toyota auris hybrid this fall??
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Flying White Dutchman, Jun 26, 2009.
  1. Tideland Prius
    16,672
    Thanks Mike! So it's on its own platform then?
  2. CenVal
    CenVal Member
    48
    Sorry for getting in the middle of your conversation but here's what I read this morning regarding your platform question... Shares the same platform as the Prius according to Timesonline, UK.
    At last, Britain is ready to build hybrid cars - Times Online
  3. Tideland Prius
    16,672
    Interesting. It'll be the first vehicle (well I guess second since the S-Class will be launchd before the Auris Hybrid) to be offered in petrol, hybrid and diesel!
    Well the media here also said that the Prius is based on the Scion xB so I'd take it with a grain of salt.
  4. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    heh... i like the term "chasis platform", so specific and vagoue at the same time :).
    Auris has same platform as Corolla, its Corolla Hatch. It will be interesting to see how they priced the hybrid - it should get decent pricing as no customs are paid since it is from EU. If it is priced similar to 2.0 D4D and it doesnt take too much of boot, we could have win-win situation.
    Early next year is refresh for Auris so this is timely.
  5. Flying White Dutchman
    4,376
    313
    so maybe we get the 2011 new auris with a new body and the introduction of the hybrid version
  6. Wooski
    Wooski New Member
    241
    63
    London, UK
  7. Evilshin
    Evilshin Member
    119
    Is it me, or does the Auris look a LOT like a Matrix? And the Matrix is the closest non-hybrid to the Prius...
    Hmmm...
  8. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    Following is the press release.
    July 17, 2009
    TMC's U.K. Vehicle Production Base to Build Hybrid Auris
    Tokyo — TOYOTA MOTOR CORPORATION (TMC) announced today it will produce from mid-2010 a hybrid version of the "Auris" hatchback at Toyota Motor Manufacturing (UK) Ltd. (TMUK). The hybrid Auris, using engines produced at TMUK's Deeside Plant, will be produced at TMUK's Burnaston Plant.
    read more
    Ken@Japan
  9. Flying White Dutchman
    4,376
    313
    thats one year from now.... wow. thats soon.
    intressing to go and have a look at the prototype version in the UK
  10. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    The problem they may have is that this announcement might put some people off a new Prius! Particularly if the Auris comes out cheaper but not significantly more fuel consumption.
    I anticipate that Prius will still probably consume less fuel than Auris because although Prius will likely be heavier, it's more aerodynamic. Obviously this will be a new model, so some things could change on Auris, e.g. aluminium panels where structural strength isn't important, like the bonnet and hatch as on Prius, and they could well achieve lower drag through the use of aero corners, but I don't think very low Cd is possible with the standard cut-off vertical hatchback shape.
  11. Flying White Dutchman
    4,376
    313
    then it wil have better city mpg and wurst highway mpg.
    depends on where you drive the most
  12. 1SMUGLEX
    1SMUGLEX I love the smug!
    315
    51
    Atlanta
  13. Flying White Dutchman
    4,376
    313
    qoute
    "The Auris platform was designed so it could also carry a hybrid system," Otsuka said. "By making it flexible, it can accommodate future overseas production and reduce costs."
  14. Tideland Prius
    16,672
    The current Matrix, I've heard, was also designed to take in HSD.
  15. Evilshin
    Evilshin Member
    119
    The Matrix and the Prius have the same chassis, but they differ in some areas. So it's no issue to make a Matrix hybrid. The body shape of the Matrix is less aerodynamic, but offers better interior cargo room. Other than trim, the cars are very similar.
  16. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    I'd like my hybrid Matrix in the AWD model please. :cool:
  17. jdenenberg
    jdenenberg EE Professor
    3,961
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    But make that an eAWD like the THH with an extra MG on the rear axel for me.
    JeffD
  18. Evilshin
    Evilshin Member
    119
    That would be the only way not make it into a Malibooboo type hybrid that gets about 2 MPG better than the non-hybrid version, and get AWD.
    But maybe two MGs, one for each rear wheel would be better. The you would have four wheel regen braking and four wheel electronic traction control. But unfortunately you would also have a $50,000 car....
    If you really want a matrix body for the prius, it probably can be done. If you want the AWD, that wouldn't be so easy... Hell, even the highlander and the Escape hybrids are FWD only...
  19. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Huh? :confused: That's not true, unless you are making some sort of technical distinction I don't understand.
    Also, I would probably prefer a hybrid Rav4 in any case, but it would be an interesting option to have it on a matrix, if it could be done for a reasonable cost.
  20. Evilshin
    Evilshin Member
    119
    Are you talking about grafting a matrix body onto a prius? Or are you talking about AWD hybrids?
    Grafting a matrix body on to a prius is theoretical. The mounting points for the body panels are the same. But the interior controls would still have to be prius's. The seats, and much of the interior would be the prius's. The parts of the matrix that can be accomodated would be the matrix hood, the door panels (probably the doors) and the lift back and the roof. If you do that, then you would have a "matrix" hybrid. This would be like converting a fiero to look like a ferrari f-40, except you can use real matrix parts. I am not talking about going into a dealership and ordering a hybrid Matrix... I'm talking about dyi modification. Nothing untrue about that...
    If you are talking about AWD hybrids... I could be wrong on this, the last time I checked, none of the hybrid SUVs are AWD. Not even the crappy GM ones...
