Toyota Cuts Weight of New Prius by Using More High-tensile Steel Plates
Discussion in 'Gen 4 Prius Main Forum' started by usbseawolf2000, Oct 25, 2015.
  1. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    A 5 mpg gain is a 10% gain, any such that could gain 10% would do backflips, why the hate?
    51,896
    cyclopathic must have a new email.
  3. KrPtNk
    KrPtNk Active Member
    323
    283
    Pacific Northwest
    Sorry. I misread your post.
  4. Tideland Prius
    16,554
    Did it not help the Prius v? It was only a suggestion.
    Also, what about the new parallel gear reduction motor. As I understand, a reduction motor acts like a torque converter, multiplying torque through the PSD. This means, Toyota is free to downsize the electric motor in terms of physical size, weight and power/torque output, because the torque loss in the size & weight reduction is compensated by the addition of said reduction motor.
  5. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    I don't know if it was meant to be hateful but Chinna can address that.
    A 10% gain is important for marketing purposes but doesn't make much difference in fuel cost. It actually represents about a 9% reduction in an already low fuel cost. If you drive 12,000 miles per year you would use about 22 fewer gallons, about $44 at today's prices.
    That said, I think the improvement will be more than 10% for those of us who live in a place with a real winter and do short drives. The current Prius takes a big hit under those conditions. The Gen 4 should reach efficient hybrid temp sooner and therefore get better winter mileage that may not show up in official figures.
  6. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    I will also reach comfortable cabin temp sooner...but I cannot quantify this in $.
  7. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    I is doing the same in G3 with the secondary planetary set. If they have changed the ratio (as compared to G3) then the motor can be smaller.
    Tideland Prius likes this.
  8. bisco
    51,896
    think globally. what if every vehicle accomplishes these kinds of improvements with each generation? we're not going to leap to 100 mpg in 10 years, it's baby steps. congrats to toyota for trying and succeeding.
