Toyota Aqua navi "nszt-w62g" language change
Discussion in 'Prius c Accessories and Modifications' started by lkman, Oct 3, 2014.
  1. Bravo
    Bravo New Member
    New Zealand
    Thanks man!
  2. Bravo
    Bravo New Member
    New Zealand
    DjQ waiting..
  3. Lemir
    Lemir New Member
    Georgia
    2016 Aqua
    DJ Q, did you manage to post the software again?
  4. Zakum
    Zakum New Member
    New Zealand
    2012 Aqua
    Any luck with the updated link? Please upload it if possible
  5. 9001MPG
    9001MPG Junior Member
    33
    New Zealand
    Hi team,
    Here is the map SDcard contents with instructions: https://1drv.ms/u/s!ApYcDQ2mW26WgqZf050ZtE93DWNqJg?e=ahLr2P
    If you're having trouble unzipping, use 7zip: https://www.7-zip.org/download.html
    The windows zip utility had some issues with this one, as there's something like 20,000 folders with 19,000 files inside, so it's going to take a while to open and decompress.
    I have 1TB of OneDrive storage, with this sitting my dedicated hosting folder, so won't be deleting this one anytime soon.
    Let me know if that works.
    Incursio likes this.
  6. Incursio
    Incursio New Member
    UK Lancashire
    Business Edition
    You're a frikken Legend for doing this.
    Thanks a lot bro.
    Just out of curiosity will this file work for other Prius decks similar to these i.e. JDM imports I can give model numbers if that makes it easier.
    Once again thanks a lot been looking everywhere for this.
  7. 9001MPG
    33
    New Zealand
    Hey no worries at all. So did it work for you?
    I'll check on the pile of old units at work see if we have any japanese units I can upload. I imagine this only works with the specific radio but who knows.
    Do drop radio unit model numbers and will keep an eye out.
  8. Incursio
    Incursio New Member
    UK Lancashire
    Business Edition
    Hey bro,
    I put the SD card into the car it loaded up the SD card data on screen since I followed all the instructions and it finally let me get into the car radio so can change stations but the functionality is still limited as I'm getting the following error message.
    Even when I try to access the settings menu I got the following message:
    Map SD is not included Please insert map SD AV AV
  9. 9001MPG
    33
    New Zealand
    I see. Ok I'm going to create a 1:1 exact copy of the SDcard using some imaging tools and will upload that shortly with some instructions on how to use it on your end. Should have something for you to try in the next few hours.
  10. 9001MPG
    33
    New Zealand
    Aight, try this: https://1drv.ms/u/s!ApYcDQ2mW26WgqZf050ZtE93DWNqJg?e=ahLr2P
    I've updated the readme for how to flash an image to SDcard. Because we're using imaging this time it's literally copying the whole SDcard, byte for byte, exactly. Any weird hidden files etc, will get copied or whatever it was that wasn't right. Should work now.
  11. Incursio
    Incursio New Member
    UK Lancashire
    Business Edition
    I appreciate the help, I've mounted image files before, so I downloaded the file and tried to mount to SD card used multiple different adapters and SD cards all at least 16 Gb but each time I tried to use balenaetcher on the file it would get to end and fail after hitting 100%, even tried with Rufus instead of Balenetcher as I've used it in the past and I'm familiar with it but the issue persists.
    Each time it failed I needed to use SD card formatter to format the SD card to try again.
    I even tried to extract the file and mount :>.
    Sadly it didn't work either.
    I'm thinking it could be the file, as I've tried everything on my end apart from a different operating system.
    LMK if you were able to get it to mount to SD card and I'll see what else I can do as I've exhausted 10 hours on the thing already but I'm confident we'll get there.
    Thanks again for helping.
  12. 9001MPG
    33
    New Zealand
    Incursio, let me know if it works for you.
  13. Incursio
    Incursio New Member
    UK Lancashire
    Business Edition
    Sadly It's taking ages for the moderators to approve my posts.
  14. 9001MPG
    33
    New Zealand
    I see. I used the Linux command dd to pipe it into a gzip archive. I would have thought that'd do the trick. Will investigate further..
    Hiran Lowe and Incursio like this.
  15. Hiran Lowe
    Hiran Lowe Junior Member
    Sri Lanka
    did the image work for you with balena etcher?
  16. hashila
    hashila New Member
    srilanka
    2012 Aqua
    Four Touring
    can u send a new link plz
  17. Cedo1497
    Cedo1497 New Member
    Kenya
    9001MPG
    Hello the file says its encrypted, according to google translate, please help
