Toyota ATF WS vs Toyota ATF D3
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Anklepain, Jul 18, 2024.
  1. Anklepain
    Anklepain Junior Member
    31
    Finland
    2014 Prius+ MPV
    Is there any difference between these 2 fluid? I would like to make things simple and buy the Toyota ATF WS but there is none in my country or even in europe for sale. Only the Toyota ATF D3 is for sale.
  2. Anklepain
    31
    Finland
    2014 Prius+ MPV
    ATF WS is the black and ATF D3 is the grey one.
  3. Anklepain
    31
    Finland
    2014 Prius+ MPV
    The car is Toyota Prius V 2014. 240 000km.
  4. Mendel Leisk
    42,369
    Are there Toyota dealerships in Finland?
  5. Anklepain
    31
    Finland
    2014 Prius+ MPV
    I found this Mannol Toyota ATF-WS transmission fluid in finnish website. It is from Mannol brand but still O.E.M. Does it needs to be from Toyota brand?
  6. Anklepain
    31
    Finland
    2014 Prius+ MPV
    Here is the picture of Mannol Toyota ATF-WS fluid
  7. BiomedO1
    BiomedO1 Senior Member
    4,636
    2,434
    Left Coast
    A Toyota dealership should be able to source that for you and most of them have an online parts portal.
    My main concern with using D3 is how it's going to affect the wiring insulation within the transmission? You can get away with throwing anything into this simple planetary gear transmission but if it delaminates the wiring insulation within, your transmission will fail. IMHO, that isn't the proper way to do maintenance on your car - better to just leave it alone and hope for the best.
    Good Luck....
  8. Mendel Leisk
    42,369
    How much is that, a liter, multiple liters? If it’s 40 euros per liter, that is exhorbitant. Here in Canada it’s around $10~12 CDN per liter.
    again: are there Toyota dealerships in Finland?
  9. Anklepain
    31
    Finland
    2014 Prius+ MPV
    It is 40 euros per 5 liter. Is there any difference between Toyota and Mannol Toyota OEM
    There is Toyota dealership in Finland but I believe they sell only cars and fix them.
  10. Anklepain
    31
    Finland
    2014 Prius+ MPV
    But do you know what is the difference between Toyota ATF WS versus Mannol Toyota ATF-WS O.E.M?
  11. Mendel Leisk
    42,369
    Have you contacted any dealerships, asked these questions?
  12. BiomedO1
    4,636
    2,434
    Left Coast
    Mannol is a EU manufacturer/distributor of automotive parts.
    IMHO, If your not going to use genuine Toyota ATF-WS; the next best choice is Aisin ATF-WS fluid. They manufacture the Prius transmissions for Toyota and other OEM manufacturers.
    Hope this helps....
    #12 BiomedO1, Jul 21, 2024
