to write music . just buy a memory card and write the music from your pc to memory card , then insert the memory in the head unit . all done.
  12. JRKT1993
    JRKT1993 New Member
    Trinidad
    2012 Aqua
    I
    Can you repost the link please i need it for me car.
  13. Hiran Lowe
    Hiran Lowe Junior Member
    Sri Lanka
    anyone got the files? please upload and send me the link.
  14. Hiran Lowe
    Sri Lanka
    please upload again
  15. Leli1024
    Leli1024 New Member
    Malta
    Recently got the file, will post it here soon as I'm too new to post links
  16. Hey
    Hey New Member
    Japan
    2022 Prius
    Business Edition
    Hey, please post it if you can. I believe you can post links after your fifth post. Cheers.
  17. Radjiv
    Radjiv New Member
    Suriname
    2012 Aqua
    Hello sir, can u help me with the software?
  18. DJ Q
    DJ Q Junior Member
    52
    24
    Trinidad & Tobago
    Hi all... I honestly forgot about this.
    I'll try to sort this out this coming weekend.
    Zakum and Boniface like this.
  19. Bravo
    Bravo New Member
    New Zealand
    Thanks DJ Q waiting for it!
    Boniface likes this.
  20. Boniface
    Boniface New Member
    Nairobi
    Hey, DJ Q!
    I am also eagerly waiting for the file. My NSZT-W62G gives the card error after battery change.
    I can give you access to my server to host the file.
    Also, which software should we use to write the file to the card?
    Thanks in advance!!
    (y)(y)(y)
    Bravo likes this.
